Drives: WR Blue BRZ
Sooo..The BRZ died
Hey all any insight in to this issue was appreciated.
Coming home last night from a track day, (No issues at all on track can drove great) I made it about an hour and a half out of a 2hr drive, my car stalls and dies on the highway. What happened is driving along with cruse control on 65ish towing a tire trailer, car dips down to 64 and comes back to 65. I don't think anything of it and turn of cruse. A few minutes later it happens again going up a slight slope, downshift to 5th everything is fine shift back to 6th. Happens again this time I put the clutch in and floor it revs fall and the engine stalls. Engine will crank but not start, no obvious failures, holes in the block, clouds of smoke, good oil pressure. No excess oil in the catch can. NO CEL, no codes. Mods: Jackson Racing Super Charger (stock pulley 93 oct Moto East Tune) Velox Catch Can, JR Oil Cooler, DW 300 Fuel pump. |
#2 |
22R
Drives: 2012 Camry SE 2017 Toyota 86
Outta gas !!
22R |
#4 |
Drives: WR Blue BRZ
#5 |
Huge E85 fan!
Drives: 2016 Scion FRS
coil pack will throw a code. Fuel pump issues will not.
You didn't see a charging system light come on while the engine was still working did you? An alternator issue won't throw a code either. |
#7 | |
Drives: WR Blue BRZ
So I think that rules out charging system. |
#8 |
Drives: WR Blue BRZ
#9 | |
![]() Fuel - compression - spark - which one(s) don't your engine have ..... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | BirdTRD (08-13-2017) |
#10 |
Drives: FT86
can you log the MAP sensor output
bad MAP (manifold pressure sensor) car wont start check fuel pressure, you should hear fuel pump prime when ignition on usually can you read any CEL codes ? not all codes light the dash light |
#11 |
Hombre
Drives: 1994 Supra Turbo
I would take the battery to an auto parts place to have it checked. It may not be quite strong enough to fully start the car. Might indicate an alternator problem. AMHIK.
A Toyota Racecar A Toyota......................Because.
Anyway, should not palindrome be spelled palinilap? |
#12 |
Drives: WR Blue BRZ
| The Following 2 Users Say Thank You to zypher For This Useful Post: | Icecreamtruk (08-15-2017), Tcoat (08-16-2017) |
#13 | |
......... you know where the stool is ....... ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | zypher (08-16-2017) |
#14 |
The Fail Boat
Drives: CWP S.B.
lmao...
Too many Gs broke the fuel indicator.
| I died when I saw this.. | Koa | Scion FR-S / Toyota 86 GT86 General Forum | 71 | 03-30-2015 10:48 PM |
| Infamous Performance Huge Spring Sale!! Sooo many ways to save! | Infamous Performance | Transmission and Driveline | 22 | 03-31-2014 04:28 PM |
| Sooo out of curiosity | ThatManAnt | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 6 | 03-05-2013 04:15 PM |
