View Poll Results: Traction Control and VSC setting preference for your daily drive
TC on, VSC on (full) 13 29.55%
TC on, VSC Sport 15 34.09%
TC off, VSC on 2 4.55%
TC off, VSC off 7 15.91%
TC off, VSC Sport 7 15.91%
Voters: 44. You may not vote on this poll
Old 03-27-2012, 03:26 AM   #1
ashtray
As Seen On The Internet
Drives: 2003 WRX, 2013 BRZ, 442
Traction/VSC Setting Preference
How do you guys plan to have the settings for traction control and VSC on a normal dry day, for casual driving (commuting but not bumper to bumper)?
Since my other car is an NA Miata with neither traction nor VSC (or even a torsen or abs) I don't think I will miss traction control much. (allow me to spin the rears on takeoff a tad). I'm thinking the sport VSC setting would be fine for my driving style.
Does the car default to both systems on at every startup, or remember your last setting?
ashtray is offline   Reply With Quote
Old 03-27-2012, 03:30 AM   #2
Canibuz
Canibuz's Avatar
Drives: BRZ SOON!
If I recall reading the manual right we have to turn it off everytime we start the car. I will keep it on and see what it does. Once I get used to the limits of the car I am sure it will be off all the time. My MR2 was no thrills either
The member of the BRZerhood formerly known as Reypt
How to spot a troll
Canibuz is offline   Reply With Quote
Old 03-27-2012, 03:40 AM   #3
Sasquachulator
Pavement Grey
My car has neither, so traction/VSC would be new for me
Turning it off would have no effect on me lol.
Old 03-27-2012, 06:52 AM   #4
Deslock
Deslock's Avatar
Drives: 2013 DZE/01 (sold for MX5 ND1)
My current ride lacks even ABS, though I've driven many cars with traction/stability control.
From Autoblog's review:
The Vehicle Stability Control (VSC) in Normal mode will catch things when the tail strays a bit hard from the slip-angle safety zone, but it's not a violent clamping down on the proceedings. I was still wagging the tail nicely on the route's myriad hairpins, and the brake activation was meted out so as to blend pretty well with my driving style. Switching to VSC Sport and its higher thresholds allowed even smoother, slight drifts through entire hairpins.
If the system is as non-obtrusive as he says, it makes sense to leave TRC/VSC enabled on public roads. I'll probably use sport mode.
A rant about misusing traction control:
It's intended as a safety feature in case you encounter an unexpected situation, so it should be left on. But don't use it to drive faster than you can without it.
I knew two drivers who had 2006 and 2007 Civic Sis (I'll refer to them as 6 and 7). Only the latter had Honda's TCS/VSA. 7 would fly around corners much faster than 6, not realizing that the computer was the only reason he wasn't crashing.
We all went to an autox, and 6 wasn't doing that well while 7 did great. He was talking a lot of smack about crushing 6's times, so before 7's next run I suggested he disable his traction control (he didn't know how, and I had to show him how to override it).
I've never seen anyone hit so many cones.
Hopefully 7 learned a lesson that day, but probably not. I used to warn him that if he ever came around a corner into a patch of leaves/sand/oil, his crash could be even worse than if he didn't have TCS/VSA (because he was traveling at such high speed). He moved away shortly after and I don't know if he ever had any mishaps.
Deslock is offline   Reply With Quote
Old 03-27-2012, 07:47 AM   #5
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I don't drive like a punk so it'll stay on for the street. I see no reason to turn it off. On the track/Autocross it'll be completely off.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-27-2012, 08:01 AM   #6
Kiwi
Drives: Volkswagen Golf GTI
While I was reading this, the word R35 kept appearing inside my head.
Kiwi is offline   Reply With Quote
Old 03-27-2012, 08:30 AM   #7
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
How would I *want* the settings? Off and Off.
How will they likely be set if you were to catch me on a drive to work? On and On.
I tend to forget to turn stuff like that off when I start the car. But I remember to shut them off when I'm about to go hooning.
Old 03-27-2012, 08:58 AM   #8
BLikeWater
Drives: Scion tC + future FR-S
Unless having it on some how effects mpg, I don't see the point of turning it off until it's time to play. So, just normal daily driving, I'll leave mine on full.
BLikeWater is offline   Reply With Quote
Old 03-27-2012, 10:19 AM   #9
Turbowned
Turbowned's Avatar
Shut that shit off! Unless I have to turn it off every time I turn the car on, then I'll just leave it be until I decide to play around.
In overly-safety-concerned America, car drives you!
Old 03-27-2012, 10:34 AM   #10
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
You do have to turn it off every time.
I really don't understand the point of turning it off to drive to work, or the mall, or to get food, etc. Why bother? I never turned it off on the street in my S2000 and I never once had it engage either.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 03-27-2012, 10:56 AM   #11
86'd
86'd's Avatar
Drives: 2012 WRX Sedan
Everything on full for the street.
86'd is offline   Reply With Quote
Old 03-27-2012, 11:31 AM   #12
engee
Drives: Subaru
Full Power Scotty!!
But yea, keeping them on unless hooning about.
engee is offline   Reply With Quote
Old 03-27-2012, 11:57 AM   #13
Lighting Red
Habitual Line Crosser.
Lighting Red's Avatar
Drives: ^ Two of my favorite things.
Considering my current AWD coffin of a car; I am turning the TC/VSC off ASAP when I get the BRZ! I want to have some fun!
Lighting Red is offline   Reply With Quote
Old 03-27-2012, 12:09 PM   #14
Jeff_DML
Drives: 2008 M3 Sedan(last motor vehicle)
turn off everything of the track/auto-x
My previous car was a E90 m3 with the tech package and it had a M button. I had it enable MDM which is equivalent to VSC sport and would push it every time I got into the car. Might be lazy with the BRZ but guess it depends how aggressive normal VSC is.
Jeff_DML is offline   Reply With Quote
