Old 06-30-2017, 04:10 PM   #4047
CSG Mike
CSG Mike's Avatar
Originally Posted by Bramick View Post
Am I the only one who continually has issues with my oil spacer plate slowly leaking from underneath? Everytime I change the oil I have the issue. The only way​ to resolve it is to tighten everything as hard as possible. That doesn't seem correct. I'm out of ideas.
Replace the seal, and torque to spec. Overtorquing it damage the seal, which is then band-aided by overtorquing it even more, etc etc
Bramick (06-30-2017), mrg666 (06-30-2017)
Old 06-30-2017, 04:28 PM   #4048
CSG Mike
CSG Mike's Avatar
Originally Posted by Ron B Avery View Post
I am looking at the Jackson supercharger for my 86. Is it a good idea to add the Jackson oil cooler? And a oil/pressure temp gauge? And if so witch one and where do you mount them so they don't looked tacked on. The car will mostly be driven on the street with the occasional track day.
Ron
That "occasional track day" is why I would recommend also getting the Jackson Racing oil cooler with your supercharger kit.
You won't need a pressure/temp gauge; the system is already proven. If you want one anyways, I would recommend using an OBD2 type device, or getting a P3 vent gauge for stealthyness.
Should I have @CounterSpace Garage schedule you in for an install? CSG is only about 90 minutes away from Oxnard.
mrg666 (06-30-2017)
Old 06-30-2017, 04:58 PM   #4049
mrg666
pessimistic skeptic
mrg666's Avatar
Originally Posted by Moto-Phil View Post
An oil cooler kit is almost a must when you do any kind of forced induction on these cars, If you are tracking the car it is required. The Jackson racing oil cooler works great and fits well with the kit so its a no brainier.
As for the gauges a lot of people coming in have been getting ortiz custom pods as of lately which is an entire new bezel piece that integrates the gauges into the bezel and looks fairly decent, we have also done a few gauge installs in the glove compartment which are nicely tucked away until you need your readouts.
-Phil
Do you have a build thread or blog of your 600 whp brz?
Old 06-30-2017, 09:01 PM   #4050
twag4
Drives: frs
I need these seal for my JR engine oil kit I bought from you. Do you have them?
twag4 is offline   Reply With Quote
Old 06-30-2017, 09:33 PM   #4051
Ron B Avery
Ron B Avery's Avatar
Drives: 2017 86 Coupe
Thanks for the offer, I already have the install covered.
Ron
2017 Toyota 860 Halo White, TRD springs, TRD air filter, Center consul arm rest lid, Magnaflow cat back exhaust, Pioneer SPH-DA120 head unit with Apple CarPlay,
TRD sway bars , 17" 949 Wheels Beryllium finish, Michelin Pilot Super Sport tires, 225/45 ZR 17, Garage Vary Kouki splitter
Ron B Avery is offline   Reply With Quote
Old 07-02-2017, 12:24 AM   #4052
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
I'm sure owners here are familiar with the fluttering sound the SC makes when off throttle at high rpm which sounds a lot like compressor surge. At my local tracks the car sits at this high rpm through long bends frequently and was wondering whether the long term reliability is compromised by the compressor surge, would switching to a proper blow off valve be a possible solution or should I just stick with what I have?
Canehda is offline   Reply With Quote
Old 07-02-2017, 03:24 AM   #4053
CSG Mike
CSG Mike's Avatar
Make sure your bypass is properly plumbed to vacuum.
Old 07-02-2017, 01:51 PM   #4054
Canehda
Canehda's Avatar
It is, my mechanic even zip tied the vacuum lines just in case. There are three of us with the same kit in a group chat and they all sound the same so I'm assuming they all do it unless we got a bad batch of by pass valves. But below 6k rpm they make the whooshing air sound. Just at the high rpm does it make the compressor surge sound
Old 07-02-2017, 03:55 PM   #4055
Sleepless
Sleepless's Avatar
Drives: 2016 FR-S
Not familiar with this. Do you have a recording?
Sleepless is offline   Reply With Quote
Old 07-02-2017, 08:41 PM   #4056
mrg666
pessimistic skeptic
mrg666's Avatar
Since you said there is no leak, the sound could be just the bypass valve. If you are suddenly releasing the throttle while accelerating hard above 5000rpm, the bypass valve recirculates the extra air until engine rpm is reduced. Fluttering sound you mention might be that sound. If you have to suddenly abort a strong acceleration, manually up shifting decreases the pressure by reducing rpm so that bypass valve wouldn't handle all that extra pressure and make the fluttering sound.
Old 07-03-2017, 02:47 AM   #4057
CSG Mike
CSG Mike's Avatar
Can you get me a video clip?
It should be a singlar "woosh".
The way the kit is designed, compressor surge is virtually impossible. There's a reason why the bypass is directly after the supercharger.
Old 07-04-2017, 10:45 PM   #4058
Canehda
Canehda's Avatar
Working on the video clip, it's a. It obscure with internal go pro mic so I'm trying to grab an external mic so you guys get a more accurate sound!
Old 07-24-2017, 03:58 PM   #4059
adjusts
adjusts's Avatar
Drives: 86
anyone else getting weird thump sounds under abrupt throttle? Inlet tube seems to be compressing.
adjusts is offline   Reply With Quote
Old 07-24-2017, 08:24 PM   #4060
PR138
PR138's Avatar
Drives: '14 WRB BRZ | '17 CB STi
For those of you running a C38 with the high boost pulley on e85, can you comment on how it feels? I keep seeing comments on this forum and elsewhere that this kit is "underwhelming" in pull, but I find it hard to believe a 2800lb car with 370whp is underwhelming in feel or performance. I'm guessing most of those comments are directed towards a fairly stock car with 91 octane.
Can anyone here comment on overall feel at that boost and power level?
PR138
IG: @pr.138
2008 LBP Honda S2000
2013 UM Scion FR-S
PR138 is offline   Reply With Quote
The Following User Says Thank You to PR138 For This Useful Post:
CSG Mike (07-24-2017)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
