Old 05-26-2017, 11:34 AM   #4481
redlined600
redlined600's Avatar
Drives: Fr-s
Originally Posted by Tokay444 View Post
Shouldn't matter. It's a drum/shoe setup.
Ha, you're right. I owned a Miata too long.
redlined600 is offline   Reply With Quote
Old 05-26-2017, 11:45 AM   #4482
dattran86
Driver
Drives: 2013 Whiteout FRS
I wont be back at the race track for another month.
Im going to sand the rotor and get some new brake pads.
Will see if it happen again.
dattran86 is offline   Reply With Quote
Old 05-26-2017, 12:49 PM   #4483
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
I can't imagine sanding the rotors by hand will get you any benefits in creating a smooth surface, if anything I'd bargain it makes it worse, if you're going to bother getting the rotors off have them turned down by a local machine shop if there's enough life left in the rotors to justify not buying new ones.
Without knowing Canadabuck prices new rotors are like $40/ea USD and turning down old ones is like $20/ea, probably worth it if they're at half life or more.
ineedyourdiddly
Old 07-04-2017, 11:54 AM   #4484
n0thing
Drives: Subaru BRZ
I recently installed single exit exhaust for weight saving. if I remove all the spare/jack from the trunk for tracking purpose (never did before), is that a bad thing? in the sense that, this will move the weight distribution more to the front, despite the weight lost, thus increasing oversteer?
n0thing is offline   Reply With Quote
Old 07-04-2017, 03:07 PM   #4485
Pat
Pat's Avatar
Drives: 2023 BRZ
You'll be fine. Any negative handling effects will be more than offset from the lighter weight.
Old 07-04-2017, 06:58 PM   #4486
moliver
Drives: FR-s
what oil cooler "kit" for the track?
moliver is offline   Reply With Quote
Old 07-04-2017, 08:15 PM   #4487
Sleepless
Drives: 2016 FR-S
I’ve seen excellent results from both the Perrin and Jackson Racing. Prefer the Jackson Racing for the extra capacity (and reuse when switching from NA to thei SC; the Perrin didn’t have the capacity for the SC).
Sleepless is offline   Reply With Quote
Old 07-05-2017, 04:12 PM   #4488
brzest
Drives: '15 BRZ
OK, here's a tricky one regarding the issue that a wider wheel/tire combo will be slower around a track than a narrower one (on stock power).
So I did a test...
4 runs, 2 in each direction, same (straightish) road, logged with 10HZ external GPS on Harry's Lap Timer from 90 to 170 km/h.
18x8.75 XXR527's 245/40 18 Nexen NFera SU1
14.58 & 14.58 seconds in 1 direction and 14.29 & 14.34 seconds in the other
then switched to the OE wheels on 215/45 17 Michelin Pilot Sport Cup2's
14.72 & 14.65 seconds in 1 direction and 14.41 & 14.44 seconds in the other
So the runs were done on the same road, less than 1 hour between the runs, same weather etc.
The weight of the XXR527 should be the nearly the same as the OE wheels, maybe slightly less. However since the Cup2's are one of the lightest tires around, I'm pretty sure the overall 17" combo weight was smaller, however I have not weighed them.
So there was no noticable difference, if anything the narrower 17s were slower.
Can anyone explain, why?
brzest is offline   Reply With Quote
Old 07-05-2017, 05:14 PM   #4489
strat61caster
Because at those speeds the thing your car is fighting the most is aerodynamics, rolling resistance and weight are a drop in the bucket of load your engine is fighting at those speeds.
To see a difference in weights/widths/rolling resistances you'll need to keep it <90 kmh and it'll be best if you have multiple accelerations in your 'test'.
ineedyourdiddly
Old 07-05-2017, 05:58 PM   #4490
CSG Mike
CSG Mike's Avatar
Jackson Racing.
It's what I run on my car. PM to order.
Old 07-05-2017, 05:59 PM   #4491
CSG Mike
CSG Mike's Avatar
So I did a test...
CUP2 has higher rolling resistance.
Old 07-06-2017, 01:54 AM   #4492
brzest
Drives: '15 BRZ
Ok, I will test at lower speeds next time I'm going to the track and swapping wheels anyway.
Thanks!
Old 07-06-2017, 08:58 AM   #4493
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I went from the stock 215 Primacies to 245 RE-71Rs and exited the final corner of a local track 10mph faster. I got to the other end of the straight and was only 1-2 mph faster than the 215s. That's a huge amount of speed to give up on every straight.
Old 07-06-2017, 09:43 AM   #4494
Icecreamtruk
Drives: Track preped NA FRS
Do you recall how long was that straight?
Icecreamtruk is offline   Reply With Quote
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
