#43 | |
I understand that most auto dealerships would choose to replace transmissions, rather than to rebuild them ...... ![]() humfrz |
#44 |
Last time I took my car to the dealership was because the TOB was going out, and I mentioned the grinding noise to the service guy, he ended up telling me they couldn't replicate the sound and I left it at that.
#45 |
So I left the car at the dealership and they said maybe the grinding at low rpms was caused by a bad clutch 🤔
#46 |
This specific low rpm "grinding," is this when shifting into gear, or is it just rolling on the throttle?
#47 | |
Drives: '13 FR-S - Hot Lava
They did, but they also took it for a drive to confirm the problem. |
#48 | |
Rebuilding a manual transmission is not rocket science ....... even ol humfrz has done that ..... back-in-the-day........ ![]() humfrz |
#49 | |
| The Following User Says Thank You to xZAMx For This Useful Post: | humfrz (07-31-2017) |
#50 |
Dealer called and said I have a bad transmission and that they'll replace it
#51 |
#52 | |
That's not grind. That's gearbox rattle from the engine lugging.
#53 | |
Synchros going bad?
I didn't get to check transmission fluid. So I'm driving the wrong way? The car didn't make that sound before the TOB was replaced though, it started AFTER it was replaced. If I want to avoid that grinding/rattling sound I have to get it up to 2.5k-3k rpms before releasing the clutch. Before the TOB was replaced I used to get it to 1.5k and slowly release the clutch. Oh and this is from neutral to 1st we're talking. |
#54 | |
In other words ....... I suggest (again) that you check the transmission oil level ....... get it .....?? ![]() humfrz |
| The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (07-31-2017) |
#55 |
I'm not sure of anything at this point. I see what you mean about starting out in first. Maybe it's clutch chatter?
Like humfrz said. Have the fluid checked. Show them the grind/chatter. Do that first. After that, if you can make/post a recording, I'd be glad to give it a listen. Beats spitting into the wind. edit: oh, I see you posted earlier. New transmission. Good.
#56 | |
Here's the rattle I'm talking about It's a video a recorded but the sound isn't that good. |
| Synchros finally starting to die? | Bushhy | Engine, Exhaust, Transmission | 6 | 12-09-2016 11:22 AM |
| Synchros problem? | FRiSson | Issues | Warranty | Recalls / TSB | 191 | 06-21-2016 04:27 PM |
| Are My Synchros Going Out? | Scavanger | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 11-20-2014 12:29 AM |
| Swap out OEM clutch, OEM synchros/gearbox | brzadmir | Engine, Exhaust, Transmission | 19 | 05-04-2013 03:13 PM |
| Synchros followup | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 08-31-2012 02:38 PM |
