Old 07-20-2017, 05:39 PM   #1
Terruko
Terruko's Avatar
Synchros going bad?
Sometimes when changing from 4th to 5th the shifter gets stuck and doesn't want to move, and when I force it it makes a loud grinding noise.
Are synchros considered wear items? I'll take it to the dealership tomorrow.
Terruko is offline   Reply With Quote
Old 07-20-2017, 05:41 PM   #2
ggiddix
Drives: scion frs
Well it's not covered by warranty if that's what your asking
Sent from my XT1650 using Tapatalk
ggiddix is offline   Reply With Quote
Old 07-20-2017, 05:50 PM   #3
Terruko
Terruko's Avatar
Doesn't it fall under powertrain warranty though? I have powertrain warranty until 100k miles.
Old 07-20-2017, 05:52 PM   #4
ggiddix
Drives: scion frs
If you can prove that it was defective then maybe, but they will just say you abused the clutch or grinded the gears and then won't cover it
Old 07-20-2017, 06:30 PM   #5
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
I'd leave that part out when I explain the problem to the dealer.
PetrolioBenzina is offline   Reply With Quote
Old 07-20-2017, 07:12 PM   #6
Shinigami301
Slow driver, fast biker.
Shinigami301's Avatar
Drives: '16 86, '00 Celica GTS, Sportbikes
Does it still do it when you double-clutch? Are you trying to power shift? Or speed-shift?
Shinigami301 is offline   Reply With Quote
Old 07-20-2017, 07:18 PM   #7
Terruko
Terruko's Avatar
Yeah and no, just normal driving. It doesn't happen all the time though, just every now and then, but today it happened when I went from 1th to 2nd, and sometimes it doesn't want to go on 1th either. I'm taking it to the dealership tomorrow because my frs has been making a rattle noise when I'm on first and under 1.5k rpms, it started after I got my TOB replaced.
Old 07-20-2017, 07:48 PM   #8
gravitylover
^^ Sounds like something is misaligned. The clue is that it started after the tob was replaced. Hopefully that hasn't caused undue wear on other parts.
Old 07-20-2017, 07:57 PM   #9
humfrz
I'll ask an obvious question ....... then refer you to @Ultramaroon
Do you have a short shifter installed .. ??
humfrz
Old 07-20-2017, 09:01 PM   #10
Terruko
Terruko's Avatar
humfrz
No. Everything is stock on this car.
Old 07-20-2017, 09:21 PM   #11
Teseo
Drives: frs
Firs change fluid, drive for a while. Also at what rpms you are shifting?
Old 07-20-2017, 09:28 PM   #12
humfrz
Good point!
However, first off ...... check the fluid level to make sure the folks that installed the new TOB put oil back in the transmission........
humfrz
Old 07-20-2017, 09:56 PM   #13
Ultramaroon
not playing cards
Ultramaroon's Avatar
***How many miles after your TOB replacement now?
Rattling noise at low RPM may or may not be normal. By itself I would say nothing wrong. Factory gear lube is super thick in an effort to keep it quiet.
If the transmission was under-filled That would make shifting more notchy and picky, especially after it gets hot.
I'm not an expert with dealer service interaction and I'm suspicious of other peoples' work. That said, If you have any intention of following up with a warranty claim, do... not... touch... anything.
Old 07-20-2017, 10:11 PM   #14
Terruko
Terruko's Avatar
2.8k-3k
Synchros finally starting to die? Bushhy Engine, Exhaust, Transmission 6 12-09-2016 11:22 AM
Synchros problem? FRiSson Issues | Warranty | Recalls / TSB 191 06-21-2016 04:27 PM
Are My Synchros Going Out? Scavanger Scion FR-S / Toyota 86 GT86 General Forum 11 11-20-2014 12:29 AM
Swap out OEM clutch, OEM synchros/gearbox brzadmir Engine, Exhaust, Transmission 19 05-04-2013 03:13 PM
Synchros followup FRiSson Scion FR-S / Toyota 86 GT86 General Forum 7 08-31-2012 02:38 PM
