#15 | |
Drives: 2016 BRZ Limited
Weir F/D
| The Following User Says Thank You to vintagemxer For This Useful Post: | TofuJoe (05-13-2017) |
#16 |
Here ya go Joe & anyone else looking to go this route...which is amazing by the way...
75 MPH...6th gear...2500 RPM's...5th gear...3200 RPM's...4th gear 4500 RPM's. I did a photo shoot today up in the canyon...I can tell you 3rd gear is pretty much all I use, unless the road is long enough before I need to shift @ 7 g's...I'm doing 80. Love Love Love this upgrade !!!!! |
#18 |
Drives: 2013 Scion FR-S 6M Argento
#19 |
Drives: red scion frs
I have a 4.88 rear, (from spencer) at 110kmh (aprox 70mph) I am at 2700 revs in 6th in an auto.
#20 |
Project Shadow
Drives: 2015 BRZ Limited 6MT
That's sad to hear! Not too long ago he rebuilt my diff with a 3.73 FD, solid spacer, and supra bearing while installing a Harrop diff cover too under his exchange program. He did really good work too......
#21 |
Drives: 2014 DGM BRZ
yeah i think thats the one i was looking to get!!! it also had the much beefier carrier bearings right??
#22 |
this was all with the stock diff correct? does anyone know what the limitations are on the stock diff?
#23 |
Project Shadow
Yes. As for limitations, not sure. I dont think i have ever heard of anyone grenading these diffs from power, but i could be wrong. From research they seem to be very similar to the is300 diffs and those have been known to hold 700+rwhp regularly without issue.
#24 |
Drives: 2013 Asphalt FRS
Mark got a job offer he couldn't refuse, and has a baby on the way, I believe in July. The benefits were just to good to pass up and with a new baby he wanted the best for his wife and soon to arrive child. He loved doing his own thing but loves his family more, so who can blame him right.
I have used weir performance out of cali several times, Spencer Weir is a stand up guy. And yes the factory diffs hold 700 plus hp easily Ive been beating on mine for 2 or 3 years dumping the clutch at 7000rpm at 20 psi of boost.... You don't need all that fancy high dollar stuff to be dependable.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
| The Following 3 Users Say Thank You to FRS Justin For This Useful Post: |
#25 |
The carrier bearings are good to go but the pinion bearings are a little on the small side get the upgraded pinion bearings and solid sleeve.
#26 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
"As far as the parts Spencer Fab was using, they were purchasing all of this from us. We always use the solid pinion spacer on our builds and the upgraded pinion bearings as well. All of these parts are listed on your estimate emailed earlier. I'll get this going as soon as possible once I am back from my vacation, thanks." So it looks like the Weir Performance route is a good way to go but you will just need to supply him with the diff up front. |
| The Following 2 Users Say Thank You to BirdTRD For This Useful Post: | FRS Justin (05-21-2017), jcw99 (05-22-2017) |
#27 |
Drives: swp mt '14 brz premium
#28 |
Notice it mostly when decelerating.
| The Following User Says Thank You to vintagemxer For This Useful Post: | jcw99 (05-25-2017) |
| FS- Spencer Fab built 4.88 Final Drive | qwerty66 | Transmission and Driveline | 9 | 05-12-2017 01:01 PM |
| DIY - Air Spencer | P@ul | DIY (Do-It-Yourself) Guides | 6 | 03-02-2014 02:04 PM |
| Spencer Strayer's Ultramarine FR-S | Spencer Strayer | Member's Car Journals | 33 | 04-09-2013 07:26 PM |
| GIGA AIR Spencer? | NemeGuero | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 12-13-2012 02:30 PM |
