Old 08-01-2017, 03:39 AM   #1
FR-Sky
FR-Sky's Avatar
Drives: 2013 FR-S 10 series [755]
unknown knocking/clunking sound, whatever you call it....
So, it happened couple days to last weeks ago, I can hear the knocking sound/clucking sound in front of the vehicle. It happens when going low speed, and hitting some small bump or little bit bigger bumps. No sound on the high way. So I check the front suspension today, nothing were loose, sway bar, endlinks, coilover, etc....and I have tighten it again, and the sounds still happens.
I have Tein Flex Z,
Whiteline sway bar,
Whiteline endlink,
Any ideas?
FR-Sky is offline   Reply With Quote
Old 08-01-2017, 09:42 AM   #2
BRZ@SGP
Drives: BRZ MY17
Had it. It clunk at low speed while steering. Wasted days googling for solution. Sent to dealer under warranty. Solved it in 1.5 days. They refuse to tell me what went wrong by giving a lame reply ... like something loose
BRZ@SGP is offline   Reply With Quote
The Following User Says Thank You to BRZ@SGP For This Useful Post:
FR-Sky (08-01-2017)
Old 08-01-2017, 10:15 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
coilover's top nut (and hence clunking in loose ball bearing)?
FR-Sky (08-01-2017)
Old 08-01-2017, 10:37 AM   #4
15limited
15limited's Avatar
I have Tein Flex Z,
Whiteline sway bar,
Whiteline endlink,
Any ideas?
How low do you have your Flex Z's adjusted? The endlinks that came with the adjustable swaybar (both whiteline) we're too long and the swaybar was bottoming out on the front LCA, even using Fortune Autos shortened endlinks I still couldn't clear the control arm :/
Sent from my 2PQ93 using Tapatalk
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
The Following User Says Thank You to 15limited For This Useful Post:
FR-Sky (08-01-2017)
Old 08-01-2017, 10:42 AM   #5
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
A few things it could be:
1) Lug nuts need to be re-torqued. I know it sounds dumb, because you'd figure you couldn't be so absentminded as to forget to retorque them, but it was what was causing the same clunking for me for a bit. lol
2) Check the stabilizer link nuts, they might also need to be tightened.
3) Could be the shock nut as @churchx mentioned
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
FR-Sky (08-01-2017)
Old 08-01-2017, 11:57 AM   #6
FR-Sky
FR-Sky's Avatar
I dont think so, the knocking/clunking sound happens during low speed, and when hitting bumps. I checked top nut, it was fine.
[ame="https://www.youtube.com/watch?v=YvKWGjmPKoc"]How to Check a Wheel Bearing (Sound, play in the wheel, ABS light) - YouTube[/ame]
The sound is not similar to this, but might be tho.
Old 08-01-2017, 11:59 AM   #7
FR-Sky
FR-Sky's Avatar
little bit less than 1 finger gap.
I used fortune auto before, between 1.5-2 fingers, and it was fine.
Old 08-01-2017, 12:02 PM   #8
FR-Sky
FR-Sky's Avatar
1) Checked, and re-torqued, problem still persist.
2) Checked, and re-tightened, problem still persist.
3) Checked, and re-tightened, problem still persist.
so frustrating.....sigh
The Following User Says Thank You to FR-Sky For This Useful Post:
Shark_Bait88 (08-01-2017)
Old 08-01-2017, 12:27 PM   #9
Jasonbot
Jasonbot's Avatar
Drives: scion FRS
It could be coil bind. Usually happens at low speeds and when doing slow turns. Check the collars on the coils.
Jasonbot is offline   Reply With Quote
The Following User Says Thank You to Jasonbot For This Useful Post:
FR-Sky (08-01-2017)
Old 08-01-2017, 12:35 PM   #10
VIP BRZ
VIP BRZ's Avatar
Drives: 2014 Subaru BRZ
$100 says its this
http://www.ft86club.com/forums/showthread.php?t=117073
VIP BRZ is offline   Reply With Quote
The Following User Says Thank You to VIP BRZ For This Useful Post:
FR-Sky (08-01-2017)
Old 08-01-2017, 12:38 PM   #11
7c8
I'm sure I have the same sounds as you with my Bilstein B14 + Raceseng CasCam plates. Only at low speeds and it comes and goes. Usually it gets more frequent the longer I drive or the warmer the weather which hints me at bushings or ball joints. I haven't been able to pin this down, but it is definitely not the swaybar bushings or endlinks, which I originally thought it was. I can rule them out because I've disconnected the swaybars already and the sound was still there.
7c8 is offline   Reply With Quote
The Following User Says Thank You to 7c8 For This Useful Post:
FR-Sky (08-01-2017)
Old 08-01-2017, 12:59 PM   #12
FR-Sky
FR-Sky's Avatar
Originally Posted by VIP BRZ View Post
Checked yesterday, endlink, swaybar, coilover were fine and re-tighten..
Beside, I had the coilover for half years...and it just happened recently...
Thx for the $100...lol jk.
Old 08-01-2017, 01:01 PM   #13
FR-Sky
FR-Sky's Avatar
Yea, I checked and re-tighten everything and I am quite sure it is not the sway bar/endlinks, etc. I ll check it again, and if I still can't find the problem then I have no choice to find a mechanic =[
Old 08-01-2017, 02:48 PM   #14
7c8
It's quite frustrating. I'm dying to know what it is, so please keep us updated if you find out!
FR-Sky (08-01-2017)
Knocking sound Moe23 Issues | Warranty | Recalls / TSB 80 04-18-2019 09:09 PM
knocking sound wingrider Engine, Exhaust, Transmission 12 08-22-2016 01:35 AM
Knocking sound from AC? DCdesign2000 Issues | Warranty | Recalls / TSB 2 09-25-2015 10:09 PM
Clunking sound coming from suspension Maverickgear Issues | Warranty | Recalls / TSB 9 07-11-2014 03:41 PM
Neutral to 1st clunking sound wallace03 Issues | Warranty | Recalls / TSB 3 01-10-2013 10:50 PM
