Old 06-04-2017, 02:56 PM   #1
Williampreza
Williampreza's Avatar
Drives: 2017 Ice Silver BRZ Limited
Does DD Tail as Turn work on 2017?
I'm thinking about the ACE Laguna 90 exhaust for my 2017 BRZ and I want to make sure I still have backup lights. Thx!
Will
Williampreza is offline   Reply With Quote
Old 06-04-2017, 05:50 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Not sure if serious but the MY17 has LED lights, you can't put a white light in them for the reverse.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-04-2017, 07:35 PM   #3
Williampreza
Yes. I'm aware of the led's. That's why I'm asking. Basically, if I delete my reverse light, is there a way that I can use this mod to have a reverse light in a different place, except that I wouldn't need to add any LED's.
The reason I ask is that I've seen several posts from people who did this with their pre-17 twins after switching to this exhaust and losing the reverse light. Does that make sense, or am I misunderstanding the way this device works?
(given that they are not using the mod for it's explicit purpose, but rather taking advantage of a side effect)
Old 06-04-2017, 07:44 PM   #4
Williampreza
Originally Posted by Williampreza View Post
Yes. I'm aware of the led's. That's why I'm asking. Basically, if I delete my reverse light, is there a way that I can use this mod to have a reverse light in a different place (in the assembly with the brake lights and turn signals), except that I wouldn't need to add any LED's.
Old 06-05-2017, 03:45 AM   #5
Kodename47
Kodename47's Avatar
Drives: UK GT86
What they do in the original tail lights is swap the indicator bulb with a white bulb:
You'll either have to replace all the amber LEDs with white ones, or not have a reverse light.
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-05-2017, 06:53 AM   #6
Williampreza
Okay thanks! Guess that's a no for my application.
Old 06-05-2017, 12:06 PM   #7
Diode Dynamics
Diode Dynamics's Avatar
The Tail-as-Turn™ will not be compatible with the 2017 model because of the tail light design differences.
The Diode Dynamics SmartTap™ module works on the 2017 Toyota 86 though!
Nick C.
John C.
Diode Dynamics
Old 06-05-2017, 12:17 PM   #8
KnightRyderx2
Drives: 2014 FR-S
You could do a small LED strip with enclosure behind the stainless mesh.
Something like this. Just out of site till the lights are on. Thats just an idea but something along those lines.
KnightRyderx2 is offline   Reply With Quote
Old 06-05-2017, 01:19 PM   #9
wparsons
wparsons's Avatar
I thought they replaced the amber bulbs with dual "filament" LED's that are white when solid and flash amber (just like the replacement marker bulbs for the front), then add to the wiring harness so the solid white is triggered by the reverse light circuit?
flickr
Old 06-05-2017, 01:47 PM   #10
Williampreza
I think that's what I'll have to do. Maybe find two small rectangular enclosures that can accommodate the existing bulbs and then splice in the connectors.
Old 06-05-2017, 03:11 PM   #11
Kodename47
Kodename47's Avatar
Drives: UK GT86
No, it uses the brake/rear lights as the indicator.
[ame="https://www.youtube.com/watch?v=kuZz7Kih0Ck"]Tail as Turn™ + Backup LED Module for Scion FR-S, Subaru BRZ - YouTube[/ame]
.: Stealth 86 :.
Kodename 47 DJ:
Old 06-05-2017, 03:26 PM   #12
wparsons
wparsons's Avatar
Ah, I was thinking of a different take on it using the switchback bulbs.
flickr
Old 06-05-2017, 03:58 PM   #13
KnightRyderx2
Drives: 2014 FR-S
Out the box it moves your turn to the red circle LEDs. Since you now have the blank space where the blinker was you can move the reverse there, and replace the yellow bulb with a white bulb. You can go a step further and do a switchback blinker/reverse; but that is kinda pointless considering.
Diode Dynamics Tail-as-Turn™: Make your LED tail a turn signal & add backup LEDs! Diode Dynamics Exterior Parts - Lighting 192 10-04-2017 11:51 AM
Would this work to turn off the p0420? guybo Engine, Exhaust, Transmission 15 08-22-2017 09:51 AM
Converting 2017 BRZ fog lights to FRS turn signals? James The Giant Cosmetic Modification (Interior/Exterior/Lighting) 10 04-12-2017 08:19 AM
Turn as tail timing not matching with the front turn signals NahumCC Cosmetic Modification (Interior/Exterior/Lighting) 1 01-03-2016 10:40 PM
Help! Headlights/turn signals don't work and I can't get my car out of park Cajun Cosmetic Modification (Interior/Exterior/Lighting) 27 01-11-2013 11:02 AM
