Old 07-08-2017, 07:44 AM   #99
JD001
JD001's Avatar
Drives: Subaru BRZ
Originally Posted by JoeC View Post
How is this thread still going?????????
JoeC, please appreciate that this is a well oiled machine. No half measures here!
The Following 2 Users Say Thank You to JD001 For This Useful Post:
JoeC (07-08-2017), Ultramaroon (07-08-2017)
Old 07-08-2017, 10:59 AM   #100
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
5 star comment
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
JD001 (07-08-2017)
Old 07-08-2017, 11:51 AM   #101
oldgunfan
oldgunfan's Avatar
Drives: 2014 BRZ sterling silver
One thing I see happening is are car has a remote oil filter that is above the engine. So I think if you let the car sit to long the oil from the filter drains down in the oil pan. When you start the car and Warm it up it refills the oil filter. that's why we are getting strange readings. So I guess we should do it like the manual says
oldgunfan is offline   Reply With Quote
The Following User Says Thank You to oldgunfan For This Useful Post:
Old 07-08-2017, 03:32 PM   #102
Actually that's part of the "wait 5 minutes" rule. Doesn't take long for it to empty.
On a side note, after installing my mechanical pressure gauge I find it a little disturbing counting two and a half Mississippis before the oil hits the journals.
Gotta force myself to quit looking.
Old 07-08-2017, 03:47 PM   #103
oldgunfan
oldgunfan's Avatar
I Know, That's why I started running 5/30 pennzoil ultra platinum. I only get one mississippi with that
Old 07-08-2017, 03:49 PM   #104
You have a mechanical gauge too? I thought I was the only one.
What pressure do you get on cold start with that heavy stuff?
Old 07-08-2017, 04:08 PM   #105
oldgunfan
oldgunfan's Avatar
about 120 cold but the big difference is I have never seen it below 50. BTW I wouldn't call 5/30 heavy, I would call 0/20 water, I saw below 20 in the summer with that stuff.
Old 07-08-2017, 10:09 PM   #106
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
It does worry me how thin the oil is. I suspect it's for emissions/fuel efficiency.
Once my 0w-20 runs out I'm using 5w-30
Scrappydoo is offline   Reply With Quote
The Following User Says Thank You to Scrappydoo For This Useful Post:
Ultramaroon (07-09-2017)
Old 07-08-2017, 11:37 PM   #107
See ...... too much information is bad ......
strat61caster (07-09-2017), Ultramaroon (07-09-2017)
Old 07-08-2017, 11:42 PM   #108
All three of you-ens ........ this is a dip stick reading thread NOT a weight of oil thread ..... THAT just confuses the dipstick readings .......
Old 07-09-2017, 12:15 AM   #109
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
But a thicker oil should make reading the dipstick easier.
humfrz (07-09-2017), Ultramaroon (07-09-2017)
Old 07-09-2017, 01:26 AM   #110
Silver Supra
Hombre
Silver Supra's Avatar
Drives: 1994 Supra Turbo
I just wish it made reading this thread easier!
Also, it makes things quicker if you count the "mississippis" the way my location is written.........
Silver Supra is offline   Reply With Quote
The Following 2 Users Say Thank You to Silver Supra For This Useful Post:
Scrappydoo (07-09-2017), Spuds (07-09-2017)
Old 07-09-2017, 02:19 AM   #111
Well, that's true ...... but my point is that would just add another variable to reading the dip stick. ........
That goes along with how dirty the oil is, what kind of rag/paper towel you use to wipe off the dipstick, the lighting in your driveway/garage, which way the dipstick was inserted. the speed of which the dip stick was pulled out, the angle one held the dip stick to read it, which side of the dipstick to read, let alone the surface tension of the oil and its ability to adhere to the metal dip stick.
Bubba says to open the hood, pull out the dipstick and if the end of the oily part is between the two holes, stick it back in and shut the hood, you're good to go, ............what's the big deal ......
Spuds (07-09-2017)
Old 07-09-2017, 02:53 AM   #112
You're making it sound waaaaaay too simple. This is a car forum, FFS! It's our duty to argue over all the shit about which normal people don't give a fuck.
humfrz (07-09-2017), JD001 (07-09-2017), Spuds (07-10-2017)
OFT not reading ECU Gray Fox Software Tuning 12 08-02-2017 07:44 PM
What can I stick this onto... GhostRai Other Vehicles & General Automotive Discussions 28 07-05-2017 07:24 PM
Reading Vin # Knightmare BRZ First-Gen (2012+) — General Topics 2 11-16-2012 02:26 PM
RPM stick between 3.5 - 4.5 Realm Engine, Exhaust, Transmission 6 09-18-2012 02:10 PM
