Old 07-07-2016, 09:25 PM   #547
mynameis940
mynameis940's Avatar
Drives: WRX
If anyone is interested im selling almost everything in this kit, just missing on piece.
http://www.ft86club.com/forums/showthread.php?t=107896
mynameis940 is offline   Reply With Quote
Old 08-24-2016, 08:36 AM   #548
maca
Drives: brz
PM'd , let me know !
maca is offline   Reply With Quote
Old 08-30-2016, 09:46 AM   #549
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
does anybody have the height of the forester oil cooler? Basically the height for part number 21311AA170
pgranberg11 is offline   Reply With Quote
Old 09-01-2016, 12:59 PM   #550
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Originally Posted by Irace86 View Post
Sounds like this is a good setup for anyone because it helps warm the oil faster, and acts as a regulator by distributing heat out among the system. Sounds also like it will maintain oil temps just fine for most applications.
The point that I read is that the stock coolant journals throughout the engine don't pull enough heat off the oil, so this oil cooler provides a mechanism for getting that accomplished. And the idea is that spikes in temperatures in any one area (fluids, chambers) can lead to engine failure, so distributing the heat out will allow for safer engine use at high thresholds.
The other point is that this kit doesn't increase the thermal capacity of the system because there is no addition of cooling surface area. If heatsoak was an issue then a larger radiator would be necessary. In the case that the oil regulator couldn't extract enough heat, and it was a bottleneck in cooling (coolant temps were ok, oil temps were heat soaked) then a dedicated oil cooler would be necessary. The good thing is that OEM oil regulator could work in conjunction with aftermarket oil coolers with the addition of a sandwich plate like with the Mishimoto example. In either case, with a radiator or with an aftermarket oil cooler, the system has increased its thermal capacity through the addition of more radiators/cooling surface area.
would a termostat plate still be needed for cooler climates or would the oem setup keep the temps up?
Old 09-01-2016, 06:31 PM   #551
Irace86
Drives: BRZ + Ducati M796
Unfortunately that is not a subject I am familiar with so I can't really comment.
Irace86 is offline   Reply With Quote
Old 09-02-2016, 04:30 AM   #552
banane63
banane63's Avatar
Drives: BRZ Club blanc perle
As water going up faster than oil, it will rise the oil temp quicker. A radiator will low the temperature, that's why you then needs a thermostat plate.
Collecteur et frontpipe Supersprint full décat - Catback Remus
Admission directe Greddy - Kit Flexfuel et map Ecutek Visconti Tuning - Tein Street Advance EDFC Pro - NED modine - OZ Alleggerita 18 Michelin PS4 - Wilwood 6 pistons
banane63 is offline   Reply With Quote
Old 09-18-2016, 03:56 PM   #553
sickmint79
Drives: bmw
have some data and comparisons for this kit when pushed hard. go with the throttle body routing
https://www.pointmeby.com/2016/09/18...z-frs-gt86-86/
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com
sickmint79 is offline   Reply With Quote
The Following 2 Users Say Thank You to sickmint79 For This Useful Post:
phrosty (09-18-2016), taiguy (01-27-2017)
Old 03-08-2017, 07:55 PM   #554
taiguy
Drives: 2013 Black BRZ Limited
Has anyone run into coolant leaks with this setup? I burped my system with a spill free funnel and ran the car for 10-15 min until the air bubbles slowed way down.
The morning after the install I found a nice antifreeze puddle on the street under my BRZ. It appears to be a small leak.
No issues from the front pipe or connections off the oil cooler itself.
Then I found this at the bottom.
Luckily the nipple didn't seem to be exhibiting any issues. I was worried I'd have to deal with that... after loctiting it in.
Following the trail of dried coolant further, it looks like the smaller pipe and hose by the firewall is the source of the leak.
I'm struggling right now to get that little hose clamp back off but will end up replacing it with a standard one once I do.
taiguy is offline   Reply With Quote
Old 05-10-2017, 12:31 PM   #555
TunaNoCrust1984
TunaNoCrust1984's Avatar
Drives: 2013 Toyota GT86
Hey guys, while surfing the interwebs, looking for cheaper subaru parts stores I found this one. For people living in the southeast part of the US this would be a great place. Don't know if shipping will be more for the west coast, I doubt it, but the price shipped came to $268.54 shipped. Hope this helps.
http://www.subarupartssuperstore.com
TunaNoCrust1984 is offline   Reply With Quote
Old 05-17-2017, 04:47 PM   #556
pgranberg11
BoostedBRZ
Drives: Turbo BRZ
Originally Posted by Roberto12 View Post
https://goo.gl/photos/nAomQwmNrGLmHBh3A
https://goo.gl/photos/fXTgxowjS5yEgySK7
I have an external oil cooler and the OEM together. It does not smack the hood.
hard to tell, but is that the racerX fabrication sandwich plate and spacer with the forester setup?
The Following User Says Thank You to pgranberg11 For This Useful Post:
sroby (01-28-2019)
Old 07-26-2017, 03:06 PM   #557
bass_114
bass_114's Avatar
Drives: wrb brz
Just about to try out the throttle version install and wondering if there is any importance to the way the hoses hook up from the cooler to the throttle body (how to tell which goes to the inlet and which to the outlet) also what size hoses to use that fits the barb on the throttle nipple, read threw the thread one guy said 3/8" and others say 1/2"
thanks!
bass_114 is offline   Reply With Quote
Old 10-26-2017, 11:54 PM   #558
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Hey everyone, I've got a fairly stupid question I'd like to ask!
I'm planning on installing the Forest XT oem oil cooler/ regulator but wanted to know if I could simply reuse my engine coolant, when I drain the system, instead of buying several containers of it. Being that the car is roughly 6mo old, I didn't see any reason it wouldn't work as long as I use a clean pan with no contaminants. Thoughts?
MS, CSCS, TSAC-F, CPT
Old 10-30-2017, 02:01 PM   #559
nunonuna
nunonuna's Avatar
You can.
I did it twice using empty distilled water jar. You can connect hose from overflow tank to the tip of drain nipple then collect coolant straight to water jar. When I refill it, I filtered it just in case.
나의 SM-N950U 의 Tapatalk에서 보냄
nunonuna is offline   Reply With Quote
The Following User Says Thank You to nunonuna For This Useful Post:
weederr33 (10-30-2017)
Old 10-30-2017, 02:17 PM   #560
weederr33
weederr33's Avatar
Originally Posted by nunonuna View Post
You can.
What did you use to filter the coolant?
brz, fxt, oil, oil cooler
OEM Oil cooler from the 2.0 DIT Forester Kostamojen Engine, Exhaust, Transmission 119 09-10-2019 05:28 AM
Bought a 2014 Subaru Forester EAGLE5 Other Vehicles & General Automotive Discussions 10 10-02-2013 12:54 PM
2014 Forester key fob - nicer than BRZ Turbowned Cosmetic Modification (Interior/Exterior/Lighting) 3 04-17-2013 03:35 PM
BRZ 2.0L Turbo in 2014 Forester Sleeperz BRZ First-Gen (2012+) — General Topics 37 03-21-2013 06:42 PM
Review after test driving a 2013 WRB BRZ and 2014 Forester in Okinawa, Japan… 2013GTRNate BRZ First-Gen (2012+) — General Topics 12 02-01-2013 12:29 PM
