Drives: WRB Brz / SR S14
TopHat Issue St Coilovers
Hey guys, i am currently confused on the tophat situation regarding the ST coilovers. A lot of the images are broken on the forums (thanks photobucket..) and i am having a hard time finding this information. Now, does one completely reuse the oem top hat for the STs? I have heard that people remove the lower half of it, but I am having a hard time seeing how they do so since its one piece. I have it currently installed, and the front sits a bit higher than desired. Now, i think that might just be the added height from not removing the lower perch. Does anyone have insight or images on this? thank you!
#2 |
How low are you trying to get it? You might be as low as they can go already?
#3 |
#4 |
Drives: '13 FRS - STX
I thought the front spring perch on the OE top hat was supposed to be removed and replaced with the provided spring perch that comes with the ST's, I believe that's common with KW or any other spring/damper combo that uses a differently sized spring from OE.
| The Following User Says Thank You to strat61caster For This Useful Post: | wparsons (08-07-2017) |
#5 | |
Sent from my Pixel using Tapatalk |
#6 | |
About 2:50 into this video they describe the top hat swap, looks like there's some awkward hardware going on, idk. http://www.ft86club.com/forums/showthread.php?t=30968 http://www.ft86club.com/forums/showp...&postcount=183
#7 | |
#8 |
If you're not going to use the OEM upper spring perch (and we do not as you can see in strat61caster's picture of our RCE coilovers), then I would highly recommend using the OEM conical washer.
Details in our instructions here: http://racecompengineering.com/instr...structions.pdf Our RCE coilovers are made by KW so instructions are similar for your STs. - Andrew Last edited by Racecomp Engineering; 08-07-2017 at 12:38 PM. |
| The Following User Says Thank You to Racecomp Engineering For This Useful Post: | drew_kar (08-07-2017) |
#9 | |
It looks like you meant the upper spring seat that's attached to the OEM upper mount? If that's the case, you definitely want to remove it.
| The Following User Says Thank You to wparsons For This Useful Post: | drew_kar (08-07-2017) |
#10 | |
#11 | |
(this is all about the front top hats, the rear top hats absolutely have the spring perch integrated into the top hat and is unchangeable) |
#12 | |
| FS MA: RCE Tarmac 2 with OEM tophat, $1650 | dreamwonder | Brakes, Suspension, Chassis | 8 | 08-09-2016 07:43 AM |
| FS SOCAL - OEM STRUTS SPRINGS TOPHAT | JGalp | Brakes, Suspension, Chassis | 11 | 04-10-2016 11:27 AM |
| Front camber from LCA, hub and tophat | Manji | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 02-24-2015 05:10 PM |
| Issue with BC BR extreme low coilovers | 86TruenoFRS | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 08-17-2013 09:27 AM |
| Stance coilovers lowering issue | Dispect | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 08-06-2013 11:05 PM |
