Old 07-02-2017, 07:33 PM   #1
Jarrid'sBRZ
Drives: 2016 Black subaru BRZ limited
Reading the dip stick
Hello all,
Does any one have any tips for trying to read the dip stick? Every time I use it I only get a bit of oil along the edge of the stick and its impossible to read. Is this how it is for everyone or am I just useless... lol let me know guys!
Jarrid'sBRZ is offline   Reply With Quote
Old 07-02-2017, 07:37 PM   #2
MisterSheep
Killed Scion
MisterSheep's Avatar
Drives: 2013 FR-S Whiteout
Originally Posted by Jarrid'sBRZ View Post
Hello all,
If you're only getting oil along the side, try changing the direction of the dipstick (as in change the way the dipstick is positioned). If that doesn't work then your oil is definitely low.
Instagram: trevor.parque
Old 07-02-2017, 09:47 PM   #3
Ultramaroon
not playing cards
Ultramaroon's Avatar
I have read here that scuffing up the dipstick with some scotch-brite makes it much easier to read. I haven't tried it but it makes sense. It's easier to see the glossy oil against a matte surface than it is against the shiny surface of the oem dipstick.
If you do try it, make sure all the abrasive dust is cleaned off before you stick it in. Don't contaminate your engine. Sounds obvious but it still bears mentioning.
Old 07-02-2017, 09:55 PM   #4
extrashaky
Drives: 2014 BRZ Limited
But isn't that just good common sense advice for life in general?
Old 07-02-2017, 10:02 PM   #5
Ultramaroon
not playing cards
Well, yes. I suppose that is true.
Old 07-02-2017, 10:41 PM   #6
I have done this (sort of) with every car I have owned in the last 20 years.
I score the dipstick horizontaly between the holes. Not only is it easier to see the oil against the rough surface it actually holds more of it in place on the dipstick.
Old 07-03-2017, 12:10 AM   #7
Silver Supra
Hombre
Silver Supra's Avatar
Drives: 1994 Supra Turbo
I score the dipstick horizontaly between the holes. ..
What score did your dipstick get?
Silver Supra is offline   Reply With Quote
Old 07-03-2017, 12:15 AM   #8
Old 07-03-2017, 01:10 AM   #9
Ultramaroon
not playing cards
Does scoring it randomly or vertically ruin the effect?
Old 07-03-2017, 01:31 AM   #10
Well it is only basically horizontal so is pretty random. I suppose vertically would have almost the same effect of having the oil stick better. Just don't score too deeply or the car will be off balance to sink like a stone in a turn.
Old 07-03-2017, 03:06 AM   #11
Ultramaroon
not playing cards
Old 07-03-2017, 11:56 PM   #12
pfaffendorn
pfaffendorn's Avatar
Drives: 2014 ssm BRZ Limited 6M
Hello all,
You're not useless, just facing one of the mildly aggravating challenges of prudent car care. I find the same thing upon pulling the dipstick, but I have learned that wiping it clean and reinserting it will give you a pretty clear reading on the second pull. The other guys have creative and useful suggestions, but I think mine is, on balance, less trouble, and uses just one kleenex to perform.
By the way, while we're speaking of oil, I have also found that adding a pint or so more oil above the top hole in the dipstick results in a smoother startup and less metal-on-metal noise on the road. I know I'm probably courting some kind of disaster, but I feel less engine noise means less wear and tear, and it seems to work the same way with both my BRZ and our Legacy 2.5 (which made a horrifying clatter for a few seconds after pushing the start button, but not anymore). And the music of the exhaust is much more enjoyable.
Any comments, y'all?
There are worse things to worry over.
pfaffendorn is offline   Reply With Quote
Old 07-04-2017, 03:27 AM   #13
Ultramaroon
not playing cards
I thought wiping and re-inserting was a given. If not then, yes. Pull, wipe, insert, pull, read.
Do not overfill unless you know for a fact where the hard limit is. I don't.
Old 07-04-2017, 04:30 AM   #14
JD001
JD001's Avatar
Drives: Subaru BRZ
Just don't do it too often as you'll run out of oil..
OFT not reading ECU Gray Fox Software Tuning 12 08-02-2017 06:44 PM
What can I stick this onto... GhostRai Other Vehicles & General Automotive Discussions 28 07-05-2017 06:24 PM
Reading Vin # Knightmare BRZ First-Gen (2012+) — General Topics 2 11-16-2012 01:26 PM
RPM stick between 3.5 - 4.5 Realm Engine, Exhaust, Transmission 6 09-18-2012 01:10 PM
