Old 04-08-2017, 12:54 PM   #1
sid94
Drives: 2013 frs
PBM modded knuckles
Looking to get more steering angle out of the car I tried searching to see if anybody had done a review of the pbm knuckle mod, not the entire kit just the knuckle mod but I didn't find anything. I have the megan racing inner tie rods already but I still want more.
200 and a week maybe 2 of down time on the car isn't a bad deal for a set of knuckles. Or do you guys have any other alternatives? All opinions are appreciated!
sid94 is offline   Reply With Quote
Old 04-08-2017, 01:02 PM   #2
Shinchu
Shinchu's Avatar
Drives: 2016 FR-S Asphault MT
Search for ambush drift on youtube. He has the angle set and posts here as @Gatorbush. His vids go over the installation and how well it has been performing for almost a year since.
TEAM HINGA | Shift-Lock.net | Club4AG
http://www.poweredbymax.net/
Shinchu is offline   Reply With Quote
Old 04-08-2017, 09:01 PM   #3
sid94
Drives: 2013 frs
Saw the videos but he has the entire kit, what I'm talking about is just the knuckles
Old 04-10-2017, 12:19 PM   #4
liquidsky44
liquidsky44's Avatar
Drives: AVO Turbo Subaru BRZ / Subaru WRX
Did you ordered the knuckles? I ordered mine but it still not shipped out to me after 2 months. Still waiting...
AVO Turbo|Essex AP Sprint Kit|AVO Overpipe|HKS Hi-Power Spec L Catback|Cusco Engine Mounts|Whiteline Bushings|KW Clubsport|Defi Advance ZD|AEM Wideband Failsafe Gauge|Greddy ProFec Boost Controller|Tomei 2Way LSD|AEM Water/Meth Kit|PBM Angle Kit + Kunckles|Flatwell LCA|HKS Oil Cooler|Greddy High Cap. Diff Cooler|Sard ATF Oil Cooler|CSF Radiator|
liquidsky44 is offline   Reply With Quote
Old 04-10-2017, 12:59 PM   #5
tato.valverde
tato.valverde's Avatar
Drives: Scion FRS RS1.0,Mazda MX-6 2.5i 4WS
The knuckle mod they do is intended to work only for their angle kit (and probably soon to be obsolete due to their new knuckles being finally available). In order to run the knuckles alone, they would have to custom make you outer tie rods that work with the knuckles. Do-able, but not just 200 anymore
tato.valverde is offline   Reply With Quote
Old 04-11-2017, 03:33 PM   #6
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
If all you want is a knuckle, look elsewhere as there are quite a few people who offer solutions.
Or just get tie rods and be done with it. $80, yields 80-90% of the angle you'd get from modded knuckles, and can be done within an hour, easily. No downtime for the car needed.
Unless you're running higher power levels, the PBM kit isn't really all that useful anyways. Only time you'll really use it is if you screw up. Otherwise, a simple knuckle or tie rod solution will suffice.
TylerLieberman is offline   Reply With Quote
The Following User Says Thank You to TylerLieberman For This Useful Post:
DavidBob (04-20-2017)
Old 04-14-2017, 09:59 PM   #7
sid94
Drives: 2013 frs
I did not, they told me that I would need the tie rod spacers along with the flca because they would rub on the stock control arm
Yea I'll figure out what else I can do and when I get more power I'll probably get the full kit
Old 05-15-2017, 09:34 AM   #8
liquidsky44
Just a FYI for those running the Essex AP Sprint kit and intending to get the new PBM knuckles. They will not fit. You would need to customized a new bracket for the Sprint Kit BBK.
The Following User Says Thank You to liquidsky44 For This Useful Post:
tato.valverde (05-15-2017)
Old 05-15-2017, 02:02 PM   #9
Shady195
Drives: '13 10 Series FRS #1203
Eh, I wouldn't go quiet that far. I've had both, its a pretty dramatic difference.
Shady195 is offline   Reply With Quote
Old 05-15-2017, 02:13 PM   #10
TylerLieberman
Drives: '24 GR86
I would. Having driven on and installed both, and while there's a noticeable difference, it's not like the tie rods by themselves are not a valuable option. Knuckles by themselves are also a good option.
The biggest difference is that the knuckles will help decrease ackerman, while simply adding tie rods will increase it. Also, the knuckle will allow steering to react faster, but the tie rods is just adding more rotation lock to lock.
That being said, the knuckles give you quicker steering with less scrub, while the tie rods add some scrub and just require more steering rotation lock to lock. That's probably a big part of the differences you're noticing.
Hostile_Kittens (07-04-2017)
Old 05-19-2017, 09:14 AM   #11
Shady195
The angle difference between just the Inner tie rods and the knuckles is quite substantial, this is also having driven and installed both.
This is close/at full lock with Knuckles.. You're not getting anything close to this with the megan inners.
Old 05-19-2017, 09:26 AM   #12
Shady195
BTW Tyler, I'm not trying to be a ****. You seem to have a lot more experience under your belt than me
While the tie rods do add some, I find if you plan to get knuckles or anything of the sort in the future, you're better off saving the 80 bucks.
The Following User Says Thank You to Shady195 For This Useful Post:
TylerLieberman (05-19-2017)
Old 05-19-2017, 11:04 AM   #13
TylerLieberman
Drives: '24 GR86
No worries man. We're allowed to have our separate opinions. It's all good. I actually agree with your statement though. Knuckles by themselves are probably the best option, as it gives you a good angle increase and eliminates some ackerman. It's also a reasonable price, typically $300-$400. If you plan on doing knuckles in the future, just do that and not spend the time with tie rods.... or you can do both lol. Might need offset spacers for the tie rods though so they don't bind.
The picture above is of my car with tie rods, but prior to alignment. I just eye balled it. The car had a bit of toe-in when it got up on the rack, so the car had a touch more when everything was said and done. As you can see, it really isn't far off from what your knuckles gave you. Roughly 80-90% compared to stock.
Old 05-19-2017, 11:14 AM   #14
TylerLieberman
Drives: '24 GR86
I flipped my image and put them together to show. Granted, the view is different, but it gives an idea.
The knuckles give more angle for sure, but it really isn't that big of a difference between the two. For $80, I still think the tie rods give really good value. The stock steering angle is pitiful. I would hit lock all of the time it was kind of annoying. With the tie rods, I would still hit lock, but it felt it was nowhere near as much. Gave a lot more room for big transitions without the worry of spinning out. Removing the front sway bar helped too with the snappy tendency of the front end.
The car that I drove with knuckles felt very similar to mine (we basically had the same exact setup) except his steering felt much faster. That felt perfect. If I were to do it again, I'd definitely do knuckles. However, I still stand by the tie rods for people just starting out and learning. In fact, I'd add it to the list for starting out. Coilovers, LCAs + alignement, tie rods. Those 3 things make the car much better. All of which can be done for like $1500.
theneptune86 (05-20-2020)
Drop Knuckles instead of lowering Springs or Coilovers FRSPacNW DIY (Do-It-Yourself) Guides 19 10-09-2017 12:42 AM
PArt Shop Max Roll center knuckles. laextreme5 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 03-14-2017 09:07 PM
Wisefab knuckles Ryaquinn Suspension | Chassis | Brakes -- Sponsored by 949 Racing 25 03-27-2014 12:28 AM
