#43 |
FT86Club Vancouver
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
![]() On a more serious note, the correct way is always check only when engine is cold when MOST of it's oil has drained back into the pan. It's the most accurate way. I ALWAYS fill up to the "FULL" mark, no more, no less. That way, I know if my engine is eating oil when I check it the following morning. Good luck!
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT 2010-2012 2013 BRZ Sport-Tech 6AT Since '12 (OEM+ STI tS Build) 2015 Lexus IS250 AWD F-Sport 2 2015-2018 2018 Lexus NX300 F-Sport 3 Since '18 |
| The Following 2 Users Say Thank You to DaJo For This Useful Post: | 22R (07-06-2017), pfaffendorn (07-05-2017) |
#44 |
Drives: Grrrr
Is it on an even page in the book?
| The Following 2 Users Say Thank You to Scrappydoo For This Useful Post: | pfaffendorn (07-05-2017), Ultramaroon (07-05-2017) |
#45 | |
Senior gif poster
Drives: 2013 Asphalt FRS
Is there a reason to keep the oil at the full mark? Do you have info to back that up? For me I've added oil to the full mark only to check it the next day after driving and see it is now above the full mark which I know can be harmful. That is why I don't fill to the full mark. Judging by everyone's reactions I may be wrong but it is a good opportunity to learn what is right and why. Can you or someone else please explain? |
| The Following User Says Thank You to DandoX For This Useful Post: | pfaffendorn (07-05-2017) |
#46 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Never going to be a literary masterpiece.
Mine barely even has a plot and the protagonist seems to be a slimeball. Ishmael's got nothing to worry about here.
"I gotta rock." -- Charley Brown |
#47 | |
AND, the manufacturer is the one that made and calibrated the dip stick. Now, what's to debate ....... ?? ![]() humfrz |
| The Following 3 Users Say Thank You to humfrz For This Useful Post: |
#48 | ||
Drives: '13 FRS - STX
Not up to the 'full' line, not 'above half' and certainly not 'a pint over'. They give you a minimum threshold and a maximum threshold and all they care about is staying above the minimum and below the maximum. I won't argue beliefs and anecdotes and oil flow rate calculations, only that the manual does NOT tell you to "fill it all the way up". Personally I think filling it up to the full mark is no problem, engineers are smart and they know people don't read directions (which is why having it at or even below low isn't going to ruin it either). It also says check when warm and more than 5 minutes after you shut the car off. Anecdote: just did my 60k mile service, never has it once been filled all the way to the "full" mark, even from the factory, you'll all hear about it if I blow an engine. I typically try to keep mine between 1/4 and 1/2, old racing habits die hard but it's never been below 'low'.
| The Following 4 Users Say Thank You to strat61caster For This Useful Post: | DandoX (07-05-2017), Logikal Reazon (11-28-2018), pfaffendorn (07-05-2017), Ultramaroon (07-05-2017) |
#49 |
Depends on whether one is reading the US, or the Queen's version.
#50 | |
Drives: Grrrr
Damn right. You can't be sure unless you fill it right up. Pour as much oil in there as possible and throw the rest on your lawn. It's your birthright. |
| The Following User Says Thank You to Scrappydoo For This Useful Post: | pfaffendorn (07-05-2017) |
#51 |
Drives: Grrrr
#52 |
Drives: Grrrr
| The Following 3 Users Say Thank You to Scrappydoo For This Useful Post: |
#53 | |
Just the tip
Drives: 2017 DGM BRZ
Page 337 of 2017 manual says otherwise. This makes sense to me because your oil level at operating temperature is what should matter. The difference between hot and cold should be pretty small anyways, but I go by the manual. Page 338 shows that the oil amount between low and full is 1.1 qt or 1 litre. I just keep a 1L in my trunk and top off to close to full as needed. Only had to do it once in my first 7k kms, maybe 250ml worth. I agree that staying closer to full is probably better, because if the difference is 1.1qt and the car takes 5.7qt, that's almost a 20% difference been low and full. |
| The Following User Says Thank You to wolffbite For This Useful Post: | pfaffendorn (07-05-2017) |
#54 | |
![]() See, everybody. We all need a good dope slap now and then. I'll still keep checking mine cold and add 'til it's almost full. For the record, my rough calculation shows that 5 quarts of oil at 20*C will have expanded by about a cup at 80*C
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | pfaffendorn (07-05-2017), strat61caster (07-05-2017) |
#55 |
| The Following User Says Thank You to Ultramaroon For This Useful Post: | pfaffendorn (07-05-2017) |
#56 |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | pfaffendorn (07-05-2017), strat61caster (07-05-2017) |
| OFT not reading ECU | Gray Fox | Software Tuning | 12 | 08-02-2017 07:44 PM |
| What can I stick this onto... | GhostRai | Other Vehicles & General Automotive Discussions | 28 | 07-05-2017 07:24 PM |
| Reading Vin # | Knightmare | BRZ First-Gen (2012+) — General Topics | 2 | 11-16-2012 02:26 PM |
| RPM stick between 3.5 - 4.5 | Realm | Engine, Exhaust, Transmission | 6 | 09-18-2012 02:10 PM |
