Old 07-20-2017, 01:39 PM   #15
kch
Senior Misanthrope
kch's Avatar
Seriously. You need separate street pads and track pads.
Old 07-20-2017, 01:41 PM   #16
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
Originally Posted by RJasonKlein
those Project Mu Racing999 are pretty expensive and look like they are rated for 200-800. Seems like they'd eat rotors when cold and fade quicker than the R6 or W3 would.
You're right, they are expensive and rotor wear is high, but pad wear is good and rotors are cheap on these cars. I don't know your skill level or how your car is set up, but the maximum operating temperature of these pads is 800°C and their performance as that temperature is reached is exceptional.
@CSG Mike, you and I have spoken about these pads extensively - can you weigh in on their performance and your personal experience with them?
Last edited by RJasonKlein; 07-20-2017 at 02:07 PM. Reason: Corrected a typographical error.
RJasonKlein is offline   Reply With Quote
Old 07-20-2017, 01:49 PM   #17
wparsons
wparsons's Avatar
Originally Posted by MassTroy View Post
@wparsons I might consider doing the R8 instead of the R6. But it says its min temp is 74F as opposed to 0F. The R6 still looks like it is more fade resistant than the HP+.
You'll be hard pressed to find rotor temps under 74F in the summer in the continental US or southern Canada...
@RJasonKlein those Project Mu Racing999 are pretty expensive and look like they are rated for 200-800. Seems like they'd eat rotors when cold and fade quicker than the R6 or W3 would.
R6 is 1000F, the 999's are 800C (~1500F). The ClubRacer's are also a great pad, and work fine on the street in the summer. I prefer the feel of the ClubRacer's (less compressible) to the R10's, but both have similar heat ranges and are equally capable on the street and track.
flickr
RJasonKlein (07-20-2017)
Old 07-20-2017, 02:07 PM   #18
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Sort of a noob question but at what point do you make the call to resurface the rotors? How worn does it need to be?
DandoX is offline   Reply With Quote
Old 07-20-2017, 02:19 PM   #19
ZDan
ZDan's Avatar
Drives: '23 BRZ
I never resurface rotors. I replace them before they get to minimum thickness.
The Following 8 Users Say Thank You to ZDan For This Useful Post:
CSG Mike (07-20-2017), DandoX (07-20-2017), DylanJZA (01-24-2023), JazzleSAURUS (07-21-2017), Racecomp Engineering (07-20-2017), strat61caster (07-20-2017), Tristor (03-29-2018), wparsons (07-20-2017)
Old 07-20-2017, 02:24 PM   #20
Icecreamtruk
Drives: Track preped NA FRS
Never! Use them till they crack, replace with new ones, done.
Icecreamtruk is offline   Reply With Quote
The Following 2 Users Say Thank You to Icecreamtruk For This Useful Post:
DandoX (07-20-2017), wparsons (07-20-2017)
Old 07-20-2017, 02:31 PM   #21
MassTroy
Subaru BRZ
MassTroy's Avatar
Drives: 2013 Subaru BRZ
I'm currently running RE71-Rs. But I'll be switching to RS4s or GT Radials when they wear out
MassTroy is offline   Reply With Quote
Old 07-20-2017, 02:33 PM   #22
OND
OND's Avatar
Drives: 2023 BRZ
OP, dont get too hung up on minimum temperature recommendation for the pads. None of the pads mentioned in this thread are hardcore race pads that need huge amounts of heat.
I daily XP10's which have a range of 250F-1650F and it bites stronger than OEM pads even on 40-45F days.
OND is offline   Reply With Quote
The Following 5 Users Say Thank You to OND For This Useful Post:
CSG Mike (07-20-2017), DylanJZA (01-24-2023), MassTroy (07-20-2017), strat61caster (07-20-2017), wparsons (07-20-2017)
Old 07-20-2017, 02:45 PM   #23
Icecreamtruk
I mean, if we are going to go with temp based recomendations, I would be a dead man by now, since I ran the DTC-60 pads on Canadian winters (below 0F) because I was lazy and cheap (didnt have extra pads, didnt want to swap them). They still bite more than oem pads, even on freezing temps. THe only thing, is they eat rotors more when cold, thats all, but you should be replacing rotors more often if you are tracking anyways, they will usually crack before they get too thin.
The Following 3 Users Say Thank You to Icecreamtruk For This Useful Post:
kevaughan (09-05-2022), OND (07-20-2017), wparsons (07-20-2017)
Old 07-20-2017, 02:53 PM   #24
MassTroy
Subaru BRZ
MassTroy's Avatar
Yeah, its the rotor wear when operating below temp that I'm more concerned about. I don't need maximum braking power when slowing to a stop sign. I've been getting grooves in my rotor with my Hawks. How often do you replace rotors? How many events/months of daily do you get on them?
Old 07-20-2017, 03:02 PM   #25
Icecreamtruk
With cheap blank rotors, they last anywhere from 6 to 8 track days with ducts in the front, or around 4 to 6 events without duckting. The rears seem to last forever, I change them once a year just because, but they can probably do something like 15-20 events, they wear so little. (you might have more wear if you race with nannies on, the ASC and EBD rely a lot on the rear brakes to control the car).
Old 07-20-2017, 03:06 PM   #26
MassTroy
Subaru BRZ
MassTroy's Avatar
Oh wow! Maybe I feel less bad about my rotor wear then. Not sure how long the previous owner used those rotors, but I put a dozen autocross, 5 track days, 2 road trips of aggressive mountain driving, and 15k miles of street driving on them. So I guess they lasted pretty long...
Old 07-20-2017, 03:11 PM   #27
Sideways
BRZZZZZ
Sideways's Avatar
Drives: 2013 BRZ Whiteout
Even I am in same boat as OP.
To everyone asking to run separate pads for track and street, do you change pads every time to want to go to the track. I go to track 3-4 times a year and autocross 5-6 times a year (summer is short here in Canada). I would find it very tedious to keep switching pads.
Sideways is offline   Reply With Quote
The Following User Says Thank You to Sideways For This Useful Post:
JDM4E (07-20-2017)
Old 07-20-2017, 03:21 PM   #28
swarb
It only takes like 15 minutes each corner once you get the process down. You should be inspecting the brakes/wheels/tires before and after an event anyways.
The Following 2 Users Say Thank You to swarb For This Useful Post:
brake, brake pad, counterspace, street brakes, track prep
FS: Hawk track brake pads, DTC-30 front/HP+ rear, 90% life left, best track day combo tampaSi Brakes, Suspension, Chassis 4 05-27-2017 02:31 PM
How to restore OEM brake pads after a track day? torqdork Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 09-24-2013 12:45 PM
Daily drivers, do you swap street and track brake pads? qoncept Tracking / Autocross / HPDE / Drifting 31 06-26-2013 03:50 AM
Brake pads for track days why Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 05-26-2013 06:42 PM
Track brake pads - front and rear? oofie Tracking / Autocross / HPDE / Drifting 37 05-26-2013 04:48 PM
