Old 07-05-2017, 04:12 AM   #43
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
On a more serious note, the correct way is always check only when engine is cold when MOST of it's oil has drained back into the pan. It's the most accurate way.
I ALWAYS fill up to the "FULL" mark, no more, no less. That way, I know if my engine is eating oil when I check it the following morning.
Good luck!
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
The Following 2 Users Say Thank You to DaJo For This Useful Post:
22R (07-06-2017), pfaffendorn (07-05-2017)
Old 07-05-2017, 05:02 AM   #44
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
WTF?
No.
Full is full and best. Any lower and the pump has to do more work.
Too full is a problem when it starts sloshing and getting whipped up.
Stick to the book, everyone. I can't believe some of the shit I'm reading here.
Is it on an even page in the book?
Scrappydoo is offline   Reply With Quote
The Following 2 Users Say Thank You to Scrappydoo For This Useful Post:
pfaffendorn (07-05-2017), Ultramaroon (07-05-2017)
Old 07-05-2017, 12:19 PM   #45
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Originally Posted by Subsonic View Post
OK, I get it. You say without qualification that filling to between the 1/2 and 1/4 mark makes you feel better. No harm in that, unless you are actually recommending it to others. Carry on enjoying your car!
Subsonic
In the manual it just says keep between full and low and add oil if it gets too close or below the low mark, nothing about topping it off to the full mark.
Is there a reason to keep the oil at the full mark? Do you have info to back that up?
For me I've added oil to the full mark only to check it the next day after driving and see it is now above the full mark which I know can be harmful. That is why I don't fill to the full mark. Judging by everyone's reactions I may be wrong but it is a good opportunity to learn what is right and why. Can you or someone else please explain?
DandoX is offline   Reply With Quote
The Following User Says Thank You to DandoX For This Useful Post:
Old 07-05-2017, 12:36 PM   #46
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Never going to be a literary masterpiece.
Mine barely even has a plot and the protagonist seems to be a slimeball.
Ishmael's got nothing to worry about here.
Old 07-05-2017, 01:11 PM   #47
WTF?
No.
Yep, I agree, the manufacturer is the one that knows best as to where to keep the oil level.
AND, the manufacturer is the one that made and calibrated the dip stick.
Now, what's to debate ....... ??
The Following 3 Users Say Thank You to humfrz For This Useful Post:
pfaffendorn (07-05-2017), strat61caster (07-05-2017), Ultramaroon (07-05-2017)
Old 07-05-2017, 02:14 PM   #48
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
WTF?
No.
Yes yes everyone should re-read the manual:
When checking the oil, look at both sides of the dipstick and use the lower measurement to determine the level of oil (p. 242)
Adding engine oil
If the oil level is below or near the low level mark, add engine oil of the same type as already in the engine. (p. 243)
https://www.toyota.com/owners/resour...uals/fr-s/2013
Not up to the 'full' line, not 'above half' and certainly not 'a pint over'. They give you a minimum threshold and a maximum threshold and all they care about is staying above the minimum and below the maximum.
I won't argue beliefs and anecdotes and oil flow rate calculations, only that the manual does NOT tell you to "fill it all the way up". Personally I think filling it up to the full mark is no problem, engineers are smart and they know people don't read directions (which is why having it at or even below low isn't going to ruin it either). It also says check when warm and more than 5 minutes after you shut the car off.
Anecdote: just did my 60k mile service, never has it once been filled all the way to the "full" mark, even from the factory, you'll all hear about it if I blow an engine. I typically try to keep mine between 1/4 and 1/2, old racing habits die hard but it's never been below 'low'.
ineedyourdiddly
The Following 4 Users Say Thank You to strat61caster For This Useful Post:
DandoX (07-05-2017), Logikal Reazon (11-28-2018), pfaffendorn (07-05-2017), Ultramaroon (07-05-2017)
Old 07-05-2017, 03:21 PM   #49
Depends on whether one is reading the US, or the Queen's version.
Old 07-05-2017, 03:24 PM   #50
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Damn right. You can't be sure unless you fill it right up. Pour as much oil in there as possible and throw the rest on your lawn.
It's your birthright.
The Following User Says Thank You to Scrappydoo For This Useful Post:
Old 07-05-2017, 03:25 PM   #51
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
I don't think our Queen could be bothered with a Subaru.
There are a few queens on here, ask them
Old 07-05-2017, 03:27 PM   #52
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Not Cole. She is a princess.
The Following 3 Users Say Thank You to Scrappydoo For This Useful Post:
pfaffendorn (07-05-2017), Spuds (07-05-2017), Tcoat (07-05-2017)
Old 07-05-2017, 03:27 PM   #53
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Good luck!
Page 337 of 2017 manual says otherwise. This makes sense to me because your oil level at operating temperature is what should matter. The difference between hot and cold should be pretty small anyways, but I go by the manual.
Page 338 shows that the oil amount between low and full is 1.1 qt or 1 litre. I just keep a 1L in my trunk and top off to close to full as needed. Only had to do it once in my first 7k kms, maybe 250ml worth. I agree that staying closer to full is probably better, because if the difference is 1.1qt and the car takes 5.7qt, that's almost a 20% difference been low and full.
wolffbite is offline   Reply With Quote
The Following User Says Thank You to wolffbite For This Useful Post:
Old 07-05-2017, 03:32 PM   #54
Well, shit! I've read cover to cover and still missed the specifics. Must've skimmed over that.
See, everybody. We all need a good dope slap now and then.
I'll still keep checking mine cold and add 'til it's almost full. For the record, my rough calculation shows that 5 quarts of oil at 20*C will have expanded by about a cup at 80*C
Old 07-05-2017, 03:34 PM   #55
lol
Old 07-05-2017, 03:41 PM   #56
How to Read a Dipstick and What Oil Level Should You Maintain Thread #509,834,418,001.6
OFT not reading ECU Gray Fox Software Tuning 12 08-02-2017 07:44 PM
What can I stick this onto... GhostRai Other Vehicles & General Automotive Discussions 28 07-05-2017 07:24 PM
Reading Vin # Knightmare BRZ First-Gen (2012+) — General Topics 2 11-16-2012 02:26 PM
RPM stick between 3.5 - 4.5 Realm Engine, Exhaust, Transmission 6 09-18-2012 02:10 PM
