Old 07-13-2017, 07:03 PM   #449
cwvisual
cwvisual's Avatar
Drives: 2014 Scion FR-S Monogram
Originally Posted by pancake View Post
I've got the Berk muffler delete, and i've been wanting a catless UEL.
How does the sound compare? Did it add a lot of rasp?
Was drone reduced?
It’s much louder and “growly”. Definitely a more aggressive sound. I don’t think it’s very raspy at all.
Drone is worse because you are losing a cat. It’s not unbearable though. I actually drive without music a lot now and just listen to the car lol.
I will tell you though, it does sound a lot different in the cabin than it does outside the car. So don’t be fooled, you will be really happy once you hear it outside the car. Really makes the engine sing!
cwvisual is offline   Reply With Quote
Old 07-13-2017, 07:05 PM   #450
Stuvven
Drives: 2013 Subaru BRZ
Originally Posted by cwvisual View Post
If you are changing the “in gear” table it won’t pop in neutral, only while driving above the speed threshold. If you want it to pop in neutral simply make the same changes to the neutral table.
Thanks!
Stuvven is offline   Reply With Quote
Old 07-23-2017, 12:51 AM   #451
Minsekt
Minsekt's Avatar
Drives: GT86
is it possible to simulate the amg up shift crackle somehow?
Minsekt is offline   Reply With Quote
The Following User Says Thank You to Minsekt For This Useful Post:
radroach (07-26-2017)
Old 07-25-2017, 10:31 PM   #452
cwvisual
cwvisual's Avatar
So I just got the rest of my cats taken out, and I still have the stock resonator. The rest is straight piped, but I’m still not getting any flames, even on the super loud bangs. Any idea as to why? Probably going to add another resonator anyway to bring the volume down, I’d just like to see some flames for shits and giggles.
Old 07-26-2017, 12:12 AM   #453
steve99
Drives: FT86
you can try this, just look where the retard is. It might not work as you need fuel for pops and during shifts injectors shut off. but thier might just be enough residual fuel to get a couple of pops. It might make the off/on throttle a bit jerky if so reduce the number of cels with retard in the higher load/rpm ranges
will probably work on slower upshift but not on fast upshifting
Old 07-26-2017, 10:24 AM   #454
majixmatrix
BRZ Wannabee
majixmatrix's Avatar
Drives: 2013 Limited BRZ
I tried this.....gave me some horrible crank shaft CEL. I was scared shitless but I reflashed to a map I thankfully had without the pops and it's been fine since. Additionally the throttle response is so much better without the pops, it's just not worth it.
majixmatrix is offline   Reply With Quote
Old 07-26-2017, 10:34 AM   #455
Detroiter
Detroiter's Avatar
I very much doubt that if you changed the right tables that it would cause a crank shaft CEL. What code did it show you had? If you had adjusted all the right tables then I'm willing to bet the same CEL will show up again soon. When you flash the ecu it clears all codes so that would remove it for some time until it is triggered again.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
Old 07-31-2017, 10:06 AM   #456
Takumi788
JHerbert Racing
Takumi788's Avatar
Drives: 2013 Scion FRS
I was making a few tweaks to my tune when I came across this mod. At first I thought this isn't my type of thing but I adjusted Base Timing B as in the first post and it's actually quite entertaining. lol. With my setup it's a pretty tame burble on decel. I dig it. Good work.
- #813 2013 Scion FRS Build Thread
- JHerbert Racing Website
Takumi788 is offline   Reply With Quote
Old 07-31-2017, 10:42 AM   #457
Soloside
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
This should be do-able with the Automatic tranny as well correct?
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside
Soloside is offline   Reply With Quote
Old 08-01-2017, 05:40 AM   #458
Minsekt
Minsekt's Avatar
Drives: GT86
yes, works without problems. works best in manual mode tho. you can basically turn it off if youre in auto/sport mode.
Old 08-06-2017, 02:11 AM   #459
22mraustin
22mraustin's Avatar
Drives: Scion FR-S
This is my current setup with the custom tune. I've had it for about a year or so and it's been perfect for me, still getting 400 miles on a full tank and my setup is
Borla uel catless headers
Invidia OP
Invidia catless FP
Invidia N1
Video is dark but you can see the flames, if I down shift up to the 2500k range it will pop and backfire.
2013 Scion FR-S
Tennessee
22mraustin is offline   Reply With Quote
The Following User Says Thank You to 22mraustin For This Useful Post:
eddieflyinv (08-08-2017)
Old 08-07-2017, 09:58 AM   #460
Kicknwing
Drives: 2014 frs
Invidia OP
Invidia catless FP
Invidia N1
2013 Scion FR-S
Tennessee
did you just do what the op said to change?
Kicknwing is offline   Reply With Quote
Old 08-07-2017, 12:05 PM   #461
22mraustin
22mraustin's Avatar
Drives: Scion FR-S
No, when I had the setup it was little baby pops and crackles, and I didn't like it that much, the one I currently have I feel is more louder pops, if I remember I think it's the tune someone did on this thread with a yellow series frs
2013 Scion FR-S
Tennessee
Old 08-07-2017, 12:13 PM   #462
22mraustin
22mraustin's Avatar
Drives: Scion FR-S
2013 Scion FR-S
Tennessee
2013 Scion FR-S
Tennessee
rom tuning for pops and backfires andrew5826 Software Tuning 110 12-23-2016 04:39 AM
First romraider defs are up jamesm Software Tuning 95 01-13-2015 05:29 AM
Transient Ignition Retard Tables from RomRaider Ralph Spoilsport Issues | Warranty | Recalls / TSB 31 05-24-2014 07:48 AM
OFT-Help with Romraider/FFS and Launch Control-issues continuecrushing Software Tuning 9 04-17-2014 11:07 PM
Possible backfires Bg8780 Engine, Exhaust, Transmission 0 05-22-2013 02:12 PM
