Old 05-25-2017, 02:03 PM   #85
MJones_RB
MJones_RB's Avatar
Drives: Scion FR-S Series 10 #2462
Originally Posted by maximtheg View Post
My apologies for bringing back this thread, but I'm a noob and I have some questions. Will I need extended studs with any wheel spacers? I'm thinking about running the 20,25 setup. Thanks!
Only on the spacers that don't attach to the hubs with lug nuts, aka shim spacers.
MJones_RB is offline   Reply With Quote
Old 05-31-2017, 02:16 PM   #86
airindia33
airindia33's Avatar
Drives: 2020 BRZ PP
Just bought a 17 BRZ with performance package. The wheels are 17x7.5 +48 offset vs the 17x7 +48 on the regular wheels.
I am looking to run spacers but am having a hard time deciding between sizes. I don't want any poke at all if possible. I was thinking 10 up front and 20 in the rear???
Since the wheels are .5" wider they will already stick 6.35mm further out. My question is since the tire size has not changed should I really worry about the extra 6.35mm? And what size spacers should I go with?
airindia33 is offline   Reply With Quote
Old 05-31-2017, 04:47 PM   #87
KnightRyderx2
Drives: 2014 FR-S
Dont do slip on spacers in that size, no bueno. Anything above a 15mm go with a bolt on spacer. So, go with bolt on in the size you want and no need for extended lugs.
I would do 20mm front and 25mm rear, bolt on. 10mm would be to small and you would need extended lugs.
KnightRyderx2 is offline   Reply With Quote
Old 06-14-2017, 11:51 AM   #88
blkwrxwag
Drives: DS FRS
When I look on Amazon, all the 20mm bolt on spacers say they do not work with the stock wheels, but here I see a load of pictures with stock wheels.
I'm looking to use these with my stock wheels...
https://www.amazon.com/Hubcentric-Sp...07N6Y5VVT38WDT
-Max H.
blkwrxwag is offline   Reply With Quote
Old 06-14-2017, 12:36 PM   #89
KnightRyderx2
Drives: 2014 FR-S
The reason certain 20mm spacers do not fit is because the cavity design on the hub side of the OEM wheels. The cavity is shaped in a way that the nut that comes with the spacer will not fit in the cavity.
There is a couple things you can do. One is look for a bolt on spacer that uses a flat nut with dimpled key. Another is to bore out the cavity in the wheel to fit the nut.
Old 06-14-2017, 12:41 PM   #90
blkwrxwag
Drives: DS FRS
Anyone have a link to any that work?
-Max H.
Old 06-14-2017, 04:03 PM   #91
KnightRyderx2
Drives: 2014 FR-S
Check out the vender section and anyone that sells spacers have all been tested to fit. Also Perrin, Ichiba, Project Kics, and Eibach are good.
You could also just go with 25mm and be done with it.
Old 06-14-2017, 04:09 PM   #92
blkwrxwag
Drives: DS FRS
Thanks - I checked out all those. All were more than I wanted to spend and all were out of stock anyway. I was hoping some of the cheap Amazon ones would work, but I guess not.
25mm might be a bit much up front, but I'll take another look at some photos. Thanks for your help.
-Max H.
Old 06-14-2017, 04:12 PM   #93
KnightRyderx2
Drives: 2014 FR-S
Yeah all those I suggested are a bit on the high side but they work.
I have 25mm all around and they are awesome. I bought them from amazon too.
The Following User Says Thank You to KnightRyderx2 For This Useful Post:
blkwrxwag (06-15-2017)
Old 06-15-2017, 02:20 AM   #94
gramicci101
Off Topic
I have 20/25mm spacers from Corner3Motorsports. The lugs do stick through the 20mm spacers a bit, but as soon as you start to torque the wheel everything lines up. They've held up just fine for two years.
http://www.corner3motorsports.com/pr...ers-56-1-bore/
Old 06-15-2017, 12:33 PM   #95
blkwrxwag
Drives: DS FRS
Those would work. Do they damage the ends of the stock lugs at all, as I would still need to go back to them for autocross where the spacers are not legal?
-Max H.
Old 06-15-2017, 01:09 PM   #96
gramicci101
Off Topic
No they don't. The OEM wheel has pockets in the back, so there's space. The corner of the lug nut just barely touches the edge of the pocket, but it's not enough to cause any damage. It's just enough to keep the wheel from seating properly with zero effort, but like I said, as soon as you start torquing the wheel down everything sits flush.
Make sure when you install spacers that you torque them just like you would the wheel. Same value, same pattern.
The Following User Says Thank You to gramicci101 For This Useful Post:
Old 06-15-2017, 01:11 PM   #97
blkwrxwag
Drives: DS FRS
Perfect - thanks. Now to explain to the wife what I want for Father's Day
-Max H.
Old 07-06-2017, 01:14 AM   #98
rookietopro_frs
rookietopro_frs's Avatar
Drives: 2013 Scion FRS
Originally Posted by zoltiz View Post
20 front / 25 back, no drop.
OH ! Makes a big difference, might do this route instead of getting bigger wheels as of now. Just need better tires honestly & really want Falken Azenis RT615Ks
rookietopro_frs is offline   Reply With Quote
Best springs+spacers for stock wheels? retrosmiths Suspension | Chassis | Brakes -- Sponsored by 949 Racing 12 09-22-2015 08:52 AM
Spacers on all 4 corners / stock wheels (20mm/25mm) zoltiz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 09-14-2015 11:43 AM
Spacers and stock wheel studs solidONE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 08-31-2013 08:55 AM
Stock Wheels Need Spacers? theom Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-17-2013 11:49 AM
Spacers with Stock Wheels Starscream15 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 06-05-2012 01:31 PM
