Old 05-19-2017, 11:27 AM   #15
Shady195
Drives: '13 10 Series FRS #1203
Keep in mind your suspension is just hanging right now, on the ground at full lock it will be less than that, mine looks liek A LOT more in the air than it does on the ground
I really wish i could find the pic I took with my megan inners at full lock on the ground. grrr
Shady195 is offline   Reply With Quote
Old 06-22-2017, 01:13 PM   #16
cheeseburger
IG: @_southwell_86
cheeseburger's Avatar
Drives: Rwd Prius.
@TylerLieberman what tie rods would you recommend from your experience?
cheeseburger is offline   Reply With Quote
Old 06-29-2017, 12:44 PM   #17
timandytimandy
Wanna-be
timandytimandy's Avatar
Drives: 2013 Firestorm FR-S
Dang drifters is another option for knuckles. Apparently gets a little more angle than the pbm mod. His are $220 and you don't need tie rods are ends.
timandytimandy is offline   Reply With Quote
Old 06-29-2017, 08:59 PM   #18
tato.valverde
tato.valverde's Avatar
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
I highly doubt you can get more angle than with the PBM if you don't change tie rods at all...
tato.valverde is offline   Reply With Quote
Old 07-04-2017, 04:12 PM   #19
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Megan, which are really just rebranded Hard Race units.
Old 07-12-2017, 04:13 PM   #20
Shady195
I would NEVER buy these from Russ. He lists them on his site and posts them on forums acting like you just bolt them right on your stock FR-S and go ham. Never mind the fact that there is no real testing or evidence of any of the claims he makes about them other than "One of my customers replaced his PBM knuckles with these and said he gets a lot more angle"
I'm pretty sure he just copied the PBM knuckles and modified the cut a bit. (they may just be an exact copy) Theres only so many ways you can cut and re-weld and knuckle and there are two different reputable companies that have actually tested their product and have people using them.
I would never in a million years recommend buying those knuckles
You can't. He's full of BS.
The Following User Says Thank You to Shady195 For This Useful Post:
tato.valverde (07-14-2017)
Old 07-12-2017, 05:40 PM   #21
timandytimandy
Wanna-be
Ok dude don't buy em them. Few local dudes run em with no problems.
Drop Knuckles instead of lowering Springs or Coilovers FRSPacNW DIY (Do-It-Yourself) Guides 19 10-09-2017 12:42 AM
PArt Shop Max Roll center knuckles. laextreme5 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-14-2017 09:07 PM
Wisefab knuckles Ryaquinn Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 03-27-2014 12:28 AM
