#57 | |
Drives: 2014 ssm BRZ Limited 6M
There are worse things to worry over.
| The Following 2 Users Say Thank You to pfaffendorn For This Useful Post: | Ultramaroon (07-05-2017), wolffbite (07-05-2017) |
#58 |
Drives: frs
Short throw dip stick is way better
| The Following 5 Users Say Thank You to Teseo For This Useful Post: | Scrappydoo (07-05-2017), Spuds (07-05-2017), strat61caster (07-05-2017), Tcoat (07-05-2017), Ultramaroon (07-05-2017) |
#59 | |
![]() Good times.
#60 |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
That and lower oil content is weight savings!
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
#61 | |
Drives: '13 FRS - STX
If I did it your way I'd fear being overfilled (at the Full mark when cold would be over full by ~0.2L) but I don't think you're negatively affecting the engine, fat margins of safety on consumer products yo. |
#62 |
Drives: Subaru BRZ
I'm finding myself dipping in and out of this thread.. so far no wiping!!
| The Following 2 Users Say Thank You to JD001 For This Useful Post: | Scrappydoo (07-05-2017), Spuds (07-05-2017) |
#63 |
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | strat61caster (07-05-2017), TurtleFace (07-06-2017) |
#64 |
Drives: Grrrr
#65 |
Drives: frs
| The Following User Says Thank You to Teseo For This Useful Post: | Scrappydoo (07-05-2017) |
#66 |
Drives: Grrrr
#67 | ||||
Drives: 2015 Series.Blue
5 pages and nobody posts this?
![]() 1) Do it warm. 2) Check both sides and go off the lower side. 3) It's not a range, it's full or low, stop under filling! Quote:
2) You "drive with spirit" means you're liking taking corners hard which if you're under filled would cause loss of oil pressure as the pickup is uncovered. Also, extreme conditions is short trips and opposite of what 90% of people think it is. Quote:
Maybe it's because I come from cars that are very sensitive to oil starvation, but this crap drives me crazy. |
#68 |
![]() Life was simpler back-in-the-day ....... ![]() humfrz |
#69 |
The Dictater
Drives: '13 Red Scion FRS
| The Following User Says Thank You to Spuds For This Useful Post: | Ultramaroon (07-05-2017) |
#70 | |
The "full" mark is not an indicator that it MUST be to that line. It simply means it is full. The instructions are very clear when you need to add oil and it does not say "If below the full line at all". That said I am firmly with you in the keep it full all the time camp.
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | strat61caster (07-05-2017), Ultramaroon (07-05-2017) |
| OFT not reading ECU | Gray Fox | Software Tuning | 12 | 08-02-2017 06:44 PM |
| What can I stick this onto... | GhostRai | Other Vehicles & General Automotive Discussions | 28 | 07-05-2017 06:24 PM |
| Reading Vin # | Knightmare | BRZ First-Gen (2012+) — General Topics | 2 | 11-16-2012 01:26 PM |
| RPM stick between 3.5 - 4.5 | Realm | Engine, Exhaust, Transmission | 6 | 09-18-2012 01:10 PM |
