Old 08-09-2017, 05:35 PM   #113
JermMX5
Drives: 2017 Toyota 86
Originally Posted by Tuxedo Tony View Post
Stage 1 you're not going to notice a difference in performance on a stock car on 91 or 93.
Ehh on the older cars I could definitely feel the dip be filled in. It didn't feel like a rocket ship obviously, but I wasn't pissed off at the dip anymore.
My 2017 still has the vtec feeling like im going from no torque to tons.
2017 Toyota 86 - Whiteline 20mm Front Bar | Crash Bolts | 235/45/17 RE-71R | 17x7.5 OZ Omnia | OFT Stage 1 For Street Driving | Trackpipe for AutoX | Not enough camber.
JermMX5 is offline   Reply With Quote
The Following User Says Thank You to JermMX5 For This Useful Post:
OrangeGuitar (08-09-2017)
Old 08-09-2017, 06:40 PM   #114
invaliduser
Drives: 2017 86
Tunes for the 2017 cars do not have nearly the same performance gains as the 13-16.
Sent from my Pixel XL using Tapatalk
invaliduser is offline   Reply With Quote
Old 08-09-2017, 07:00 PM   #115
JermMX5
As I've sadly found out...
But the biggest reason I bought it was to bump up the rev limit and to make it a softer limit for autocross (since the second gear is so short), and it did in fact do that. Once they figure out launch control for the 2017 then I'll be content.
Old 08-09-2017, 07:06 PM   #116
churchx
churchx's Avatar
Drives: 2014 GT86
Or it can be worded other way. 2017 may have share of max gains already as stock.
Old 08-09-2017, 07:23 PM   #117
JermMX5
Could be true, but I know that for 2017 the stock headers were changed quite a bit to increase flow, yet the stock car only gained 5hp over the previous generations. I would think that the stock 2017 header should allow me to get some nice gains with the right tune. I bashed on the car for quite a while, and I couldn't get it to knock even once according to the OFT.
If anyone has any suggestions/guides on tuning timing, AFR, etc to get the best gains possible from a road tune let me know and I'll do it and post the results (and the tune if anyone would want it).
But the fact that the car didn't have to once correct timing for knock tells me I have power to be had.
Old 08-09-2017, 07:53 PM   #118
G-awesome
Drives: 2015 Firestorm Scion FRS
hold up! so the v3 are leaked or released? I'm getting antsy! lol ME WANTS.
G-awesome is offline   Reply With Quote
The Following 2 Users Say Thank You to G-awesome For This Useful Post:
smg1138 (08-10-2017), timmydatooth (08-11-2017)
Old 08-10-2017, 02:56 PM   #119
JermMX5
So after being able to smell a bit of gas after doing some pulls I logged a little launch to redline 1st, redline 2nd, and 3rd to 7k rpm and it's at 11.02 AFR from about 6-7k and it seems really rich in quite a few places. And once again no knock correction. So to me it looks like the stage 1 tune at least is super conservative and probably for 91 octane.
Anyone have any input on the AFRs?
http://www.datazap.me/u/jermmx5/stag...00&tmax=617.00
Old 08-10-2017, 09:38 PM   #120
nocoolname
You need to log afr commanded as well, with that you can determine if you need to scale your MAF or not.
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily
2013 BRZ limited - new toy
nocoolname is offline   Reply With Quote
Old 08-11-2017, 02:59 AM   #121
steve99
Drives: FT86
Attachment 156948
The 2017 fuelling works different to the old cars, theirs extra tables one ecutek calls "power AFR" it doesn't seem to be identified the the opensource definitions I have seen, however shiv may have better defs. The extra tables are used as well as the normal OL fuel tables (and their is two of those as well)
Old 08-11-2017, 12:06 PM   #122
JermMX5
How do I change what the OFT logs?
Old 08-11-2017, 01:17 PM   #123
nocoolname
Similar to PE table in GM ecus?
Old 08-11-2017, 03:42 PM   #124
Bamco
Drives: Satin White Pearl BRZ 6MT
Originally Posted by tdotBRZ View Post
@Shiv@Openflash You've mentioned this new 3.0 tune will be different, how so and how will this new tune compare to the OFH Stage 2 tune (the more aggressive one), if you don't mind me asking?
second that
Bamco is offline   Reply With Quote
Old 08-11-2017, 03:47 PM   #125
Bamco
any updates on this? How is this new tune compared to stage2OFH (aggressive) tune, more power more torque?
bump
Old 08-11-2017, 04:05 PM   #126
JermMX5
Originally Posted by Bamco View Post
bump
He had said in an email that tunes would be out this week, and with this being the last business day of the week it's not looking hopeful, he hasn't responded to my emails asking for the 93 tune for the 2017 so I feel like he's either too busy or something else...
OpenFlash Tablet: Multiple Data Log files! Shiv@Openflash Software Tuning 95 11-09-2017 08:40 AM
OpenFlash Tablet: OTS v2.0 Beta (132 new maps, 12 new XMLs) Available for Download Shiv@Openflash Software Tuning 1062 08-13-2017 04:13 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
OpenFlash Tablet v1.55b: BIN files added! Shiv@Openflash Software Tuning 525 04-09-2014 09:42 PM
Now Available: OpenFlash Tablet Datalogging/Datagraphing (BETA Release) Shiv@Openflash Software Tuning 255 02-15-2014 04:43 AM
