Old 08-13-2017, 08:08 AM   #1
zypher
Drives: WR Blue BRZ
Sooo..The BRZ died
Hey all any insight in to this issue was appreciated.
Coming home last night from a track day, (No issues at all on track can drove great) I made it about an hour and a half out of a 2hr drive, my car stalls and dies on the highway.
What happened is driving along with cruse control on 65ish towing a tire trailer, car dips down to 64 and comes back to 65. I don't think anything of it and turn of cruse.
A few minutes later it happens again going up a slight slope, downshift to 5th everything is fine shift back to 6th. Happens again this time I put the clutch in and floor it revs fall and the engine stalls.
Engine will crank but not start, no obvious failures, holes in the block, clouds of smoke, good oil pressure. No excess oil in the catch can. NO CEL, no codes.
Mods: Jackson Racing Super Charger (stock pulley 93 oct Moto East Tune) Velox Catch Can, JR Oil Cooler, DW 300 Fuel pump.
zypher is offline   Reply With Quote
Old 08-13-2017, 08:26 AM   #2
22R
22R
22R's Avatar
Drives: 2012 Camry SE 2017 Toyota 86
Outta gas !!
22R
22R is offline   Reply With Quote
Old 08-13-2017, 08:30 AM   #3
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
No problems with the serpentine belt/belt tension?
BirdTRD is offline   Reply With Quote
Old 08-13-2017, 08:43 AM   #4
zypher
Drives: WR Blue BRZ
Nope every thing looked good with the belt/tension ac was on and working great.
My best guess right now is the coil pack shit the bed.
Old 08-13-2017, 09:14 AM   #5
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
coil pack will throw a code. Fuel pump issues will not.
You didn't see a charging system light come on while the engine was still working did you? An alternator issue won't throw a code either.
guybo is offline   Reply With Quote
Old 08-13-2017, 10:03 AM   #6
mrg666
pessimistic skeptic
mrg666's Avatar
My guess is the fuel pump or injectors
Old 08-13-2017, 10:26 AM   #7
zypher
Drives: WR Blue BRZ
No charging system light, the car was running fine and then just acted like it stalled. Battery was still strong enough to attempt to start 4 or 5 times and still not show any signs of being low.
So I think that rules out charging system.
Old 08-13-2017, 10:27 AM   #8
zypher
Drives: WR Blue BRZ
Possibly now that I think about it when I installed the fuel pump I did not install all the oring's and it was similar, I had fuel pressure but would not start.
I will take a look at that.
Old 08-13-2017, 01:51 PM   #9
Your engine had a heard attack ??.......
Fuel - compression - spark - which one(s) don't your engine have .....
Old 08-14-2017, 01:12 AM   #10
steve99
Drives: FT86
can you log the MAP sensor output
bad MAP (manifold pressure sensor) car wont start
check fuel pressure, you should hear fuel pump prime when ignition on usually
can you read any CEL codes ? not all codes light the dash light
Old 08-14-2017, 01:49 AM   #11
Silver Supra
Hombre
Silver Supra's Avatar
Drives: 1994 Supra Turbo
I would take the battery to an auto parts place to have it checked. It may not be quite strong enough to fully start the car. Might indicate an alternator problem. AMHIK.
A Toyota Racecar A Toyota......................Because.
Anyway, should not palindrome be spelled palinilap?
Silver Supra is offline   Reply With Quote
Old 08-15-2017, 09:59 PM   #12
zypher
Drives: WR Blue BRZ
Originally Posted by 22R View Post
Outta gas !!
22R
Winner winner chicken dinner.
Turns out I ran out of gas.
Don't exactly know what happened as my fuel gage still read a quarter tank. It reads full now with a full tank.
Thanks to all of you for trying to help me out.
Old 08-15-2017, 10:26 PM   #13
......... you know where the stool is .......
Old 08-15-2017, 10:38 PM   #14
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
lmao... Too many Gs broke the fuel indicator.
I died when I saw this.. Koa Scion FR-S / Toyota 86 GT86 General Forum 71 03-30-2015 10:48 PM
Infamous Performance Huge Spring Sale!! Sooo many ways to save! Infamous Performance Transmission and Driveline 22 03-31-2014 04:28 PM
Sooo out of curiosity ThatManAnt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-05-2013 04:15 PM
