| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Whiteout FRS
Vacuum for Oil Change?
Hey guys,
I was looking into getting a vacuum pump for oil changes. Any recommendations or steps I should take you guys recommend? Thanks guys! |
#2 |
#3 |
Drives: GR Corolla
#4 |
#5 | |
Drives: Grrrr
Only tip would be to make sure the oil is warm so it flows. |
#6 | |
If you push a flexible sucker tube down the oil dip stick tube, how are you going to insure it reaches all the way to the bottom of the sump ..... since the tube makes that sharp bend where it goes into the engine ....... ?? Or, is there another way into the sump ... ?? humfrz |
#7 | |
Drives: Grrrr
The vacuum pipe is flexible and you can tell when it reaches the bottom of the sump as it stops going in any further. Men on the moon. Can you believe it ![]()
#8 | |
![]() Now, tell me just how you know you are getting all the food out of the bottom of your food dish ...... ![]() humfrz |
#9 | |
Drives: Grrrr
#10 |
Drives: 2013 Firestorm FR-S AT
@shellslinger
Search and ye shall find. http://www.ft86club.com/forums/showt...ght=vacuum+oil I use this one: https://www.amazon.com/gp/product/B001445IZ8/ Works well. Run the car for a couple of minutes to warm up the oil; clamp the vacuum tube, pump 35-40 times, insert the vacuum tube into the dipstick tube until you feel resistance, open clamp, suck. Total time: ~10 minutes. Empty the container into an empty 5 qt oil jug to make sure you sucked all the oil out. It should fill the jug with ~1/2 qt of oil left in the container. In 4 years I've used only this method to change my oil. If you have problems removing all the oil you can remove the dipstick tube by removing 1 small top bolt, pull the dipstick tube out on the bottom (held in by a small O ring), and insert the vacuum tube directly into the sump. Last edited by RickyBobby; 06-17-2017 at 03:22 PM. |
#11 |
OK, folks, here is how it comes down when Scrappydoo (SD) goes into a shop to have the oil changed by a technician (T).
SD - I'd like to have the oil changed in my twin T - OK, but we use a vacuum device to remove the used oil SD - fine, but can I watch? T - sure, see, I'm inserting the vacuum tube in as far as it will go. Now, I turn on the pump ....see bubbles ..... ahhh, here comes the oil, see it in the container. Now, hear the vacuum pump running freely, and only air bubbles in the container, so all the oil is out of the sump. SD - ah, cool SD - as he is paying. How much oil did it take to fill it back up? T - about a quart ..... I reckon your car has a small oil sump. SD - yep, I reckon so humfrz |
#12 |
TRACKBREAD
I prefer a drain valve. Fumoto makes a great one.
I've never seen a dealer except Mercedes use a vacuum though. Most new cars don't even have a dipstick anymore to use for that. I don't like the idea on our weird dipstick setup though. It's hard enough to get a consistent reading on the damn thing. If it went directly into the pan It'd be better. |
#13 | |
Thupercharged
Crack the drain bolt after you vacuum all the oil you can and be slightly surprised that virtually no oil drips out. I've used my pump on this car for the last 30K miles, and my old E36 for easily double that.... if the oil filter is on the top of the engine, it makes for a nice easy oil change. I crawl under the Saabaru to drain oil because it doesn't require ramps to get under and the oil filter is underneath the engine, negating the "clean" aspect of a vacuum oil change with a top mounted filter. I was very skeptical at first, but I see the value now.... also helps with draining/filling other fluids as most models have a pump feature to empty the contents into disposal jugs.
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
#14 | |
Drives: Grrrr
| Vacuum pump oil | USMCgetsome | Engine, Exhaust, Transmission | 4 | 12-10-2016 08:16 AM |
| Vacuum at idle.... | BadBRZ | Forced Induction | 1 | 08-30-2014 12:47 AM |
| Vacuum Leak?? | woode | Forced Induction | 31 | 05-25-2014 04:09 AM |
| Affordable vacuum? | swift996 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 21 | 04-02-2014 06:21 PM |
| Vacuum help! | Scalzo | Forced Induction | 6 | 06-26-2013 02:12 PM |
