Old 06-16-2017, 04:05 PM   #29
drz400dude
My temps are in F, are yours in C? How are your intake temps so low? It was about 80F in the garage when I ran that. My pump is running and my coolant is topped off.
Yea my pump is running
Originally Posted by woomis View Post
Look at your Intake Temps! I'm on the same kit and my temps are 34 average. 51 MAX if I'm sitting at a light and it's 100deg outside.
Check your intercooler on top (only when you're 100% sure it's cooled off enough to safely check) -- Check inside and make sure coolant in there is nice and topped off and hasn't leaked out and make sure your water pump is running It should be plugged into the windshield wiper fuse and should be heard while key ON without engine on.
drz400dude is offline   Reply With Quote
Old 06-16-2017, 04:28 PM   #30
woomis
Drives: 2016 FRS Release Series 2.0
I was hoping that was the case.
Your logs are tough to read... Post a CSV with default parameters.
woomis is offline   Reply With Quote
Old 06-16-2017, 04:31 PM   #31
woomis
Nevermind -- I actually just watched the video for the first time. That's the DI Pump (it's mechanical and is very much affected by the CAM). You may have the new 2017 GDI tables or something -- I'd have to see the tune.
PM me the tune Works gave you and I'll compare to mine. Anything special you want with it? E85/91 - Is it UEL or EL? Ecutek/OFT? I have this tune a few different ways....
Old 06-16-2017, 07:52 PM   #32
drz400dude
No the file name says 2014. I sent the csv file to works and they said it looked fine. I was just worried about the noise, but everything seems to be OK.
Idle knocking noise Kostamojen Issues | Warranty | Recalls / TSB 33 04-20-2018 01:09 PM
Rear end clicking noise after spring install Nhil Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 07-16-2017 09:44 PM
Knocking noise from LSD after FD swap Toyota86.ir Engine, Exhaust, Transmission 15 11-08-2015 03:02 AM
Loud clicking sound when slowing down in neutral I like the tuna here Issues | Warranty | Recalls / TSB 1 05-02-2015 12:03 AM
loud knocking constant with engine speed whatsmynameagain Issues | Warranty | Recalls / TSB 34 12-09-2014 09:58 PM
