Old 08-03-2017, 02:10 PM   #1
tobin
tobin's Avatar
Drives: '13 BRZ
Solution to noisy seatbelt?
Hello,
I have been passively trying to come up with a solution for a minor annoyance for a couple of years, and have all but given up. When driving, the seatbelt fabric rubs against the leather retaining strap on the seat back, which produces a nearly constant, annoying squeak-type noise.
I have tried unstrapping the belt, but then it rides too high up my neck. I have tried wrapping a piece of fabric around the strap, but it looks ugly. I even asked an upholstery shop to make me a fabric sleeve to slide over the strap (they agreed, but never called me back).
Has anyone else found a solution to this?
tobin is offline   Reply With Quote
Old 08-03-2017, 02:13 PM   #2
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Turn the music up.
Lol but I agree, the noise is annoying. In for solutions.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
tobin (08-03-2017)
Old 08-03-2017, 02:33 PM   #3
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Huh, this is the first time hearing this problem. I don't remember seat belt making a noise from rubbing the strap. Do you move your upper body that much while driving that causes the seat belt to make a noise?
Old 08-03-2017, 02:46 PM   #4
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I know exactly what your talking about. I have yet to find a decent solution also. You can try adjusting how the seat is angled which can help. I've thought about taking super fine sand paper and working the inner part of the strap but I've been reluctant to do so. My solution as of now is buy an aftermarket exhaust which turned my frown upside down but didn't really solve anything just mask it. If it really bothers you best bet is probably find some sort of fabric like you tried and adhere it to that strap, or cut a seatbelt cushion thing and fit it inside that strap.
DandoX is offline   Reply With Quote
Old 08-03-2017, 03:08 PM   #5
OND
OND's Avatar
Drives: 2023 BRZ
Go to a junkyard and get the retaining straps from a Premium BRZ?
OND is offline   Reply With Quote
Old 08-03-2017, 03:11 PM   #6
churchx
churchx's Avatar
Drives: 2014 GT86
I guess it might be related to people of specific body proportions / for seat & it's back being adjusted at specific position, thus for some it might be annoying issue - for others - never experienced one. Luckily i'm in 2nd camp.
Old 08-03-2017, 03:16 PM   #7
JD001
JD001's Avatar
Drives: Subaru BRZ
I have retaining straps.. they are unfastened sitting there on the shoulder of the seats looking forlorn..
Old 08-03-2017, 03:29 PM   #8
Chimera
Drives: FRS
I'm like.. 85% sure my straps are cloth, not leather.
Old 08-03-2017, 03:53 PM   #9
Williampreza
Williampreza's Avatar
Drives: 2017 Ice Silver BRZ Limited
I had a related problem with the seatbelt rubbing my neck. I used a strap that's meant to adjust the height of the shoulder belt for a booster seat. It's a black strap with a loop on one end and an adjustable buckle on the other. You attach the loop to the loop on the seat folding mechanism, then clip the buckle on your shoulder belt. The strap length is adjustable, try pulling it snug against the seat and see if that helps. The strap comes with Graco booster seats.
Williampreza is offline   Reply With Quote
The Following User Says Thank You to Williampreza For This Useful Post:
bcj (08-05-2017)
Old 08-03-2017, 03:55 PM   #10
JD001
JD001's Avatar
Drives: Subaru BRZ
The straps on my seats match the leather but I doubt that they're leather, most likely faux leather.
Old 08-03-2017, 04:05 PM   #11
Teseo
Drives: frs
Yes, make a squeaky sound like a dog toy, i ended using black tape to cover the cables
Old 08-03-2017, 04:52 PM   #12
8RZ
The Gunshine State
8RZ's Avatar
"Pleather" squeaks.
Current DD: M235i
Old 08-03-2017, 05:27 PM   #13
funwheeldrive
What about these?
The Following User Says Thank You to funwheeldrive For This Useful Post:
x808drifter (08-03-2017)
Old 08-03-2017, 07:15 PM   #14
x808drifter
LMGTFY
x808drifter's Avatar
Drives: 13 FRS, 91 Miata
What about these?
Beat me to it.
The Following User Says Thank You to x808drifter For This Useful Post:
funwheeldrive (08-03-2017)
Noisy MCS Shocks Kuro86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 08-30-2018 09:28 AM
Noisy a/c vent? StraightOuttaCanadaEh Issues | Warranty | Recalls / TSB 19 03-20-2017 01:14 PM
Noisy throw out bearing jp_r6 Issues | Warranty | Recalls / TSB 23 08-18-2016 04:45 AM
Anyone else got a noisy ECU? ft_sjo Issues | Warranty | Recalls / TSB 11 04-16-2013 09:03 AM
Engine is quite noisy Rob_g Issues | Warranty | Recalls / TSB 9 10-14-2012 08:41 AM
