Old 09-30-2014, 08:01 PM   #1
tonytduc
tonytduc's Avatar
Outside Rear View Mirror Housing Loose
Anybody have this problem? Driving on freeway and notice the mirror housing moving back and forward. More so on driver side then pass.
tonytduc is offline   Reply With Quote
Old 09-30-2014, 08:34 PM   #2
roddy
roddy's Avatar
Drives: '13 Ultramarine
Yes. There was a thread with instructions and pics on here a while ago. The fix is pretty easy. Just pop the black plastic off the pedestal, remove the bolts holding the mirror to the door, then turn the mirror over, and there are a couple of small Phillips screws up inside the pedestal that will need to be tightened. If you can find that thread, it will give you more/better details. It should only take 10-15 mins to fix.
Old 09-30-2014, 09:31 PM   #3
tonytduc
tonytduc's Avatar
S-SB-0016-14.pdf
Found tsb
Old 10-01-2014, 03:20 PM   #4
rapidcars
rapidcars's Avatar
Drives: 2013 DGM BRZ Limited
Bring it to the dealer and they'll fix it for free. They may have to order the part though.
rapidcars is offline   Reply With Quote
DIY JDM Rear View Mirror F1point4 DIY (Do-It-Yourself) Guides 29 12-23-2014 01:55 AM
OEM Rear View Mirror and OEM Side Mirror hanabie Cosmetic Modification (Interior/Exterior/Lighting) 2 03-28-2014 10:07 PM
Rear view Mirror with monitor? Trashed675 Electronics | Audio | NAV | Infotainment 2 02-07-2014 10:38 AM
Rear view Mirror polarized CajunFRS Cosmetic Modification (Interior/Exterior/Lighting) 2 01-05-2014 12:52 AM
Rear view Mirror pic nixeighty6 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 45 01-27-2012 05:10 PM
