Avid searcher of things
Drives: Scion Fr-s 10 series
Are My Synchros Going Out?
So on a cold temp start I have issues getting it into any gear. First time I have had this car in the "winter" months of Texas so I didn't have this issue before. It goes into gear just fine after I finally get it into a gear to where I can move, but before that it just feels like it is stuck. I have a little over 20k miles on my car and haven't grinded any of the gears, but I do drive it pretty hard (after its warm of course). So my question is could it be the synchros or the actual clutch?
As long as it frees up after you have drove a bit then there is no problem. Almost any standard will be a bit tough to shift when really cold. The oil just thickens up and needs to warm to flow properly. This has happened every winter, on every one of the 20 or so standards I have owned and has never resulted in damage.
Just double clutch and let it warm up and you will get used to it.
Drives: White GT86
It's just because it's colder. The oil is thicker so it's a little more difficult to shift from gear to gear. Just be gentle and don't force anything and the gear will engage. You can also try selecting neutral, raise the clutch, then depress the clutch and try again. Usually that'll smooth everything out.
You can also try changing the transmission oil, there's plenty of recommendations on the forum for oil that provide smooth shifting even when cold. |
#4 | |
OK, so now let's see just how many people give the exact same answer even though it is here twice already.
#5 | |
Drives: White GT86
But you got there first just about, so I guess +1 Internet Point for you? Congrats etc. |
Flanders being hostile today
As long as it frees up after you have drove a bit then there is no problem. Almost any standard will be a bit tough to shift when really cold. The oil just thickens up and needs to warm to flow properly. This has happened every winter, on every one of the 20 or so standards I have owned and has never resulted in damage. Just double clutch and let it warm up and you will get used to it.
Drives: 2013 Firestorm FRS
double clutching will help. @Tcoat
I didnt watch the video, but the thumbnail looked like he knew what he was talking about [ame="http://www.youtube.com/watch?v=zy0BfG_CG2Y"]What happens in the transmission when you double clutch / Heel Toe Downshift??? - YouTube[/ame] |
#9 | |
Actually you would win by several hours if we take the time zones into account. The follow up was for the next 100 people that were not typing at the same time as we were and will say it all again anyway.
#10 |
Nah you will know without a doubt if hostile!
#11 | |
#12 | |
![]() What day is this ...... ![]() humfrz |
| Synchros problem? | FRiSson | Issues | Warranty | Recalls / TSB | 191 | 06-21-2016 04:27 PM |
| Swap out OEM clutch, OEM synchros/gearbox | brzadmir | Engine, Exhaust, Transmission | 19 | 05-04-2013 03:13 PM |
| Synchros followup | FRiSson | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 08-31-2012 02:38 PM |
