Old 06-09-2017, 02:58 AM   #1023
Kodename47
Kodename47's Avatar
Drives: UK GT86
Originally Posted by Dragon780 View Post
your ltft is consistent, vs mine fluctuates a bit at times, i wonder why.
It's just what it does. There are different regions where LTFT is set, it's not a single figure for the entire range.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-09-2017, 09:25 AM   #1024
steve99
Drives: FT86
post up the datazap log, it probably need some maf scaling, f your not on stock intake
Old 06-09-2017, 01:01 PM   #1025
Dragon780
Drives: Scion FRS
Ya it's not stock
It's the ace takeda intake
I'll post the data log in a bit and maybe u guys can help me take a look
Dragon780 is offline   Reply With Quote
Old 06-09-2017, 02:40 PM   #1026
Dragon780
Drives: Scion FRS
i was playing around with romriader and compared the stage 1 and stage 2 UEL tune,
with the stage 2, why are alot of the values for everything 0?
Old 06-09-2017, 03:37 PM   #1027
Dragon780
Drives: Scion FRS
here is the data log, i did some regular driving at the beginning shifting around 2-3 rpm and after i did a pull reaching close to WOT
this time my LTFT is always around 14, i believe i do need to change the MAF scaling.
thank you for checking this for me,
Old 06-10-2017, 04:12 AM   #1028
Kodename47
Kodename47's Avatar
Drives: UK GT86
if you're comaring them, it shows you the difference so 0 means no change. The menu of the open table has an option to turn that off to see the actual values.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-10-2017, 12:14 PM   #1029
Dragon780
Drives: Scion FRS
I also opened the stage 2 up alone and those were the values
I meant compare just as in opening both maps up to look at them indivicidually
Sorry for the misunderstanding
Old 06-10-2017, 04:18 PM   #1030
steve99
Drives: FT86
if you post your logs up to www.datazap.me they are much easier to read in graphical form.
Yes look like maf scaling would benefit you ltft varying from -6 to plus 10 or more.
could not see any full throttle run to redline in that log though
Old 06-24-2017, 05:55 PM   #1031
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
Is the template added at the bottom of the first post still the most current? I am having the 0 IAM issue and am wondering if cal file "F00D" isn't current.
Edit: No MAF voltage either, probably need an update. What would be the best way to contact OFT where they aren't swamped with messages?
Weigaldo is offline   Reply With Quote
Old 06-24-2017, 07:09 PM   #1032
Buffalo_Rob
Drives: 2016 FR-S
I'm having the same problem with my cal 'F00C'. I sent openflash a message through their website 2 weeks ago and I PM'd shiv on here over a week ago. If anyone can help with this it would be greatly appreciated.
Buffalo_Rob is offline   Reply With Quote
Old 06-27-2017, 06:50 PM   #1033
Weigaldo
Weigaldo's Avatar
A potentially dumb question, but with the IAM not registering, wouldn't I be able to just monitor the timing to determine if knock is occurring? It would go negative right?
Old 06-28-2017, 05:16 AM   #1034
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
If IAM monitor is not working, then you can derive the value from the KC Learned parameter. The latter is NOT knock, but the knock correction learned ignition advance. It is derived from the "Knock Correction Advance Max A" table in ROM and multiplied by IAM and subtract FLKC.
So, you'll need to monitor Engine Load, Engine Speed (RPM), KC Learned and FLKC. You'll need to have also the table values of "Knock Correction Advance Max A".
Old 06-28-2017, 11:22 AM   #1035
Weigaldo
Weigaldo's Avatar
Thanks for the information. So while driving, FLKC and FBKC should stay around 0. FBKC will register over time but FLKC will be instantaneous. If FLKC is less than 0, the negative would added to the IAM (I can't currently see) to show the KC learned?
Old 06-28-2017, 04:19 PM   #1036
Kodename47
Kodename47's Avatar
Drives: UK GT86
Read this - Knock Control Explained
.: Stealth 86 :.
Kodename 47 DJ:
WTB: Open Flash Tablet TOZER Canada Classifieds 3 07-05-2015 07:13 PM
Open Flash Header & Open Flash Tablet Calavera Engine, Exhaust, Bolt-Ons 9 05-11-2015 08:27 PM
FS: open flash headers / open flash tablet - SOLD alanhung85 Canada Classifieds 12 02-10-2015 02:08 PM
FS: Open Flash Tablet (OFT) mex2309 Engine, Exhaust, Bolt-Ons 1 10-29-2014 02:49 PM
Open flash tablet. cooldandani Scion FR-S / Toyota 86 GT86 General Forum 1 02-22-2014 07:14 PM
