#295 | |
I will never cease to be amazed at how they keep getting more and more stock power out of lighter and smaller engines. When you consider that my old 1970 R/T's 440 (7.2 liter) magnum weighed in at 670 pounds and produced a blistering 280 HP (stock) it is easy to see how far things have progressed. Half the weight with twice the HP is nothing to sneeze at.
#296 | |
Drives: 17 Alfa Romeo 4C
FA20 engine weighs 377lbs LS3 over 400lbs N54 around 430lbs. Are you sure they are not heavier? For what its worth .... the LS3 engine based on weight and output is amazing.
My 2013 Firestorm Red 13 FRS is gone. Bought the next best thing: 2017 Alfa Romeo 4C
#297 | |
TRACKBREAD
Iron blocks and heads are heavy lol! I think we won't see much improvement in engine weights now that most cars already have an all aluminum motor. More expensive cars can go a bit further with a full magnesium alloy block and heads (like BMWs N52), but the gains aren't anywhere close to switching from iron to aluminum. Sent from my iPhone using Tapatalk |
#298 | ||
Drives: '15 BRZ RA
#299 |
Drives: '15 BRZ RA
Here is a block with the liners:
#300 | |
TRACKBREAD
Sorry I borked a number on the BMW motor. I meant N52, not N54. The N52 is NA and magnesium alloy, the N54 is twin turbo and aluminum. There's an LS motor that the swap guys claim is lighter than the FA20 too. Sent from my iPhone using Tapatalk |
#301 |
I've broken the code on the Twins future...
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
#302 |
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
https://drivetribe.com/p/ATKkqSJRT5O...SB6eX3_mo1EtkA
Article on Drivetribe, 13 cars that will become classics in 20 years. GT86 is number 2. |
#303 | |
#304 | |
Circle Work Clerk
I think these cars will end up like the NA Miatas or 240Z Fairlady. They'll bottom out for awhile and then clean examples will see a demand. Finding a clean example in 20 years is going to be quite a task, though at the rate my mileage is going (16700 after 4.5 years) I'll barely be at 90,000 miles in 20 years. |
#305 |
Drives: 2013 Subaru BRZ
Stroker motors are heavier because they have heavier cranks, the heaviest component in an aluminum block engine. They also usually fit longer rods, also steel and heavy.
Subaru already makes a stroker variation of the FA20, the FB 20. It would be child's play for them to combine the 86 mm bore with the 90 mm stroke but they won't. To get to 2.5 they need a 94 mm bore as well, and Subaru already makes one of those also, the FB 25. That's massively bigger for such a small car but it will fit. After all somebody shoehorned a Ferrari V8 in there already. Why they didn't wait for the turbo V6 Alfa/Maserati version is a mystery. One would think 500 HP was "enough". They also make a turbo version of the FA20 which you just know would drop right into the BRZ engine bay. Throw away that juvenile intake noise generator and take a peek at how much room there is in front of the FA 20, room for a pair of cylinders let alone a turbo. Subaru and Toyota won't turbo this car because it would increase the price and alter the essence of the car. FI would add at least $5k to the production cost. Says the man with his eForce Supercharger....expensive mod but really, really worth adding. |
#306 |
Drives: between cars...
#307 |
#308 | |
There are probably a thousand or more other considerations that people do not know or care about when they start changing up engines so there is much more to it than they don't want to increase the cost of the car.
| Serious Question: Save for possible future BRZ tS, or throw money at current BRZ? | Kostamojen | BRZ First-Gen (2012+) — General Topics | 72 | 05-08-2017 02:40 PM |
| Bad Sign for Future Twins, or Blessing? [Article] | Koa | Other Vehicles & General Automotive Discussions | 14 | 11-19-2014 11:09 PM |
| a turbo in the twins future??? | AndyJ | Scion FR-S / Toyota 86 GT86 General Forum | 19 | 05-07-2014 04:46 PM |
| Twins vs future competition | regal | FR-S / BRZ vs.... | 69 | 07-12-2013 08:51 AM |
| Future of the "twins" | regal | Scion FR-S / Toyota 86 GT86 General Forum | 85 | 06-05-2013 08:54 PM |
