Old 05-29-2017, 12:50 AM   #1
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Fuel Starvation?
This weekend I was running Streets of Willow, counter clockwise. I started the day with a full tank of fuel. The last session of the day my car started acting funny. Going up the hill through the Chicane to the bowl I could run through the gears to 7500 no problem. But coming down hill turning left in the last two corners before the main straight my engine would just kind of go flat and not rev above 6000 rpm on the straight. I was down to a half a tank of fuel at this point. Do you think this could be a fuel sloshing problem from the half full tank and left hand turns?
Lunatic is offline   Reply With Quote
Old 05-29-2017, 10:02 PM   #2
stevesnj
stevesnj's Avatar
Depends where the pickup strainer is.
My 2016 Build thread
Old 05-29-2017, 10:57 PM   #3
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
You can definitely starve on 1/2 tank, but shouldn't if the car is NA. It's a pretty big pop / immediate loss of power if you run the rails dry.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 05-29-2017, 11:18 PM   #4
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
The 'won't rev past 6000 on the straight ' doesn't sound like a fuel starvation problem. In my experience a starvation occurs mid corner and goes away fairly soon; by corner exit depending on length of corner
Sleepless is offline   Reply With Quote
Old 05-29-2017, 11:43 PM   #5
zdr93523
zdr93523's Avatar
Yea that sounds odd. I'll start to lose FP mid-corner and the power level / consumption sometimes won't let it recover and I'll end up starving at the end of a straight.
www.makesmodels.com
www.camautomag.com
Old 05-30-2017, 09:42 AM   #6
Lunatic
Lunatic's Avatar
Supercharged on e-85
Old 05-30-2017, 11:33 AM   #7
Jonsey
Jonsey's Avatar
I was fuel starving my car N/A on E85 by 7/8th of a tank on a long, high-g left hander before going with a surge tank. It would starve right after corner exit and would last two or three seconds.
"It is better to keep your mouth closed and let people think you are a fool than to open it and remove all doubt." Mark Twain
Jonsey is offline   Reply With Quote
Old 05-30-2017, 01:47 PM   #8
Lunatic
Lunatic's Avatar
That sounds like what I was experiencing.
Old 05-30-2017, 04:46 PM   #9
Sleepless
Sleepless's Avatar
Drives: 2014 BRZ
Do you have a data log with RPM, speed and throttle position?
Old 05-30-2017, 05:56 PM   #10
Lunatic
Lunatic's Avatar
No.
Old 05-31-2017, 11:46 AM   #11
2superblus
2superblus's Avatar
Drives: 13 BRZ WRB
Are you running with stability or traction control on?
2superblus is offline   Reply With Quote
Old 05-31-2017, 07:25 PM   #12
Lunatic
Lunatic's Avatar
NO
Old 05-31-2017, 07:35 PM   #13
Lunatic
Lunatic's Avatar
I was able to do some test pulls today. rev to 7500, up to 120 mph with no trouble, engine pulled hard all the way and wide band O2 never leaned out. So I'm guessing it was just the half full tank and the track configuration that was causing my problems.
Old 05-31-2017, 09:45 PM   #14
georgiafrsguy
Drives: white 2013 frs
you def had fuel starvation at half tank with your setup for sure. welcome to the club. gonna have to keep full tank or get surge tank setup. couldn't run Atlanta motorsports park n/a with half a tank without starving
georgiafrsguy is offline   Reply With Quote
Left Hand turn fuel starvation on WOT Huehuecoyotl Tracking / Autocross / HPDE / Drifting 105 08-05-2021 08:12 PM
High boost, e85, fuel starvation on a road course: What's everyone doing in 2015? Xero-Limit Tracking / Autocross / HPDE / Drifting 6 06-16-2015 01:45 PM
Fuel Starvation issues? YAY OR NAY? track_warrior Tracking / Autocross / HPDE / Drifting 23 10-22-2013 12:19 PM
Oil starvation in high loads jdcorbitt3 Engine, Exhaust, Transmission 7 06-01-2013 11:46 PM
Fuel Starvation feldy Tracking / Autocross / HPDE / Drifting 1 06-09-2012 11:14 AM
