Old 06-30-2017, 09:41 PM   #1
John27
Drives: scion fr-s
torque
anyone know could affect torque cause some days feel like car launch forward other days feel like car die
John27 is offline   Reply With Quote
Old 06-30-2017, 09:47 PM   #2
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
foot all the floor is usually fast
ineedyourdiddly
The Following 11 Users Say Thank You to strat61caster For This Useful Post:
Braces (07-01-2017), Cole (07-01-2017), Crashdummy (07-01-2017), extrashaky (07-01-2017), fx1mark (07-02-2017), Impureclient (06-30-2017), jubella2 (07-06-2017), KR-S (07-01-2017), lantsalot (07-05-2017), Spuds (07-01-2017), Summerwolf (07-01-2017)
Old 06-30-2017, 10:14 PM   #3
carsebuco
How do I shift?
carsebuco's Avatar
Drives: '13 GBS BRZ
The other day my car died when I put her in 5th from stop. I was just trying to beat that minivan that cut me off but it didn't quite work out.
carsebuco is offline   Reply With Quote
Old 06-30-2017, 10:55 PM   #4
Impureclient
Drives: 2015 FR-S
car die sound bad maybe entered 87 gas octane formula?
strat61caster right, foot all the floor working usually
modifications are inside on your engine place?
The Following 2 Users Say Thank You to Impureclient For This Useful Post:
Cole (07-01-2017), OND (07-01-2017)
Old 07-01-2017, 12:02 AM   #5
radroach
Drives: car
Hot car make not run good. Drive on cold day feel better.
The Following User Says Thank You to radroach For This Useful Post:
RallySport (07-05-2017)
Old 07-01-2017, 12:09 AM   #6
navanodd
Drives: 2013 BRZ Sport-tech WRB
Sometimes, the jar is really hard to open and you need to put it under hot water first.
navanodd is offline   Reply With Quote
The Following User Says Thank You to navanodd For This Useful Post:
KR-S (07-01-2017)
Old 07-01-2017, 12:34 AM   #7
Although written like an old SNL sketch the OP has a valid question.
John, is the car stock?
Is there any pattern to when you have issues?
DriveDriftDogfight86 (07-02-2017), Vic4uf (07-01-2017)
Old 07-01-2017, 12:41 AM   #8
KR-S
Sporadic Member
KR-S's Avatar
Drives: 2016 Halo FR-S M/T
somedays i feel very alive while other days i ded in bed
Old 07-01-2017, 12:48 AM   #9
KR-S
Sporadic Member
KR-S's Avatar
so to be serious and address your question fren
Do you have any mods whatsoever? For example maybe a tune from Ecutek or OFT?
EDIT: Based on your previous threads, are you still having issues with your MAF as well?
The Following User Says Thank You to KR-S For This Useful Post:
Tcoat (07-01-2017)
Old 07-01-2017, 01:13 AM   #10
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Some helpful responses so far, but is someone who wrote that OP able to comprehend them?
PetrolioBenzina is offline   Reply With Quote
Old 07-01-2017, 01:15 AM   #11
Boomerang
86
Boomerang's Avatar
button control maybe traction
Old 07-01-2017, 10:44 AM   #12
PetrolioBenzina
Drives: 17 86
Problem Exists Between Pedals And Seat?
The Following 2 Users Say Thank You to PetrolioBenzina For This Useful Post:
Old 07-01-2017, 11:00 AM   #13
StraightOuttaCanadaEh
Wes
I have noticed this on multiple cars and always attributed it to air humidity and temperature. Car runs better in cooler temperature and when it's humid outside. I believe BMW M4 GTS has a water injection system that humidifies the air in the intake (is that how it works?) so I'm guessing it's something like that. Cause yeah, definitely some days it feels like the car has more oomph.
Also I noticed when I drive it AFTER I have already driven it once and it sat for about an hour or so, so the fluids are still warm, it really flies.
Old 07-01-2017, 11:23 AM   #14
oldgunfan
oldgunfan's Avatar
Drives: 2014 BRZ sterling silver
May-be it's the loose nut behind the wheel, (good luck finding a wrench to fit it or a Torque spec).
oldgunfan is offline   Reply With Quote
The Following User Says Thank You to oldgunfan For This Useful Post:
Calculate torque when using a crows foot on torque wrench BirdTRD DIY (Do-It-Yourself) Guides 0 10-11-2015 04:02 PM
Requested torque and Calculated torque nickw14 Software Tuning 3 06-13-2015 04:09 AM
Torque Pro App poorsche Engine, Exhaust, Transmission 4 12-12-2014 05:01 AM
Lug Nut Torque Lunatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 07-30-2014 07:45 PM
Torque Pro sav AFRICA 33 08-27-2013 07:31 AM
