Old 06-24-2017, 06:45 PM   #4033
mrg666
pessimistic skeptic
mrg666's Avatar
Originally Posted by milhouse View Post
I was planning on a CARB tune for mine, but due to an error by FT86 Speedfactory I had to get a Delicious remote tune. It cost $1,125 (instead of $1,000 for the CARB tune) and gave me a lot more peace of mind. The guys from Delicious were great - overnighted an Ecutek, and did 3 sessions based on my logs. That took them 2 days total, and their base tune only needed minor changes (though I have very light mods, and a stock header).
But for an extra $125 you will get an excellent custom tune, unless, of course, you require a CARB tune...
You made it sound like CARB tune is inferior. I don't see anything wrong with CARB tune if everything else is stock. I am happy with it; very refined, efficient, and consistent. Engine is running smoother than stock.
With engine modifications Delicious tune is good too as I see the feedbacks from others.
Old 06-24-2017, 06:48 PM   #4034
milhouse
Because Racecar
milhouse's Avatar
Drives: 2013 Lightning Red Subaru BRZ
That wasn't my intention as, like I said, that was my plan. But if you are going to make further mods you can't use the CARB tune. But an extra $125 gives you the option, as opposed to paying more later if you can no longer use the CARB tune.
Sent from my ONEPLUS A3000 using Tapatalk
milhouse is offline   Reply With Quote
The Following User Says Thank You to milhouse For This Useful Post:
mrg666 (06-24-2017)
Old 06-24-2017, 07:00 PM   #4035
mrg666
pessimistic skeptic
mrg666's Avatar
I agree, if there are future mods planned, starting with Delicious tune seems like a good idea.
The Following User Says Thank You to mrg666 For This Useful Post:
Sleepless (06-25-2017)
Old 06-25-2017, 11:12 PM   #4036
adjusts
adjusts's Avatar
Drives: 86
would it be okay to flash the delicious flash-and-go tune for my JRSC and drive, even though I have UEL headers? Would it be safe to drive?
I am able to contact my tuner for a revision but I need to datalog, but I do drive the FRS pretty frequently so I am curious as to how safe it is to drive on the base JRSC tune without revision to account for headers and exhaust already on the car.
adjusts is offline   Reply With Quote
Old 06-26-2017, 03:52 PM   #4037
mrg666
pessimistic skeptic
mrg666's Avatar
You should really ask this question to Delicious. My understanding is that you buy flash&go and then buy customized_service_work.
Old 06-26-2017, 11:06 PM   #4038
twag4
Drives: frs
Delicious will sell a base tune, get you to datalog, then make any adjustments needed. You then flash revised tune then datalog again. They then check to make sure it is a safe tune for you. Works well!
twag4 is offline   Reply With Quote
The Following User Says Thank You to twag4 For This Useful Post:
kevin.nguyen (06-27-2017)
Old 06-29-2017, 03:53 AM   #4039
arthur93
Drives: Toyota 86 GTS
Hi. Would anyone be able to set me know the size of the intercooler (length, height and thickness) of just the core as we as total packaging? I have checked quite a few pages here as well as Jackson Racing's website but haven't found anything. Thanks in advance!!
arthur93 is offline   Reply With Quote
Old 06-29-2017, 04:13 AM   #4040
CSG Mike
CSG Mike's Avatar
24x6x2?
I think.
arthur93 (06-29-2017)
Old 06-29-2017, 08:58 PM   #4041
eherschend
Just out of curiosity, is it worth it to purchase an ace header to replace my existing HKS?
eherschend is offline   Reply With Quote
Old 06-30-2017, 04:36 AM   #4042
CSG Mike
CSG Mike's Avatar
if you want more power? Yes.
Old 06-30-2017, 07:37 AM   #4043
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Am I the only one who continually has issues with my oil spacer plate slowly leaking from underneath? Everytime I change the oil I have the issue. The only way​ to resolve it is to tighten everything as hard as possible. That doesn't seem correct. I'm out of ideas.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 06-30-2017, 10:56 AM   #4044
Ron B Avery
Ron B Avery's Avatar
Drives: 2017 86 Coupe
I am looking at the Jackson supercharger for my 86. Is it a good idea to add the Jackson oil cooler? And a oil/pressure temp gauge? And if so witch one and where do you mount them so they don't looked tacked on. The car will mostly be driven on the street with the occasional track day.
Ron
2017 Toyota 860 Halo White, TRD springs, TRD air filter, Center consul arm rest lid, Magnaflow cat back exhaust, Pioneer SPH-DA120 head unit with Apple CarPlay,
TRD sway bars , 17" 949 Wheels Beryllium finish, Michelin Pilot Super Sport tires, 225/45 ZR 17, Garage Vary Kouki splitter
Ron B Avery is offline   Reply With Quote
Old 06-30-2017, 11:06 AM   #4045
Kylebrz
Kylebrz's Avatar
Drives: 2013 subaru brz
. You can get the vent adapter by glow shift
Kylebrz is offline   Reply With Quote
Old 06-30-2017, 11:52 AM   #4046
-Phil
Drives: Rb25 neo brz
Ron
An oil cooler kit is almost a must when you do any kind of forced induction on these cars, If you are tracking the car it is required. The Jackson racing oil cooler works great and fits well with the kit so its a no brainier.
As for the gauges a lot of people coming in have been getting ortiz custom pods as of lately which is an entire new bezel piece that integrates the gauges into the bezel and looks fairly decent, we have also done a few gauge installs in the glove compartment which are nicely tucked away until you need your readouts.
-Phil
-Phil is offline   Reply With Quote
The Following User Says Thank You to -Phil For This Useful Post:
mrg666 (06-30-2017)
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
