Old 07-22-2017, 03:51 PM   #729
wutsaiu
wutsaiu's Avatar
Drives: 2015 Raven V8
Originally Posted by wooly35 View Post
I'm not running an oil cooler and my oil pressure at hot idle is around 30psi. Although I don't have my temp gauge in yet, so I cant really compare just yet. An oil cooler is always a good thing to have in 100+ heat outside tho. lol
Just for comparison I'm getting 32-35psi hot idle on street.
After a few laps on the track my idle was 20psi.
Went back to normal after it cooled down.
I have no oil cooler either.
wutsaiu is offline   Reply With Quote
Old 07-24-2017, 10:29 AM   #730
DustinS
DustinS's Avatar
Drives: 2013 Ultramarine FR-S
Going to jump to a 10w-40 on recommendation from the TSP. If that doesn't do it 15w-50 and really be mindful of the oil temp before I really drive the car. Oil cooler is high on the list, but being front sump the set-ups become real expensive. Currently trying to put a kit together that I am absolutely sure I like. Still a necessary item. Will get one ASAP.
Edit:
Old 07-24-2017, 04:59 PM   #731
all4spl
So I may need to hop on this swap sooner than I thought. I have some rod knock on my factory stock engine. Would you recommend the vorshalg mounts or go to a different solution? I have an LS6 with a T56 Camaro trans. Don't have the fancy transmission you guys have.
all4spl is offline   Reply With Quote
Old 07-24-2017, 05:36 PM   #732
MRS-Colin
Drives: 2001 Impreza 2.5 RS
Secret is that T56 = Magnum.
Magnum is just the aftermarket name. There are surely some other differences like tail section length and skip shift / CAGS, but they are pretty much the same box.
Colin Beck
MRS-Colin is offline   Reply With Quote
Old 07-24-2017, 05:50 PM   #733
DustinS
DustinS's Avatar
One supplied by Vorshlag is the XL which has a longer tail housing and shifter moved back. The mount also sits back further as well. I am not exactly sure how far back though.
Vorshlag Mounts work with the XL, CX Racing Mounts were designed with the Normal T56. Should work with minor modifications either way you go.
Old 07-27-2017, 10:35 AM   #734
DustinS
DustinS's Avatar
Definitely think something is wrong. Or I was spinning extremely bad (though no one said they really saw me spin or anything)
Playing with a friend making ~460whp in a 350z. He was almost pulling me...
Old 07-27-2017, 11:54 AM   #735
all4spl
time to warranty that engine.
Old 07-27-2017, 09:58 PM   #736
wooly35
Drives: 2014 Scion FR-S LS3
Weird. Have you fabricated the new intake yet? Wonder how much that will help getting the intake to some cooler air, not to mention away from the fans as they turn on. I'm working on a CAI this weekend. Hopefully it will help with the intense heat soak and have harder pulls when sitting at idle for a long period of time.
2014 scion FR-LS3 lol
wooly35 is offline   Reply With Quote
Old 07-27-2017, 11:07 PM   #737
wutsaiu
wutsaiu's Avatar
This is a good point. I know GM/Chevrolet ECU pulls a lot of timing when air temps get high. I was seeing crazy high air temps before I made a CAI of sorts.
Old 07-31-2017, 04:54 PM   #738
DustinS
DustinS's Avatar
Front Sway Bar issues.
[ame="http://youtu.be/2QVkV5rQNAU"]http://youtu.be/2QVkV5rQNAU[/ame]
The Following 4 Users Say Thank You to DustinS For This Useful Post:
cf6mech (08-02-2017), gtpvette (08-01-2017), wutsaiu (08-01-2017), Zer0 (07-31-2017)
Old 08-01-2017, 10:23 AM   #739
wutsaiu
wutsaiu's Avatar
This is why I've had no sway bar for over two years now.
Still waiting for someone to have a good solution or product to buy.
The Following User Says Thank You to wutsaiu For This Useful Post:
Old 08-01-2017, 10:51 AM   #740
gtpvette
Drives: 2015 FRS - FFR GTM
Do you think one of sheet metal oil pans might give you enough room?? I.E. Sikky's or Moroso's
2015 FR-S - One Day I'll Finish The Swap
gtpvette is offline   Reply With Quote
Old 08-01-2017, 12:17 PM   #741
Corley
Drives: 2014 Stock frs
From what I have seen. Pans like that have the fittings coming down straight out of the pan rail which happens to interfere with the steering rack. I am currently trying to figure mine out. I have cx racing pan (I know). It clears the sway bar, no lower support for the trans yet.. But no way to hook up to the fittings.
Perhaps dry sump is just the way to go..
Corley is offline   Reply With Quote
Old 08-01-2017, 12:34 PM   #742
DustinS
DustinS's Avatar
Going to pay out the A** for the fittings though. The Hose is also $11 a foot.
Fragola Straight Banjo Hose End - Verocious Motorsports
Dry Sump would be an even bigger mess honestly. Also a huge investment. Unless you have the expendable budget, then it's totally worth it. You are just looking at $6-$7000 and still might have clearance issues.
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions Dezoris Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 06-06-2017 11:54 PM
Ls or 2jz swap? sgoldberg01 BRZ First-Gen (2012+) — General Topics 13 03-22-2016 04:07 PM
Rod Swap protpibe Engine, Exhaust, Transmission 6 10-22-2015 12:38 AM
AT-->MT swap AlwaysSideways Want-To-Buy Requests 3 12-15-2014 12:14 PM
Should I swap? michaelahess BRZ First-Gen (2012+) — General Topics 8 06-12-2012 08:32 PM
