Old 06-05-2017, 06:50 PM   #15
airindia33
airindia33's Avatar
Drives: 2020 BRZ PP
So glad they left it off. Wonder if I can just leave it unplugged when I go to coilovers with aftermarket lower control arms.
airindia33 is offline   Reply With Quote
Old 06-05-2017, 07:23 PM   #16
Originally Posted by FR-Sky View Post
My hand-brake is my hill assist.
My right foot is mine.
Old 06-05-2017, 07:46 PM   #17
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Man on the streets of SF around 19th in the morning it would have been handy. But then I would have never learned the art of the quick foot start or the subtlety of the ebrake start. Some hills are so steep you can't not be scared, it's apart of the fun of manual transmission.
I never had a car with hill assist, how far will it let you roll back on a really steep hill?
DandoX is offline   Reply With Quote
Old 06-05-2017, 08:56 PM   #18
My question is ...... if you were going UP this hill and discovered you were going the wrong way ..... and couldn't get turned around ...... and had to back down the hill ....... would the hill assist prevent that ...... ??
Old 06-05-2017, 09:14 PM   #19
I don't recall seeing them use handbrakes on The Streets of San Francisco.
Old 06-05-2017, 09:56 PM   #20
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
It doesn't hold it indefinitely.
Old 06-05-2017, 10:13 PM   #21
DandoX
Senior gif poster
DandoX's Avatar
I'm not a badass I guess.
Because this is exactly what driving in SF is like:
Old 06-05-2017, 10:23 PM   #22
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
http://www.ft86club.com/forums/showthread.php?t=98870
pushrod is offline   Reply With Quote
Old 06-09-2017, 05:44 PM   #23
Speedinbai
Drives: 2017 brz
Originally Posted by sunami88 View Post
My Dad has an 08 Mini Cooper and it's hill holder (enabled by default- in fact I don't think you can turn it off at all) is by far and away one of my favourite features.
Please tell me that in the 86 at least once it's enabled it persists through key cycles, otherwise I'd wonder why they added it at all. Would have loved to have had that particular feature on my '16, but still no regrets.
It does but it is totally useless and makes one stall unnecessary on the tiniest of "hills"(bumps)
Sent from my SM-T810 using Tapatalk
Speedinbai is offline   Reply With Quote
Old 06-09-2017, 06:08 PM   #24
GhostRai
Rice Monkey
GhostRai's Avatar
Drives: 2017 Subaru BRZ Sport-Tech WRB
The hill assist on the 2017's hold you for ~3 seconds if you are facing an uphill in 1st gear, or facing downhill in reverse gear, it doesn't let you roll back at all. On very slight inclines it won't hold you and you will roll back slightly as normal. Once you can feel the clutch grab, the hill assist does disengage itself, but if you don't give it enough gas it will hold the brake enough to/almost stall the car.
"Why must everything that is broken be fixed?"
GhostRai is offline   Reply With Quote
Old 06-09-2017, 08:37 PM   #25
Speedinbai
Drives: 2017 brz
It activated on any incline in my car even ones that I couldn't tell were there
Old 06-09-2017, 11:57 PM   #26
Borchert97
Borchert97's Avatar
Drives: 2017 Toyota 86
Originally Posted by Train View Post
My dealer said there's supposed to be one...When I test drove it, it still rolled back...
I don't remember the exact combination but I looked in a 2017 BRZ manual at the Subaru I work at and you have to do some combination of the track and traction control buttons to turn it on, the car comes with it set off by default, which is odd because on the WRX and STI it comes set to on by default.
Edit: I do see that someone already supplied the "cheat codes".
Borchert97 is offline   Reply With Quote
Old 07-06-2017, 08:03 PM   #27
psionix
Drives: 2017 WRBP BRZ MT
Is the hill assist light always on once activated? Mine is always lit.
psionix is offline   Reply With Quote
Old 07-06-2017, 08:13 PM   #28
mrg666
pessimistic skeptic
mrg666's Avatar
No hill start, no hand brake. If you can't balance your car with the clutch and avoid stall, you just don't know how to drive manual. That is it.
Anyone planning HAC (Hill Assist) retrofit? Zardoman Engine, Exhaust, Transmission 28 06-06-2017 11:52 PM
Question regarding Hill-start assist control rkaywhodat Scion FR-S / Toyota 86 GT86 General Forum 17 09-30-2016 05:47 AM
Tuner Battlegrounds 2015 - Need an assist! protpibe Off-Topic Lounge [WARNING: NO POLITICS] 11 07-08-2015 05:51 PM
Cusco Jack Assist Ramp Set Evasive Motorsports Mechanical Maintenance and Tools 0 04-17-2015 01:40 PM
Car randomly doesn't start on slight hill Craig Issues | Warranty | Recalls / TSB 7 02-01-2013 01:48 PM
