#15 |
Drives: red 2014 FR-S
or this...
| The Following User Says Thank You to fx1mark For This Useful Post: | funwheeldrive (08-03-2017) |
#16 |
Drives: 2 Subarus and a 2013 FRS
Rubbermaid makes a similar product for less than half that price, for those interested. I bought some (didn't know these existed). Got them on Amazon, and cut the tags off with a razor blade when the arrived to make them look cleaner. Work great.
I didn't have the rub noise, just wanted the pads. |
#17 |
Drives: '13 BRZ
Thank you all for the replies!
The booster seat product is a good idea, but looks like butt. I have read up extensively on the Emdom pads, but when those are installed, the belt doesn't easily pass through the pad. The result is that the belts don't retract into the B-pillars, they just flop around when you unbuckle. I think I would find that annoying too. A swap to BRZ Premium or FRS straps would be ideal, but it's not a direct plug-and-play. I think a cloth cover for the leather retaining strap itself would be ideal, but nobody makes one! |
#18 | |
LMGTFY
Drives: 13 FRS, 91 Miata
LOLWUT? If that's the case then there's something else wrong with those peoples belts, I've never had a problem with mine retracting. |
#19 |
Drives: '13 BRZ
Is your Emdom pad looped into the seatbelt retaining strap on the seatback? Others have reported that when it is, the belt doesn't easily retract through the Emdom pad. Maybe they have theirs too tightly secured around the belt. Either way, it's not the ideal product for me. An Alcantera sleeve to fit over the seatbelt retaining strap would be great.
#20 | |
LMGTFY
I'm guessing its the latter for those people. Alcantara all the way. If you cant find one, I'm sure you could get someone to make it. |
#21 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
No issues either; mine just slides right through.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
#22 |
Drives: 13 BRZ, 17 Focus RS
This has been bugging me for 20k miles. Surprised this is the first I've seen talk of it. I usually move the strap around twisting it on the snap to eliminate some of the noise. Haven't found a better solution yet.
| Noisy MCS Shocks | Kuro86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 08-30-2018 09:28 AM |
| Noisy a/c vent? | StraightOuttaCanadaEh | Issues | Warranty | Recalls / TSB | 19 | 03-20-2017 01:14 PM |
| Noisy throw out bearing | jp_r6 | Issues | Warranty | Recalls / TSB | 23 | 08-18-2016 04:45 AM |
| Anyone else got a noisy ECU? | ft_sjo | Issues | Warranty | Recalls / TSB | 11 | 04-16-2013 09:03 AM |
| Engine is quite noisy | Rob_g | Issues | Warranty | Recalls / TSB | 9 | 10-14-2012 08:41 AM |
