Old 07-13-2017, 12:20 PM   #15
alex.s
alex.s's Avatar
Drives: '17 BRZ Premium. Totaled: '16 FRS
Originally Posted by JazzleSAURUS View Post
I'd do an oil change before putting any unnecessary miles on your car.
Yep. Car is sitting in the garage until the Blackstone kit arrives and I change the oil. Been doing reading. Going with redline 0w20 I think.
Sent from my Nexus 5X using Tapatalk
alex.s is offline   Reply With Quote
Old 07-13-2017, 03:23 PM   #16
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
I would think changing to at least a 0W30 synthetic oil for track duty in Southern California makes sense - @CSG Mike, what do you guys run in your cars that see a mix of road and track use?
RJasonKlein is offline   Reply With Quote
Old 07-13-2017, 03:29 PM   #17
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
0w20 is just for fuel economy. I'm using 5w30 for ordinary road usage. A more appropriate grade for the track is 5w40.
Old 07-13-2017, 04:42 PM   #18
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
And how full do you fill it?
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
Clipdat (07-13-2017), Icecreamtruk (07-13-2017), Ultramaroon (07-14-2017)
Old 07-13-2017, 04:52 PM   #19
Icecreamtruk
Drives: Track preped NA FRS
But, which side of the dipstick you need to look at for that?
Icecreamtruk is offline   Reply With Quote
Old 07-13-2017, 04:56 PM   #20
CSG Mike
CSG Mike's Avatar
With proper oil cooling? 0W20. Boosted cars typically run a 30 weight to be safe, but no need in a NA car that has sufficient cooling.
strat61caster (07-13-2017), Teseo (07-13-2017)
Old 07-13-2017, 04:56 PM   #21
CSG Mike
CSG Mike's Avatar
No it's not. Oil weight is based on tolerances.
Old 07-13-2017, 04:58 PM   #22
Capt Spaulding
Persona Non Grata
Capt Spaulding's Avatar
Drives: '15 BRZ (WRB)
Mike, is it based on "tolerances" or "clearances?"
Slow is smooth, and smooth is fast
Capt Spaulding is offline   Reply With Quote
Old 07-13-2017, 05:59 PM   #23
alex.s
alex.s's Avatar
Oil flow rate through a fixed size passage is limited by viscosity. By going with a thicker oil you decrease the flow rate and increase pressure only at the pump which means your oil pump also is more likely to wear. Racing oils have fancy additives. Things like zddp and other shit that's way above my head. You don't just want thicker oil.
The Following User Says Thank You to alex.s For This Useful Post:
Old 07-13-2017, 07:57 PM   #24
CSG Mike
CSG Mike's Avatar
Tighter tolerance allows for tighter clearance
Jasper (04-02-2022)
Old 07-13-2017, 08:58 PM   #25
OND
OND's Avatar
Drives: 2023 BRZ
Originally Posted by Trueweltall View Post
Mobil 1, API SN 0-20W *Onset Thermal Breakdown @ 265 degrees f*
Dunno man, I bet there are some Exxon engineers who would laugh their asses off if they saw this.
I have seen multiple spun bearing threads on FT86, but none mentioned tracking on 0w20
OND is offline   Reply With Quote
The Following User Says Thank You to OND For This Useful Post:
CSG Mike (07-13-2017)
Old 07-14-2017, 03:15 AM   #26
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Tracking on a 0w20 is a joke, unless you don't care for the engine or you are doing a couple of laps. It is not so much about oil temperatures, but about oil pressure. Engine clearances are fine with a 5w40 oil. For compatibility, you can check here:
https://www.sti.jp/parts/subarubrz_z.../ST98050ST110/
and here:
https://www.sti.jp/parts/subarubrz_z.../ST98050ST060/
Old 07-14-2017, 03:30 AM   #27
alex.s
alex.s's Avatar
and here:
With an oil cooler?
Old 07-14-2017, 04:23 AM   #28
CSG Mike
CSG Mike's Avatar
and here:
Try extended 45 minute sessions in 105F (40C)+ temps.
I've not had any issues yet, and I'm pretty sure my 2017 has more track miles on in than most cars see in their lifetime...
I assume you read Japanese.
パフォーマンスパーツのご購入、ご相談はお近くのスバル販売店へ
pressure and temp oil in this car? pepe Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-25-2015 05:02 PM
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 05:47 PM
Oil Temp Gauge Pod? HachiRo Cosmetic Modification (Interior/Exterior/Lighting) 5 03-07-2015 02:26 AM
Anyone know what I can use for a temp fix on this? twodollarcuts Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 02-23-2015 10:01 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-29-2013 11:50 PM
