Old 07-13-2017, 12:25 AM   #1
alex.s
alex.s's Avatar
Drives: '17 BRZ Premium. Totaled: '16 FRS
280f oil temp? is that bad?
how long is too long to run hard at 270-280f oil temp? ambient temp was 110f
i ordered an oil cooler but i'm just wondering how degraded my oil would be after 6x 20min sessions alternating between hard and easy (260f when going easy)... completely stock engine
alex.s is offline   Reply With Quote
Old 07-13-2017, 01:18 AM   #2
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
100-169F Warm Up Phase, high oil pressures
170-189F Near Operating temps, oil pressures still higher
190-225F Normal Operating Range, oil pressures normalize
225-245F Middle End of operating range for track use, 5% drop in oil pressures
245-255F Upper End of operating ranges for track use, 10% further drop in pressures on 0w20
255-265F Red Zone of operating ranges for track zone, 0w20 starts to thin, oil pressures drop to questionable range.
265F+ Playing with fire on 0w20
Can't remember where I found this or else I would credit them.
Edit: Also it depends on what brand of oil you're running before it starts to break down.
Pennzoil Ultra, API SM 0-20W *Onset Thermal Breakdown @ 280f degrees f*
Mobil 1, API SN 0-20W *Onset Thermal Breakdown @ 265 degrees f*
Castrol Edge w/ Titanium API SM 0-20W *Onset Thermal Breakdown @ 280 degrees f*
Trueweltall is offline   Reply With Quote
The Following 6 Users Say Thank You to Trueweltall For This Useful Post:
DandoX (07-13-2017), Jasper (04-02-2022), jcw99 (07-13-2017), Kazuya (07-14-2017), mizzta21 (07-13-2017), soulreapersteve (07-14-2017)
Old 07-13-2017, 01:30 AM   #3
Playing with fire there. Which oil cooler did you order?
Old 07-13-2017, 01:30 AM   #4
alex.s
alex.s's Avatar
Well shit.
Sent from my Nexus 5X using Tapatalk
Old 07-13-2017, 02:22 AM   #5
alex.s
alex.s's Avatar
Jackson racing
Old 07-13-2017, 02:44 AM   #6
Chronology
Drives: 13' Satin White Pearl BRZ
Are these considered the Flash or Fire point? Sorry just trying to compare to the oil I have.
RS*R Sport-I w/custom spring rate / Cusco Front/Rear Sways, Cusco Diff Brace / Cusco Power Brace (Rear/Front/Upper/Lower) / JDL UEL Headers / INVIDIA Q300 Ti / Valenti Revo Tails and rear backup/ EcuTek / Moto-East Flexfuel / Moto-East E85 tune
Chronology is offline   Reply With Quote
Old 07-13-2017, 03:21 AM   #7
That's when the oil starts chemically degrading and is no longer lubricating as intended.
Chronology (07-13-2017)
Old 07-13-2017, 08:03 AM   #8
Trueweltall
If I recall correctly these were the temperatures at which they started to vaporize/smoke.
The Following User Says Thank You to Trueweltall For This Useful Post:
Old 07-13-2017, 09:36 AM   #9
radroach
Drives: car
I'd just skip doing track days at 110* if its that severe on your engine.
Old 07-13-2017, 11:29 AM   #10
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
What would be the long term effects/damage to the engine from high oil temps like the OP experienced?
When I first got my '13 I took it out for 5 or more super aggressive canyon carving sessions that lasted an hour+ each, on the factory fill, where ambient temperatures were 95-105f. I did not have a way to monitor oil temperature at the time, but I'm sure it was easily in the 240-270 range if not higher.
Originally Posted by humfrz
I'm old and lazy
Old 07-13-2017, 11:39 AM   #11
alex.s
alex.s's Avatar
Blown crank bearings.
Old 07-13-2017, 11:40 AM   #12
Clipdat
Proud of BOXER
Clipdat's Avatar
And how would I know if I had that happen? What would I be looking for as far as symptoms?
I'm old and lazy
Old 07-13-2017, 12:01 PM   #13
strat61caster
strat61caster's Avatar
Engine knocking, like you're afraid to run the engine because of how bad it sounds and significant metal in the oil/filter.
It's been years, your engine is probably fine. I've done 5x track days without an oil cooler and nothing showed up in my oil analysis that would indicate improper wear.
ineedyourdiddly
The Following 3 Users Say Thank You to strat61caster For This Useful Post:
Clipdat (07-13-2017), driggity (07-13-2017), soulreapersteve (07-14-2017)
Old 07-13-2017, 12:05 PM   #14
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I'd do an oil change before putting any unnecessary miles on your car.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
pressure and temp oil in this car? pepe Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 08-25-2015 05:02 PM
FS: BNIB Prosport Guages (Water Temp / Exhaust Gas Temp) AtlasMick Interior Parts (Incl. Lighting) 2 03-31-2015 05:47 PM
Oil Temp Gauge Pod? HachiRo Cosmetic Modification (Interior/Exterior/Lighting) 5 03-07-2015 02:26 AM
Anyone know what I can use for a temp fix on this? twodollarcuts Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 02-23-2015 10:01 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-29-2013 11:50 PM
