#379 |
Solar wind surfer
Drives: 2013 FRS
I left the idle values the way they were.
I'm using OFT's off the shelf tunes. They're 1400 for one table and around 1200 for the rest. I don't want to mess with those if they're only going to help reduce the noise by a little bit |
#380 | |
Drives: 2016 Brz Hyper Blue
Is it normal that my Cruise Control also doesnt work anymore? Is it the P050B code diisabled that does that? and is it safe for our cats since they dont heat up as much, got the second cat only Last edited by Sagz; 07-18-2017 at 05:19 PM. |
#381 | |
Drives: FT86
The maf offset adds fuel like a choke on old cars, thats why their still some higher maf offset values at the very start of the wsrmup cycle at very cold temps, these should be suffient for cold starts. Yes you will definitly need to disavle P050B on Ua and Canada tunes or you will thtow a cel code and cruise will be disabled and maybe other things. This code checks post start ignition timing |
#382 | |
#383 |
Drives: 2014 GT86
cruise control is disabled when you got CEL (but IIRC is only thing that gets limited from cat readiness check fail). Disabling that check prevents that CEL to pop up.
#384 |
Well I disabled the code from Oft, I had no CEL but still wasnt able to activate Cruise control, Maybe it was only because it was the 1st drive afther flashing the ecu?
#385 | |
Drives: FT86
If you dont have the Check engine light illuminated or the slip\trac lights are not on then their is some other problem with cruise control. Oft onlt reads engine codes so their may be a ckde in one of the other computers in car like vsc or abs computers. Try removing batt terminal fir a few mjnutes to reset all car computers, see i cruise is working then |
#386 | |
Also should I run 0 or -4 ingnition Timing and what will be the difference between both and is there more risk with one or the other? |
#387 | |
Drives: FT86
#388 |
Drives: Drives like a crab.
#389 | |
Drives: FT86
What flash device do you have ?? A01G is compatable with A00G. OFT roms will actually update you to A01G If you using tactrix just use A01G roms and def and flash A01G rom to your car instead of the A00G. |
#390 | |
To edit my roms, I use RomRaider. I can't seem to find the MAF correction tables... Could it be possible that EUDM OFT maps have less features? Thanks for the quick answer. |
#391 | |
Drives: Toyota GT86
![]() To answer your question, you need to update your definitions. Use Wayno's or Kodename47 defs, then you have all of those tables. The one's suplied with the OFT are very old.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners |
#392 | |
Drives: UK GT86
The maps don't have any less features, the definitions just determine what tables you can view. My OFT Definitions for G-Series ROMs.
.: Stealth 86 :.
| Cold start question | retrosmiths | Scion FR-S / Toyota 86 GT86 General Forum | 106 | 11-15-2016 02:14 PM |
| Cold weather knocking during start ups. | JDMenrique | Issues | Warranty | Recalls / TSB | 38 | 01-12-2015 11:53 PM |
| backfire at cold start | FreaQshoQ | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 10-16-2013 06:21 AM |
| White Smoke cold start up in Cold Weather (turbo cars) | whitefrs | Forced Induction | 17 | 09-25-2013 05:05 PM |
| Loud cold start and mpg drop since new | be6sti | Issues | Warranty | Recalls / TSB | 7 | 11-28-2012 01:35 PM |
