Old 06-23-2012, 09:41 PM   #1
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
traction control issue
Im drivinh to Austin, get down on an off ramp, no water, while i turn normal my TC light comes on as if its too sensitive, anyone experienced this yet
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
*KID* is offline   Reply With Quote
Old 06-23-2012, 10:07 PM   #2
b.e
Drives: 2013 FR-S Hot Lava, 2007 Tundra
Dirt on the road? I"ve been places where something was on the road as I turned on top of it, and the traction control activated. Or stability control. Something activated.
b.e is offline   Reply With Quote
Old 06-23-2012, 10:15 PM   #3
Bristecom
Bristecom's Avatar
Drives: 2017 Subaru BRZ PP
Remember that it's a slip light and doesn't necessarily mean it activated TC or VSC.
Toyota + Subaru =
Bristecom is offline   Reply With Quote
Old 06-23-2012, 10:17 PM   #4
*KID*
86-er
*KID*'s Avatar
Drives: BRZ tS
I felt it activate, n the road looked clean
Old 06-23-2012, 10:36 PM   #5
eriktherod
Drives: 2013 Scion FR-S Firestorm Red MT
I've noticed it's sensitive but it doesn't bother me. It's my first RWD car and if I drive it like my Si, it's probably saving me from doing something stupid. That's how I see it anyways.
eriktherod is offline   Reply With Quote
Old 06-23-2012, 10:41 PM   #6
WolfsFang
Scrape Master
WolfsFang's Avatar
Drives: Goal: Oldest FRS State Side
The light comes on when their is a issue, as in the tires broke loss while TC and VSC were on. I was responding to a fire call when it was raining, took a turn and the car broke sideways a little and the light flashed. This also happened to me when on a dirt road.
WolfsFang is offline   Reply With Quote
Old 07-04-2012, 12:04 PM   #7
tanner_p32
Drives: red Scion Fr-s
traction control problem
I just bought a Fr-s auto and i cant get the wheels to spin at all. i turned the tc off the vsc/vsc sport and then held the vsc for 5 sec and still nothing not even around a corner, what am i doing wrong?
tanner_p32 is offline   Reply With Quote
Old 07-04-2012, 12:11 PM   #8
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
What you did wrong was buy an auto.
Kidding aside, get it into manual mode not drive and keep the rev range high. To spin them on a launch you have to hold the brakes about 80% get the revs up, then drop the brakes.
Hawaiian is offline   Reply With Quote
Old 07-04-2012, 04:17 PM   #9
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
If I recall correctly ..
Sport mode; TSC VSC off
please dont do this on the streets, already got 1 totalled FR-S
Old 07-04-2012, 05:05 PM   #10
ChrisH
Drives: Car
Hi *KID*
I don't have a GT 86 yet.
However, I have a BMW with a 77% LSD (clutch type LSD).
On very tight corners (e.g. if you turn at a very tight cross road corner) even at extremly low speed the LSD starts to lock a little, which may result in a very mild slip at the inner rear wheel - actually the only thing, how you know your car is equipped with an LSD at moderate speed.
It may be possible, that this warning light comes up in this moment.
Does that maybe have to do with your observation?
ChrisH is offline   Reply With Quote
The Following User Says Thank You to ChrisH For This Useful Post:
davesrave (07-07-2012)
Old 07-05-2012, 11:15 AM   #11
WolfsFang
Scrape Master
WolfsFang's Avatar
Originally Posted by ChrisH View Post
Hi *KID*
do a burnout and if you see two marks you got a lsd
Old 07-07-2012, 05:22 PM   #12
ChrisH
Drives: Car
Hi *KID*
Sorry, folks, I should add a note here:
My clutch type LSD has a preload (i.e. some pre-locking), which makes it work also in the snow.
In contrast, a Torsen LSD can not be equipped with a preload.
So maybe I was wrong here and the FR-S will actually NOT show this behavior of my BMW in very tight corners!
Old 07-07-2012, 06:45 PM   #13
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
Welcome to owning a vehicle equipped with a limted slip differential
Touge Monster is offline   Reply With Quote
Old 07-08-2012, 08:13 PM   #14
mike2100
mike2100's Avatar
Drives: 23 BRZ
Welcome to the wonderful world of rear wheel drive. If you have the opportunity or can create one, I recommend practicing weight transfer and inducing oversteer and understeer. Of course, don't practice where you can hit other people!
mike2100 is offline   Reply With Quote
Traction/VSC Setting Preference ashtray BRZ First-Gen (2012+) — General Topics 27 08-24-2018 03:39 PM
BRZ Voice Control touge-n00b Electronics | Audio | NAV | Infotainment 3 04-03-2013 03:11 PM
TPMS and Traction Control Mavrik Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-02-2012 01:50 PM
Auto climate control Daemione Electronics | Audio | NAV | Infotainment 37 06-05-2012 09:19 PM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
