CANADA Canada
Old 08-08-2017, 02:45 PM   #1
TorontoNat
Drives: 2013 Scion FR-S Asphalt [Gray]
VERY hot air when driving
Ok so I know this is not exactly a luxury vehicle and things like this might be normal but just wanted to see if anyone had noticed/experienced the same thing.
As stated in tittle, I get very hot air coming in the cabin through the vents in the car but only when I am driving over like 40kph. Heat turned off, fan dialed to 0.. and it feels like I have the temp set to max heat and the fan on at least 3. There is no way of stopping it except obviously closing the vents manually but the ones at my feet cannot close so it gets annoying.
Should I be concerned or should I just accept the power decrease and turn on my A/C for once?
TorontoNat is offline   Reply With Quote
Old 08-08-2017, 02:48 PM   #2
These things blow the hottest ambient air I have ever experienced.
Put the control on Recirculate and it will stop.
Ultramaroon (08-10-2017), wparsons (08-08-2017)
Old 08-08-2017, 02:48 PM   #3
StraightOuttaCanadaEh
Wes
Yeah, or just set the fan to blow towards the window. Also make sure the dial is at the coldest setting, even when the fan is off.
Old 08-08-2017, 02:53 PM   #4
Still comes through the vents when moving.
Recirculate closes the flaps to outside that is forcing the air through the tubes.
TorontoNat (08-08-2017), wparsons (08-08-2017)
Old 08-08-2017, 03:03 PM   #5
Wes
I find that it doesn't bother me nowhere near as much when I set it towards the window, but yeah. I mostly drive with the windows down cause I love hearing the exhaust, so I guess I don't notice it. But with recirculate on, it gets too stuffy inside in a couple of minutes
Old 08-08-2017, 03:46 PM   #6
Not as stuffy as air the temperature of the surface of the sun being forced into the car!
StraightOuttaCanadaEh (08-08-2017), TorontoNat (08-08-2017), wparsons (08-08-2017)
Old 08-08-2017, 04:42 PM   #7
TorontoNat
Recirculate button works! Makes a big difference at least. Thanks man, great fix. Posting here = always good idea.
The Following 3 Users Say Thank You to TorontoNat For This Useful Post:
Tcoat (08-08-2017), Ultramaroon (08-10-2017), wparsons (08-08-2017)
Old 08-09-2017, 11:01 AM   #8
bee-jay
bee-jay's Avatar
Drives: 2014 BRZ LTD WR Blue Pearl
I thought it was a just a auto climate control issue, I see the manual version does this too?
I've never had a car that pumped so much heat out of the fresh air vent system
I noticed this more after a driving, then stopped. It's like the heat is on max.
Doesn't seem to do it in the morning (cold start)
I usually just turn the air on for a few minutes, once your down the road it seems to cool down a bit closer toward outside ambient.
I'll try the recirc button trick.
bee-jay is offline   Reply With Quote
Old 08-09-2017, 02:44 PM   #9
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
It's even worse if you sit with the car running for a few minutes, and then drive away.
It's like a heat-sink getting blasted into the car through the vents.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 08-09-2017, 10:33 PM   #10
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Must be nice living in a place where you don't need AC 9 months out of the year!
guybo is offline   Reply With Quote
Old 08-10-2017, 01:44 AM   #11
+1 for choosing between recirc or heat gun mode.
Tcoat (08-10-2017), wparsons (08-10-2017)
Old 08-10-2017, 11:41 AM   #12
TorontoNat
Yeah but you get palm trees.. We get snow storms (As fun as those are while your in the corners.. getting out and in the car no bueno at all.)
Old 08-10-2017, 11:48 AM   #13
LOL Ya but the minute it goes over 75 I am far to hot and need the air on so still ends up being about 7 months.
Daily Driving/Spirited Driving Brakes VABeachBRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-12-2017 05:11 PM
Nightmare driving FR-S vs driving Miata chrisngn FR-S / BRZ vs.... 64 07-06-2016 12:21 PM
Driving around. Chen Northwest 27 02-05-2014 11:47 PM
Driving on PCH through Big Sur was so fun wrb Northern California 4 12-02-2013 11:46 PM
Driving section - actually driving the things somewhere bcj Site Announcements / Questions / Issues 6 04-08-2013 12:28 PM
