Old 05-13-2017, 01:24 AM   #15
vintagemxer
vintagemxer's Avatar
Drives: 2016 BRZ Limited
Weir F/D
Originally Posted by TofuJoe View Post
@vintagemxer - why the Weir final drive instead of the Cusco/Toyota one. Is it louder than stock? How high are you revving at 75mph now?
It does make a little more noise than stock. Cost, and I'll get back to you on the RPM's.
vintagemxer is offline   Reply With Quote
The Following User Says Thank You to vintagemxer For This Useful Post:
TofuJoe (05-13-2017)
Old 05-14-2017, 07:50 PM   #16
vintagemxer
Here ya go Joe & anyone else looking to go this route...which is amazing by the way...
75 MPH...6th gear...2500 RPM's...5th gear...3200 RPM's...4th gear 4500 RPM's.
I did a photo shoot today up in the canyon...I can tell you 3rd gear is pretty much all I use, unless the road is long enough before I need to shift @ 7 g's...I'm doing 80. Love Love Love this upgrade !!!!!
Old 05-14-2017, 07:52 PM   #17
vintagemxer
And Thanks to Neal @ theracersline for hooking me up ") !!!
Old 05-14-2017, 09:07 PM   #18
Jrdad
Jrdad's Avatar
Drives: 2013 Scion FR-S 6M Argento
This must be with an automatic I presume?
Jrdad is offline   Reply With Quote
Old 05-15-2017, 12:12 AM   #19
jackblack21
Drives: red scion frs
I have a 4.88 rear, (from spencer) at 110kmh (aprox 70mph) I am at 2700 revs in 6th in an auto.
jackblack21 is offline   Reply With Quote
Old 05-15-2017, 12:39 AM   #20
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
That's sad to hear! Not too long ago he rebuilt my diff with a 3.73 FD, solid spacer, and supra bearing while installing a Harrop diff cover too under his exchange program. He did really good work too......
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
Old 05-20-2017, 02:05 AM   #21
BlaqkHavok
Drives: 2014 DGM BRZ
yeah i think thats the one i was looking to get!!! it also had the much beefier carrier bearings right??
BlaqkHavok is offline   Reply With Quote
Old 05-20-2017, 02:06 AM   #22
BlaqkHavok
this was all with the stock diff correct? does anyone know what the limitations are on the stock diff?
Old 05-20-2017, 04:39 AM   #23
Drakiv
Project Shadow
Drakiv's Avatar
Yes. As for limitations, not sure. I dont think i have ever heard of anyone grenading these diffs from power, but i could be wrong. From research they seem to be very similar to the is300 diffs and those have been known to hold 700+rwhp regularly without issue.
614whp/421tq on E85
Instagram: Drakiv
Old 05-20-2017, 12:38 PM   #24
FRS Justin
Drives: 2013 Asphalt FRS
Mark got a job offer he couldn't refuse, and has a baby on the way, I believe in July. The benefits were just to good to pass up and with a new baby he wanted the best for his wife and soon to arrive child. He loved doing his own thing but loves his family more, so who can blame him right.
I have used weir performance out of cali several times, Spencer Weir is a stand up guy.
And yes the factory diffs hold 700 plus hp easily Ive been beating on mine for 2 or 3 years dumping the clutch at 7000rpm at 20 psi of boost.... You don't need all that fancy high dollar stuff to be dependable.
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following 3 Users Say Thank You to FRS Justin For This Useful Post:
Drakiv (05-20-2017), Sportsguy83 (05-22-2017), vintagemxer (05-25-2017)
Old 05-20-2017, 12:42 PM   #25
FRS Justin
The carrier bearings are good to go but the pinion bearings are a little on the small side get the upgraded pinion bearings and solid sleeve.
710whp
Old 05-21-2017, 08:19 PM   #26
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Shipped a spare diff out to Spence Weir last week to get the 4.88 build. I asked about the upgraded pinion bearing and spacer, here's his response:
"As far as the parts Spencer Fab was using, they were purchasing all of this from us. We always use the solid pinion spacer on our builds and the upgraded pinion bearings as well. All of these parts are listed on your estimate emailed earlier. I'll get this going as soon as possible once I am back from my vacation, thanks."
So it looks like the Weir Performance route is a good way to go but you will just need to supply him with the diff up front.
BirdTRD is offline   Reply With Quote
The Following 2 Users Say Thank You to BirdTRD For This Useful Post:
FRS Justin (05-21-2017), jcw99 (05-22-2017)
Old 05-22-2017, 10:36 AM   #27
jcw99
Drives: swp mt '14 brz premium
Does it make noise at power or coast or both?
jcw99 is offline   Reply With Quote
Old 05-25-2017, 02:22 AM   #28
vintagemxer
Notice it mostly when decelerating.
jcw99 (05-25-2017)
FS- Spencer Fab built 4.88 Final Drive qwerty66 Transmission and Driveline 9 05-12-2017 01:01 PM
DIY - Air Spencer P@ul DIY (Do-It-Yourself) Guides 6 03-02-2014 02:04 PM
Spencer Strayer's Ultramarine FR-S Spencer Strayer Member's Car Journals 33 04-09-2013 07:26 PM
GIGA AIR Spencer? NemeGuero Cosmetic Modification (Interior/Exterior/Lighting) 6 12-13-2012 02:30 PM
