Old 05-30-2017, 10:10 PM   #29
Gforce
Drives: 2013 Subaru BRZ
Originally Posted by Kronos View Post
I'm stuck at work all day so I won't be able to fully respond until tonight.
Thank you guys for your help so far.
I ordered the ecsta 91 but they shipped the 31 but that's irrelevant. Hopefully it will be better with the 91.
I just changed the rear tires. Fronts are Michelin pilot super sports. So we're the rears before they went bald and then ran over a nail ( hence the doughnut )
I'm a bit worried now because Im a dumb dumb and didn't know about the no doughnuts on rear rule. Totally makes sense tho, * face palm *I drove with a doughnut on the rear for about a week. Probably about 50 miles or so. Any chance I ruined my LSD and that's the cause?
Never, ever mix tire models front and rear. Even different versions of the same tire model is a bad idea. If you absolutely have to mix and match then always put the inferior tires on the front axle.
I put two new Michelin MXM HX tires on the back axle of a fwd car for this reason, after checking with Michelin. In the five years since the original MXM had been released Michelin had upgraded the grip.
Gforce is offline   Reply With Quote
Old 05-30-2017, 10:13 PM   #30
Gforce
Honestly the rear bald supersports felt more confident and predictable on the highway that my car feels currently with the ecsta 31.
The fronts still have about half tread on them.
That's because the Supersports is the best tire you can buy unless you want the Sport Cup.
Old 05-30-2017, 10:23 PM   #31
Gforce
What was "wrong" ....... I watched the movie ...... I don't get why you say wrong .......
S a r c a s m.
It's a British thing. Some Canadians think they can do sarcasm. Harris can, he's British.
But, they can't.
Great illustration of why you don't fit space savers to the drive axle unless you have no choice.
The Following User Says Thank You to Gforce For This Useful Post:
humfrz (05-31-2017)
Old 05-30-2017, 10:24 PM   #32
Gforce
Originally Posted by gramicci101 View Post
I'm willing to bet your rear toe is out of whack. It sounds like you have toe out in the rear instead of neutral or toe in.
You will lose your money. Take back the bet before it's too late.
The op just has to swap tires front to rear and hey presto, no more mushy rear axle.
Old 05-31-2017, 02:05 AM   #33
gramicci101
Off Topic
Hold on a second while I pretend you have a single clue of what you're talking about.
The Following 4 Users Say Thank You to gramicci101 For This Useful Post:
Cole (06-02-2017), Tcoat (05-31-2017), Ultramaroon (06-01-2017), WRBrzRX (06-01-2017)
Old 05-31-2017, 06:03 AM   #34
Duh. That's nothing to do with the diff. You don't want the space saver on a drive wheel.
"LSD (if equipped)"
You truly believe that running two radically different tires can not harm the diff?
You should never run one on a drive wheel but that goes even stronger for cars with an LSD.
Dadhawk (06-01-2017), humfrz (05-31-2017)
Old 05-31-2017, 09:41 AM   #35
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
Originally Posted by ST185RC View Post
HAH! wrong
You say 'wrong" yet post a completely different car LOL, you're the wrong one still, nice try though. "General" =/= all.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following User Says Thank You to 8RZ For This Useful Post:
Tcoat (05-31-2017)
Old 05-31-2017, 06:15 PM   #36
ST185RC
Drives: White Out FR-S
Uh, my post was in response to:
As a general rule of thumb, you really don't want to use a spare on any of your drive wheels, whether FWD or RWD.
Where chris harris wants to use a spare.
ST185RC is offline   Reply With Quote
Old 05-31-2017, 06:18 PM   #37
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Oof, wish we could threadlock until the OP posts an update, would save a lot of threads from going to shit over the past month or so.
ineedyourdiddly
Cole (06-02-2017)
Old 05-31-2017, 07:02 PM   #38
Shinigami301
Slow driver, fast biker.
Shinigami301's Avatar
Drives: '16 86, '00 Celica GTS, Sportbikes
Here you go.
Shinigami301 is offline   Reply With Quote
The Following 2 Users Say Thank You to Shinigami301 For This Useful Post:
Cole (06-02-2017), strat61caster (05-31-2017)
Old 05-31-2017, 10:03 PM   #39
Originally Posted by Shinigami301 View Post
Here you go.
Medium strength red? We would blow through that in seconds.
Cole (06-02-2017), strat61caster (06-01-2017)
Old 05-31-2017, 10:17 PM   #40
Gforce
"LSD (if equipped)"
Torsen could care less. Totally different from clutch type LSD.
Old 05-31-2017, 10:18 PM   #41
Gforce
Take all the time you think you need. You still won't understand.
Confirmation bias.
Look it up.
Old 06-01-2017, 06:20 AM   #42
My excerpt was directly from the FRS manual. Apparently at least the engineers that wrote it think it cares.
loose rear-seat latches hyperpunx Issues | Warranty | Recalls / TSB 34 02-22-2017 05:19 PM
what bushing should i get for better handling nearvincent Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 10-15-2014 04:26 PM
Outside Rear View Mirror Housing Loose tonytduc Issues | Warranty | Recalls / TSB 3 10-01-2014 03:20 PM
Help! Trd rear bumper loose :( FaNtaSy Cosmetic Modification (Interior/Exterior/Lighting) 1 10-25-2013 08:01 AM
Best handling car? gt8613 FR-S / BRZ vs.... 154 10-07-2013 09:57 PM
