go_a_way1
Old 05-28-2017, 11:55 PM   #3487
BRZMAFIA
BRZMAFIA's Avatar
Drives: 2017 BRZ Limited
Hey guys,
2017 BRZ Limited with PP. I think I've confirmed RPF1 17x9 +35s will not fit over the Brembo brakes but anyone know if Volk Racing CE28SL 17x9.0+44 would fit?
Thanks!
BRZMAFIA is offline   Reply With Quote
Old 06-02-2017, 04:34 PM   #3488
Zoid
Zoid's Avatar
Drives: 2015 Subaru BRZ Series.Blue CWP
So my car came with some Ironman iMove tires size 215/45ZR17 on the OEM STI wheels. Dunno how I feel about these, from what I've been able to dig up they seem like cheap Chinese tires. But apparently they're made by Hercules which is a cousin to Cooper? Either way I've never heard of any of these companies.
I'm looking into replacing them with some Michelin PSS and what I really want to know is, how wide a tire can I run on these wheels and how will it affect performance/mpg?
Zoid is offline   Reply With Quote
Old 06-07-2017, 02:03 PM   #3489
Helios
Helios's Avatar
Drives: 2014 Red Subaru BRZ
So, I bought these.
4pc 25mm (1") 5x100 to 5x110 Wheel Adapters/Spacers for any 5x100
I have a set of (4) 5x110 x 55mm offset wheels with 245/45/ 18s. I read as much as I could and I think I should be ok, but the 1" adapter/ spacer is where I'm not sure it will affect as far as fitment. Will the spacers cause the wheels/ tires to be out of the wheel well? If so, how much? Comments?
Helios is offline   Reply With Quote
Old 06-09-2017, 07:34 PM   #3490
Phothiraj
Drives: Lightning Red BRZ
I have a 13 brz lowered about 4inches all around. Can i fit 18x9.5 square with 255-35-18 tires?
Phothiraj is offline   Reply With Quote
Old 06-16-2017, 09:00 PM   #3491
Helios
Helios's Avatar
I found out that what I wanted to do would stick out 1-1/4" past the wheel well. No bueno...
Old 06-22-2017, 02:31 AM   #3492
Waffle86
Waffle86's Avatar
Drives: 2013 SWP BRZ Limited
Considering a meatier 18x9.5 +38, 255/35/18 or 255/45/18 square setup. I'm planning to get Tein Street Basis coils at the same time.
What is the likelihood of running this setup w/out rubbing issues if I don't want to roll fenders or adjust camber?
Waffle86 is offline   Reply With Quote
Old 06-22-2017, 10:45 AM   #3493
dattran86
Driver
Drives: 2013 Whiteout FRS
45 sidewall is too big for 18s, stick with 35.
dattran86 is offline   Reply With Quote
Old 06-22-2017, 10:56 PM   #3494
Waffle86
Waffle86's Avatar
Thanks. So 255/35/18 would fit just fine without any fender work or camber?
Old 06-23-2017, 09:25 AM   #3495
dattran86
Driver
you probably need to dial in more negative camber depending how low you're going.
the rear might work but the front definitely will rub without rolling or negative camber.
its all depends on your ride height.
Old 06-23-2017, 08:22 PM   #3496
Waffle86
Waffle86's Avatar
not sure yet, somewhere between 1.5 - 2inch drop. Sounds like i might be better off going 245/35/18 if i want to keep it simple?
Old 06-23-2017, 10:46 PM   #3497
dattran86
Driver
yes 245s would fit better.
Old 06-24-2017, 01:04 PM   #3498
BadMOFO
BadMOFO's Avatar
Drives: 2016 Scion FRS Raven Black
I can get my hands on some Stock 07 STI BBSs for practically nothing with great all seasons on them. Which I know are 5x114. My question is using the adapter from 5x100 to 5x114 will there be any issues at stock ride height. As well as if I throw a set of springs on.. will there be any issues then? Any input would be greatly appreciated. THANKS!
BadMOFO is offline   Reply With Quote
Old 06-28-2017, 03:37 AM   #3499
Captain.K
Captain.K's Avatar
Drives: 2015 FRS Firestorm Red
im looking to run 255/35/18 federal rsrr on 18x9.5 +38 wheels to see if they fit and from what i hear they run slightly wider so im wondering if anyone is running that setup with JUST COILS preferably Tein Flex Z or Apexi and have pictures of there fitment
Captain.K is offline   Reply With Quote
Old 06-30-2017, 05:08 PM   #3500
Longjohnstrokems
Drives: Red Scion FR-S
Anyone know if 17x8.5 +30 offset will work with stock tires and also fit stock height?? Will also be lowering about an inch and a half soon as well.
Longjohnstrokems is offline   Reply With Quote
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 10:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 03:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 03:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-13-2012 12:21 AM
