Old 06-27-2017, 06:11 PM   #43
mazeroni
Drives: 2013 Scion FR-S Series 10
Originally Posted by dinfern22 View Post
Guys off topic question, How come my rear tires screech so much, and lose traction? Even if I add a little gas on 1st or 2nd gear the tires screech. Even turning from a deadstop causes the tires to make noise, at parking lots, stoplights? I live in Maryland, so the weather is in the high 90's. Its definitely the tires and not other parts like brakes etc.
The car only has 11,000 miles on it, and I just recently been doing some powerslides?
Has that always happened? The differential in these cars lock the wheels 50:50 under power, right? So if you are turning, the outside wheel (I think) is forced to turn slower and 'skips' and sounds like you are peeling out.
I think power sliding is great. I did it once in the rain when making a U-turn onto a 2 lane road - then never again. I maintained control, but was not expecting the car to slide as much as it did. I ended up sliding left to right to left to right between the lanes. I was so surprised that I couldn't think to ease my foot off the gas to straighten out. Once I got it straight enough I just dumped the gas and thankfully didn't spin out.
mazeroni is offline   Reply With Quote
Old 06-27-2017, 06:25 PM   #44
Originally Posted by allowe View Post
This is what happens when you powerslide a lot. at a good like at your tires, you probably fried the contact surface between your tire and the road. Mine do that too
How is that possible, I started doing them maybe 1 or 2 months ago??? Plus I only do one powerslide a day.
Shit, I hope not! Im not trying to buy new tires
The Primacy tires were purposely chosen for their ability to break traction at relatively slow speeds.
They are not ruined, you have not "fried the contact surface", and all is fine. You would have to do a shitload of "power slides" to burn out your tires that fast.
dinfern22 (06-27-2017), why? (07-04-2017)
Old 06-27-2017, 06:28 PM   #45
Glad you said "ease" since lifting too quickly in that situation can cause lift over steer and instead of straightening out you make things even worse.
Old 06-27-2017, 06:28 PM   #46
driftartist
Kurenai Samurai
driftartist's Avatar
Drives: Red and manual
How do people manage to crash into things while powersliding??Do they go really fast into a turn, or does the car just keep turning and crash? I feel like with this car its super easy to control and the likelihood of it happening is very little.
Even being a beginner at powersliding I always manage to get control of the car with a quick simple counter steer.
some people are not as keiichi tsuchiya as you. some are kids who are just starting to learn and some dont have as much coordination.
i dont mean this to be a ****. just messing around lol. enjoy the car
driftartist is offline   Reply With Quote
Old 06-27-2017, 06:30 PM   #47
Ketchupy sushi?
That sounds horrible
arxm (06-28-2017), driftartist (06-30-2017), soulreapersteve (07-04-2017)
Old 06-27-2017, 06:30 PM   #48
dinfern22
dinfern22's Avatar
Drives: 2016 Scion FR-S(Halo)
They are not ruined , you have not "fired the contact surface", and all is fine. You would have to do a shitload of "power slides" to burn out your tires that fast.
That's a relief to hear, thanks!
Is there a way to tell when the tires contact surface has burned off, or when I need new tires? Is it a visual check or from the feel of driving, how can you tell?
....Think Ill keep powersliding to a minimum, being a college student, can't afford to be buying new tires often unnecessarily.
dinfern22 is offline   Reply With Quote
Old 06-27-2017, 06:32 PM   #49
Old 06-27-2017, 06:33 PM   #50
dinfern22
dinfern22's Avatar
Ketchupy sushi?
Hahhaha that's how i first read it!
Old 06-27-2017, 06:34 PM   #51
allowe
allowe's Avatar
Can't stop powersliding! Doing any harm?
It's possible to waste tires in a single day. I know this from experience.
It won't hurt to look at your treadwear. Just go behind your rear tire (make sure handbrake is on) and see if the tread in the middle is a bit faded. Compare it to the front tires.
Also, rotate your tires for even treadwear.
Note: to waste them in a single day you'd have to be doing a lot of burnouts and drifting.
allowe is offline   Reply With Quote
Old 06-27-2017, 06:36 PM   #52
dinfern22
dinfern22's Avatar
Guys will powersliding in the rain still cause my tires to wear out? Or do they not wear out the tires contact surface because the wet road is slippery?
This way I can stick to doing them only when it rains!
Old 06-27-2017, 06:39 PM   #53
allowe
allowe's Avatar
Not as fast as powersliding on dry roads.
Please be careful too. It's so much fun.. until you bend a rim and a toe arm hitting a curb
That's supposed to be straight..
The Following User Says Thank You to allowe For This Useful Post:
Old 06-27-2017, 06:41 PM   #54
dinfern22
dinfern22's Avatar
Jeez... Did you have to replace it yourself or did you take it to a shop?
I'm guessing this happened from adding too much throttle on a powerslide and loss control hitting a curb?
Old 06-27-2017, 06:45 PM   #55
allowe
allowe's Avatar
Too much throttle.. actually wide open throttle.
It's right under the lower control arm
I smashed a curb going way too fast on a left turn. I'm an idiot for doing so but it was fun still.
I had to replace:
Toe arm
Rim (it was bent pretty bad)
Wheel hub assembly (bearing got wrecked)
Lower control arm.
All in all it costed me about 500ish usd because I did all the work myself. I just got it inspected by a dealership to let me know what's screwed up
Old 06-27-2017, 07:16 PM   #56
If anybody burns through a set of tires while street driving in one day they are a menace and moron.
If you are just wearing the "middle" you don't have the right air pressure.
Don't need to compare to the front tires since that is what wear bars are for.
You did get the rotate part right though.
Spoiler that with help performance but not harm mpg? DVNARC Scion FR-S / Toyota 86 GT86 General Forum 58 08-17-2015 10:34 AM
4 way stop. paulca Other Vehicles & General Automotive Discussions 43 02-19-2015 01:15 AM
Stop me if you've heard this one! Sincerely, Sam Scion FR-S / Toyota 86 GT86 General Forum 21 11-22-2014 06:41 PM
Please... Stop... Me.. moda3 Great Lakes 4 12-09-2011 12:51 PM
