#113 | |
Drives: Subaru BRZ
Videos to come later; ended up drinking the last few days. My bad for the delay. |
#114 |
Drives: Subaru BRZ
For the most part, if your noises are consistent; you're good to go. If new noises appear or randomly go away -- something isnt right.
#115 | |
#116 |
Drives: '14 BRZ | '95 Range Rover
Help! I want to order a FD but can't decide.
I've got a MT that I want to keep NA. I will not be doing E85 in the foreseeable future. I've got stock wheels and Michelin Pilot Super Sports in stock tire size and plan on staying this way as well. The car is my DD, and I have a different car I can use for road trips. Should I go 4.88 or is 4.56 much safer? I do about an even three-way of city-highway-freeway driving, and usually I never cruise above 75mph, more typically 65, which I calculate will be ~4000rpm on the 4.88. Is this bad? The 4.56 would be ~3700RPM. Any input is appreciated. |
#117 | |
Drives: '15 BRZ RA
On your final drive question, 4.55 or 4.88 will only drop the whole range of gears, so your top gear will be shorter, so the fuel cosumption will decrease. It will only feel livelier but not in all gears since we are just dropping the shipt points lower...but not increasing the power to the output. So it's a choice. I would leave it alone if I was you since it really doesn't make the car any faster in all places. Just in someplaces, and in other places, slower. |
#118 |
Drives: 2014 GT86
Pitty close-ratio gearsets are nowhere near as cheap as FD. Though even better would be such gearset (with longer 1st & 2nd) AND different FD.
#119 | |
Drives: 1991 Acura NSX
| CUSCO 4.55 FINAL DRIVE installed. | Racecomp Engineering | Engine, Exhaust, Transmission | 488 | 06-17-2018 12:14 AM |
| Mfactory Final Drive Ring and Pinion | Crossover Auto | Engine, Exhaust, Transmission | 87 | 05-26-2017 02:21 AM |
| Final Drive Calculations | wootwoot | Engine, Exhaust, Transmission | 34 | 12-19-2014 04:06 AM |
| Anyone w/ 3.727/3.909 Final Drive Post Boost? | Staf00 | Engine, Exhaust, Transmission | 12 | 05-02-2013 08:38 PM |
