#1009 |
Drives: frs
For users with uel header its good to set it at 3000 rpms. Sounds badass
#1010 |
i think earlier units didnt have it yet. cause I clutched in, put it in first, and it let me rev higher.
I set mine to 4000 now |
#1011 | |
TRACKBREAD
Are the maps still in beta? Do they need VVT table adjustments for JDL headers like the stage 2 tunes? |
#1012 | |
Drives: FT86
The Flex maps even for NA cars wont be on website for download, you will have to email and request them from shiv |
#1013 |
Drives: Scion FRS
I would use stage 1 as long as I have stock header right? Doesn't matter if other mods like exhaust frontpipe and intake?
#1014 |
Drives: 2014 GT86
A bit other way. Stage one for catted headers, stock or aftermarket, stage two - for catless, gutted stock or aftermarket, isn't it?
#1015 | |
Drives: FT86
Stage 1 is correct map for stock header. Exhaust mods after header are ok with stage 1 map All the oft maps expect stock jntake with or eithout drop in performance filter. If you are using other aftermarket intakes you may need to rescale maf for best results |
#1016 | |
@rayhere
http://www.ft86club.com/forums/showthread.php?t=64790 Is this what you're referring to? |
#1017 | |
Drives: FT86
Yes you will need to log tune If you have large ltft like over 8% (5% or less is better) or during WOT the commanded AFR and AFR differ by more than a few percent then maf scaling is advised |
#1018 | |
Drives: Scion FRS
Which intake did u install Maybe we can share editing and map details to help eachother out |
#1019 | |
@rayhere
Sure, that might make things easier. I have a Beatrush v2 intake. |
#1020 | |
@rayhere
https://www.dropbox.com/sh/3y7k66cni...khGGP8H_a?dl=0 |
#1021 | |
Drives: Scion FRS
my ltft ranges around 3 give or take as well, but during highs it went up to 14 , the highest i rev up to during that drive was only 4200 rpm though. at one point, i was at wot but on low gear to just check out what it feels like after the tune to test the throttle responses, at the time the ltft was around 3.91 |
#1022 |
Drives: Scion FRS
your ltft is consistent, vs mine fluctuates a bit at times, i wonder why.
| WTB: Open Flash Tablet | TOZER | Canada Classifieds | 3 | 07-05-2015 07:13 PM |
| Open Flash Header & Open Flash Tablet | Calavera | Engine, Exhaust, Bolt-Ons | 9 | 05-11-2015 08:27 PM |
| FS: open flash headers / open flash tablet - SOLD | alanhung85 | Canada Classifieds | 12 | 02-10-2015 02:08 PM |
| FS: Open Flash Tablet (OFT) | mex2309 | Engine, Exhaust, Bolt-Ons | 1 | 10-29-2014 02:49 PM |
| Open flash tablet. | cooldandani | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 02-22-2014 07:14 PM |
