Old 06-17-2017, 09:39 PM   #15
Originally Posted by Scrappydoo View Post
?....Are you feeling OK?
....... ..... am I feeling OK ....??
YOU ..... are asking .... ME ....if I'm feeling OK ........
Well, thanks for your concern ....... I'll check with mrs humfrz for a reading .....
Old 06-18-2017, 03:51 AM   #16
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Is she a fortune teller?
Scrappydoo is offline   Reply With Quote
The Following User Says Thank You to Scrappydoo For This Useful Post:
humfrz (06-18-2017)
Old 06-18-2017, 04:57 AM   #17
T-Steve
Drives: 2014 BRZ
Ha! In the automotive trades extractors are being used more and more. I've used this for numerous engine, transmission, differential, brake fluid, and power steering removals with great success.
https://www.amazon.com/Pela-PL-6000-...+oil+extractor
(be sure to clean between applications...)
But you know what? There is nothing like draining every last bit from the drain plug.
T-Steve is offline   Reply With Quote
The Following 2 Users Say Thank You to T-Steve For This Useful Post:
humfrz (06-18-2017), Somerandom18 (06-18-2017)
Old 06-18-2017, 01:43 PM   #18
Ernest72
oil changes are pretty easy. Do it the right way.
The Following 2 Users Say Thank You to Ernest72 For This Useful Post:
DandoX (06-20-2017), humfrz (06-18-2017)
Old 06-18-2017, 02:44 PM   #19
Obviously not, or she wouldn't have married me ........
Old 06-18-2017, 03:03 PM   #20
Ahhhh....... Portlandia ...... suck stuff out.........
And ..... wouldn't that have to be a pain to have to flush the sucker out after each use .. ??
And .... if the manufacture wanted oil to be sucked out of the sump ...... they would have put in a tube that reached all the way to the bottom.
And ....what about the "sludgie" stuff in the very bottom of the sump, wouldn't that just accumulate in time .. ??
And ...... when the magnetic drain plug gets all "filled up" with metal particles, it wouldn't be able to hold any more and stuff would just be circulated in the oiling system .... ??
And ...... how would you know you got all the old oil out ... ??
And ...... gravity is free ...... sucker machines cost money.
(popcorn - reminds me, I took mrs humfrz to the picture show last night ..... yep, bought that sweet pea of mine a medium popcorn (with butter) ....... we saw "Wonder Woman" ....... oh, I want her ..... )
Old 06-18-2017, 05:19 PM   #21
RickyBobby
Drives: 2013 Firestorm FR-S AT
https://www.edmunds.com/how-to/the-t...il-change.html
From the article:
"Can You Get All the Oil Out?
While researching this story, we found that some people have posted Internet messages saying they are doubtful of this method. Wouldn't there be some oil left in the lowest part of the oil pan? And wouldn't this oil contain harmful sludge? Sludge is actually an extremely harmful gelling that occurs when water is combined with oil. This has little to do with a successful oil change.
Skeptics were probably intending to say they wanted all particulate matter removed along with the old oil. If the car has been warmed up before the oil change, as recommended, any particulate matter would flow out with the oil."
Ok, to be fair this is not an apples to apples comparison. I have no idea how the FRS oil pan is shaped, and if there is still oil left in the pan after a conventional oil change. I would assume that if the front of the car is elevated, i.e. ramps or a jack, all the oil should come out; but what about when it's level, i.e., on a lift.
RickyBobby is offline   Reply With Quote
Old 06-18-2017, 06:27 PM   #22
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
That's the one I have. Works perfectly.
Old 06-18-2017, 07:13 PM   #23
Wyatt2617
Wyatt2617's Avatar
Drives: 2015 Subaru BRZ Series.Blue
I have never heard of a dealership using a vacuum to suck oil out.. If the vehicle was supposed to be vacuumed out, why do they come with drainplugs from factory?
I've only heard of Walmart using vacuums.
Sent from my SM-G935P using Tapatalk
Wyatt2617 is offline   Reply With Quote
Old 06-18-2017, 10:56 PM   #24
stevesnj
stevesnj's Avatar
Fight the power SUCK that oil!!!
My 2016 Build thread
The Following User Says Thank You to stevesnj For This Useful Post:
Tcoat (06-19-2017)
Old 06-20-2017, 03:13 PM   #25
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Fumoto valve. Done.
No sucking required, unless you're gulping down a juice box or something.
Cockatoo is offline   Reply With Quote
Old 06-20-2017, 03:31 PM   #26
Originally Posted by Cockatoo View Post
Fumoto valve. Done.
Old 06-20-2017, 04:06 PM   #27
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Yum, love me some or somethings.
But yeah, love my Fumoto drain valve even more. But I do see the benefit of sucking the oil out if you don't have a jack/jack stands.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
Scrappydoo (06-20-2017)
Old 06-20-2017, 04:44 PM   #28
Scrappydoo
Scrappydoo's Avatar
Drives: Grrrr
Then it mustn't be true.
Vacuum pump oil USMCgetsome Engine, Exhaust, Transmission 4 12-10-2016 09:16 AM
Vacuum at idle.... BadBRZ Forced Induction 1 08-30-2014 01:47 AM
Vacuum Leak?? woode Forced Induction 31 05-25-2014 05:09 AM
Affordable vacuum? swift996 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 21 04-02-2014 07:21 PM
Vacuum help! Scalzo Forced Induction 6 06-26-2013 03:12 PM
