Old 05-14-2017, 07:43 PM   #1
ixobelle
KPOP TRASH
ixobelle's Avatar
Drives: 2015 BRZ
E85 + OFT + headers: stalls out on cold start
Each morning my BRZ needs a few tries to turn over. It coughs and sputters, then dies out if I can't get it to catch on the first try. Usually on the second or third try it catches, then runs fine (great, even!) once it warms up.
I'm thinking it has to do with the E85... I've enjoyed the extra oomph it provides, but without a true flex fuel kit, I'm afraid it just isn't properly tuned for this fuel.
Has anyone else run into this? I may try running this tank low and swapping back to a normal flash for 91.
Bay Area CA if that helps. It's not crazy cold in the mornings, or anything extreme.
ixobelle is offline   Reply With Quote
Old 05-14-2017, 08:01 PM   #2
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
If its under 60f degrees I almost always have to crank the engine twice on high mixtures of E85. If i'm running something like E70 it usually starts on first crank, but otherwise it takes minimum two cranks. This is totally normal according to Moto-Mike at Moto-East.
What mixture of E85 are you running? Temps?
ajcarson11 is offline   Reply With Quote
The Following User Says Thank You to ajcarson11 For This Useful Post:
ixobelle (05-15-2017)
Old 05-14-2017, 08:02 PM   #3
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
That's pretty normal when running the OFT E85 tune. Something I've found that seems to help is leaving the key in the accessory position for about 10 seconds before actually starting the engine. I have a garage now, so it's not much of an issue, but I used to see stalling issues anytime temps got below 60F.
smg1138 is offline   Reply With Quote
The Following User Says Thank You to smg1138 For This Useful Post:
Old 05-14-2017, 08:06 PM   #4
steve99
Drives: FT86
Modify you cranking injector pulse tables and it should start first crank doen to about 40f and maybe lower on e70
See tune tweaks link below
The Following 2 Users Say Thank You to steve99 For This Useful Post:
DAEMANO (05-15-2017), ixobelle (05-15-2017)
Old 05-15-2017, 03:09 AM   #5
ixobelle
KPOP TRASH
ixobelle's Avatar
Drives: 2015 BRZ
Thanks all for the responses, I'll dig into the flash mods, and see if I can figure it out. Mostly happy to see it's not just me!
Old 05-15-2017, 04:55 AM   #6
thatfilipinoguy
thatfilipinoguy's Avatar
Drives: 87 Supra, 13 FRS, 05 FXT
Where in Antioch are you at?! I thought I was the only one out here.
thatfilipinoguy is offline   Reply With Quote
Old 05-15-2017, 12:41 PM   #7
DAEMANO
Time Traveller
Do what @steve99 said. If you don't or can't, then simply adding 1 to 1.5 gallons of premium pump gas to every 9 gallons of e85 will resolve this issue completely and barely affect performance. I've been running this way for about 2.5 years. The car starts perfectly in cold weather. Other options would be to upgrade to an Openflash flex fuel kit and use the tune that comes with it.
The Following User Says Thank You to DAEMANO For This Useful Post:
Old 05-15-2017, 04:37 PM   #8
ixobelle
KPOP TRASH
ixobelle's Avatar
Drives: 2015 BRZ
Just off Hillcrest... look for the plate
The Following User Says Thank You to ixobelle For This Useful Post:
thatfilipinoguy (05-15-2017)
Old 05-16-2017, 11:52 AM   #9
ixobelle
KPOP TRASH
ixobelle's Avatar
Drives: 2015 BRZ
I made a video showing how to do this in RomRaider:
[ame="https://www.youtube.com/watch?v=kULTsJRhJcs"]Coldstart Issues with e85/headers/OFT (fixed with RomRaider) - YouTube[/ame]
The Following 2 Users Say Thank You to ixobelle For This Useful Post:
microSDHC (06-28-2018), Trunksse (02-14-2018)
Cold start question retrosmiths Scion FR-S / Toyota 86 GT86 General Forum 106 11-15-2016 02:14 PM
Cold Start Help Kayysonie Software Tuning 39 03-31-2016 11:35 PM
Cold start JG Engine, Exhaust, Transmission 8 08-29-2015 02:55 AM
E85 cold start Turdinator Software Tuning 8 08-29-2014 11:12 AM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
