MisterSheep
Old 08-07-2017, 05:48 PM   #463
Kicknwing
Drives: 2014 frs
it works pretty good but i would like it to do off throotle like my mini does
Kicknwing is offline   Reply With Quote
Old 08-07-2017, 07:11 PM   #464
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
A couple pages back we talk about how to do it off throttle. It's definitely far more practical in my opinion.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
Old 08-07-2017, 08:41 PM   #465
Kicknwing
Drives: 2014 frs
my tables dont look like the ones in the pics....i cant seem to find a defination to fix it. i have a b01c file
Old 08-07-2017, 10:38 PM   #466
22mraustin
22mraustin's Avatar
Drives: Scion FR-S
I can't find the link, but someone posted up a link that has the def files you need, it's on the this thread somewhere lol
2013 Scion FR-S
Tennessee
22mraustin is offline   Reply With Quote
Old 08-08-2017, 01:41 AM   #467
Mikyt3
Drives: Toyota GTS86
Perhaps a nooby question... but will it work with automatic cars? will there be a difference?
Mikyt3 is offline   Reply With Quote
Old 08-08-2017, 09:01 AM   #468
rjgough95
rjgough95's Avatar
Drives: 13 Subaru BRZ, 02 7.3 F350 Diesel
Yes it will when you switch it into manual. So it gives you somewhat of a control over when you want it running.
2.5" Non-resonated Perrin catback - Hks dual resonator front pipe - Borla UEL headers - K&N drop in - Supertek intake pipe - Megans Racing strut bar - Racer X Fabrication cylinder brace - Valenti tail lights - Veloxs Motorsports front splitter - Galvez Customs rear diffuser - Open Flash Tuner - GCS paddles - Apex ARC8 Track Wheels
rjgough95 is offline   Reply With Quote
Old 08-08-2017, 02:12 PM   #469
Kicknwing
Drives: 2014 frs
2013 Scion FR-S
Tennessee
Thanks, I found one that works
Old 08-08-2017, 08:15 PM   #470
eddieflyinv
eddieflyinv's Avatar
Originally Posted by WolF_RS View Post
Definition file should match with the CAL, correct?
My CAL is: ZA1JD00C
Here are all 5 tables that were mentioned, along with the definition file I'm using.
Pretty sure no one helped you yet, I just quickly scanned through lol
You need different definition files to get the tables properly defined, if you scan back you will find a link I had to some, also if you search for waynos 'guide to dialing in your tune' thread, his definitions have the tables defined as well, but you have to make sure your tune is a B01C tune internally, I'm pretty sure all the oft ones are.
If you absolutely cannot get anything to work, (try the d00c wayno defs with oft tune first) pm me and I can hack a b01c to d00c for you and provide the definition with it
eddieflyinv is offline   Reply With Quote
Old 08-08-2017, 08:18 PM   #471
eddieflyinv
I'm like 99% sure waynos defs will work for oft d00c though, only had to hack an F00C ROM so far, and I'd check what the oft roms are myself but I'm not near my laptop or tablet
Old 08-15-2017, 10:44 PM   #472
Goosfraba121
Goosfraba121's Avatar
Drives: 2013 Subaru BRZ
@Detroiter and @eddieflyinv any update on the tune files?
about to swap to this(from a couple pages ago) and was just curious if you guys made any changes for more backfire/flames or anything.. runnning JDL uel catless headers and catless frontpipe with N1 exhuast..if that helps ur thoughts on anything I should be changing.
Goosfraba121 is offline   Reply With Quote
Old 08-15-2017, 10:56 PM   #473
eddieflyinv
Still haven't played with this in a while so as for now I have nothing to add
Sent from my SM-G950W using Tapatalk
Old 08-16-2017, 12:09 AM   #474
Goosfraba121
Originally Posted by eddieflyinv View Post
Someone pm'd me about not getting much pops with e85 before using these settings,
Not sure what the deal ended up being but my guess would be to use more initial enrichment when using e85 with the same ignition retard
I am running e85 and my question is - does more initial enrichment mean going up in numbers so from 1.2 to say 2.0 or going down in numbres from 1.2 to say .5(new to this whole thing)
just did a quick like 10minute drive around town with the new tune, sounds great but I am looking for more of a flame shooting backfire :P
Old 08-16-2017, 12:25 AM   #475
eddieflyinv
More initial enrichment = higher number = longer pulse width = more fuel
Not 100% sure if that's what did it, but play around and have fun 👍
Old 08-16-2017, 07:38 PM   #476
edwardleeaf
Drives: Fr-s
Hey Eddie,
I followed wayno's guide and was able to fix a bunch of crazy numbers. However, I do not have two rows showing temperature, only one row. Any idea of how I can fix this?
http://imgur.com/HJycZq5
edwardleeaf is offline   Reply With Quote
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 05:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 06:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 08:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-18-2014 12:07 AM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 03:12 PM
